Speckles all over flash photo
Started Dec 11, 2013 | Discussions
msjhaffey
Senior MemberPosts: 1,373Gear list
Dec 11, 2013
I took some photographs on saturday at a local Christmas event.  The ones with flash typically came out as follows: the ones without flash were clear. It was not raining.  I checked my lens - it's not spotted.
Anyone know what might have caused it?
Sean
 msjhaffey's gear list:msjhaffey's gear list
Nikon D700 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 70-300mm f/4-5.6G +1 more
unknown member
(unknown member)
Re: Speckles all over flash photo
In reply to msjhaffey, Dec 11, 2013
msjhaffey wrote:Anyone know what might have caused it?
Reflected Dust in the Air.
seahawk
Senior MemberPosts: 2,525
Rain, Dust or snow flakes.
hobby aviation photographer
englishfil
Regular MemberPosts: 149Gear list
The above responses are quite correct. You did not say, but I am guessing you used the pop up flash? This 'phenomena' is frequently seen where the flash output is close to the optical axis of the lens - it is very prevalent on pocket compacts. If you want a laugh at the expense of the cerebrally challenged then look up 'orbs' on the internet - some people believe these blobs to be fairies or spirits - some people believe anything
 englishfil's gear list:englishfil's gear list
Fujifilm FinePix Real 3D W3 Nikon D200 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
msjhaffey
Thanks for the replies.
There was no snow or rain and I was using an SB900.
All I can think of is that the air felt damp, but there was no precipitation, either in the air or on objects. Nor was there any visible mist.
Sean
Hugo First
Contributing MemberPosts: 780
Sean
then that settles it: they must be fairies and spirits!
msjhaffey
In reply to Hugo First, Dec 11, 2013
Indeed.  A sherlock amongst us!
Sean
InTheMist
Senior MemberPosts: 3,059Gear list
Sean
Must be!
Sherlock Holmes said:
... when you have eliminated the impossible, whatever remains, however improbable, must be the truth.
OP: It's definitely something in the air.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Nikon Df Nikon 1 AW1 Nikon D810 Nikon 1 J5 Leica M-Monochrom +16 more
romfordbluenose
Senior MemberPosts: 1,841Gear list
Lots of colds around at this time of year. Perhaps someone sneezed. Also a lot of vapour coming out of the singers mouths.
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +8 more
Todd Jones
Contributing MemberPosts: 646Gear list
In reply to InTheMist, Dec 11, 2013
Sean
Must be!
A rare capture of a nighttime air drop of D600 dust bunnies!
Todd
 Todd Jones's gear list:Todd Jones's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/4G ED VR Tokina AT-X Pro 100mm f/2.8 Macro Carl Zeiss Distagon T* 2/35 Nikon AF-S Nikkor 20mm f/1.8G ED
Andy Cam
Regular MemberPosts: 463
Sean
Hi Sean,
Just a suggestion - but check in with your dealer as I think you need to move on to a DF to prevent this sort of problem.
I'm joking - you already have 2 PROFESSIONAL cameras, and high end PROFESSIONAL lenses and needed to check your lens?!!!  You seriously need to consider spending more time rather than money on your hobby!
Good luck! May your technique and bank balance improve
Bob GB
Senior MemberPosts: 1,660Gear list
It is refections from droplets close to the camera.
This is caused by reflections from condensed droplets in the air very close in front of the camera. The condensed water is probably from your own breathing. The droplets are almost invisible when they are spread out in front of you particularly when it is dark.
You can see these reflections are in front of everything also the person on the podium to the right. From the size you can calculate how close they are at f/4 and 24 mm FL.
Next time keep your breath for a moment before triggering the shutter.
msjhaffey
In reply to Andy Cam, Dec 11, 2013
Well that was helpful.
Sean
msjhaffey
Re: It is refections from droplets close to the camera.
In reply to Bob GB, Dec 11, 2013
Thanks.  It has to be droplets in the air, but not from my breathing: these were in every flash photo taken about this time but not in others that were earlier/later, nor was there any sign of these in non-flash photos.  It's also not droplets from the singers' mouths: I've checked the original photos at 100% and no sign of singer steam.
I think it must just have been the very damp air.
Sean
blue_cheese
Senior MemberPosts: 1,714
Dust
Sean
I have gotten same result this in the summer on a hot clear evening, where there is a large group of people trampling in a spot, there is dust, it is reflecting the flash light and the reflection is enlarged compared to a small light speckle due to it being out of focus. The simplest "solution" was don't use flash for that shot, but I am sure that taking the light off the lens axis would also help if you have a TTL cord
"There are two sides to every issue: one side is right and the other is wrong, but the middle is always evil."
- Ayn Rand
Radu Grozescu
Senior MemberPosts: 1,761Gear list
In reply to msjhaffey, Dec 12, 2013
There is a guy on the stage at right, he maybe generated the dust in the air close to you.
He looks like he is dancing or something.
Radu Grozescu
http://www.RaduGrozescu.com
Corporate & Editorial Photography
 Radu Grozescu's gear list:Radu Grozescu's gear list
Nikon Coolpix A Nikon Df Nikon AF-S Nikkor 28mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G
Stuart001
Contributing MemberPosts: 560Gear list
In reply to englishfil, Dec 12, 2013
I just did this.  Sheesh!  I must say I find it a little sad that there are people who actually seem to believe this stuff.
But as P.T. Barnum was reputed to have said, there's a sucker born every minute.
 Stuart001's gear list:Stuart001's gear list
Nikon D90 Nikon D700 Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 50mm f/1.8G +11 more
Andy Cam
Sean
Perhaps just try my advice, you may be surprised.
Best wishes.
seahawk
As the ground looks wet, I still go with very light drizzle.
msjhaffey
In reply to Andy Cam, Dec 12, 2013
I doubt I'd be astonished.  I'd be totally taken aback.  Staggered.
Sean
