Raw files in Aperture - cleanup
Started Dec 11, 2013 | Discussions
flylow47 Regular Member • Posts: 166
I've been shooting raw for 4 years now and have a few thousand raw files in my Aperture 3.5 library - some of the older ones are actually in a referenced iphoto library.  I don't need them anymore, and last night I did some searches for raw files and exported all of the raw files into "high" quality JPEGS for all periods before this year. My thought was to then delete the raw files from aperture, import the JPEGS back into their parent folders, and empty the Aperture trash.  Is this the best way to accomplish what I'm wanting to do?
 flylow47's gear list:flylow47's gear list
Canon PowerShot G15 Canon EOS 6D Canon EOS 70D Canon EF 85mm f/1.8 USM Canon EF-S 10-22mm f/3.5-4.5 USM +7 more
Johanfoto Veteran Member • Posts: 3,297
Re: Raw files in Aperture - cleanup
Don't! Did you also throw away the negatives after you got your prints when you were shooting on film?
DiploStrat
DiploStrat Contributing Member • Posts: 782
Scholars differ on this, but I agree with Johan - don't ever, not with a gun to your head, delete an original RAW file. (At least not one that surveyed the original quality scan.)
The are like negatives, you never know when you may want them again. I recently scanned thousands of slides, many well over thirty years old. And besides, you may find a software that you like better than Aperture, in which case you will want to be able to take full advantage.
To the news you can use, get another HD (USB 2.0 drives are extremely inexpensive) and move the old images to a new Aperture Library on that drive. Performance won't really be an issue and you can leave the drive powered down most of the time.
Save those memories!
Best wishes.
DiploStrat
 DiploStrat's gear list:DiploStrat's gear list
Nikon D60 Nikon D800E Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
PStu Regular Member • Posts: 335
I purchased a script from Aperture Expert for a few dollars that automates the whole process:  exports as JPEG, imports the JPEG, moves the RAW to the trash folder.  I've done that to a number of RAW files that I judged were low-value, mostly pictures that might have gone into the trash folder for aesthetic reasons but document a moment.  I've also used that to clean up some of the TIFF and PSD documents created by plug-in software where I still have the original RAW file.
 PStu's gear list:PStu's gear list
Olympus XZ-2 iHS Canon EOS 450D Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Canon EF 50mm f/1.8 II +9 more
Brandon birder Veteran Member • Posts: 3,927
Rawhide for Aperture is cheap and available from the App store. It does exactly what you want with lots of options re deletion tagging etc. I use it all the time to jpeg images I don't want to throw away but are not good enough for publishing.
noirdesir Forum Pro • Posts: 12,488
You could just throw away the masters/originals of the photos (or rather put them on an external drive that you then put away into a drawer). You would need to set the preview size to the maximum resolution you want to retain. Only problem is that Aperture won't export images with original missing. This can be side-stepped by simply dragging the images out of Aperture. And if you want to use Aperture's options to tailor exported images in size, quality or other parameters, you could re-import simply by dragging them backing into the project (don't know if that makes them referenced, though) and auto-stack by capture time.
flylow47 OP Regular Member • Posts: 166
Rawhide looks like it will do what i need, and I bought it. However, I could use some help in picking out the right option. I find the help screen less than intuitive.  I'm interested in keeping the full size edited JPEGs on my master hard drive and putting the raw files on an external drive. Which option should I select?
External space is not a concern. I have 3 externals on my iMac (6TB) with plenty of room available.
