Looking Up
Started Dec 11, 2013 | Discussions
bosjohn Veteran Member • Posts: 4,890
Looking Up
bosjohn aka John Shick bosjohn@yahoo.com
bosjohn OP Veteran Member • Posts: 4,890
Re: Looking Up
any input is appreciated
DavidGBK Senior Member • Posts: 1,062
Re: Looking Up
I did look at this one but do not really know what to say.
There is maybe too much, with no clear subject, perhaps a simpler "looking up" composition would work better. Just my thoughts.
Regards
David
Re: Looking Up
thanks for your response. I appreciate your input. It seem you want a stronger subject which makes sense. thanks
David28 Veteran Member • Posts: 3,071
Re: Looking Up
Just a thought. If you rotated the image a little clockwise so the dominant branch is emerging from  the left corner, may add something.
Secondly, try cloning out the  intruding second tree bottom right so the image is cleaner and stronger (your expressed sentiments in response to the other poster).  Ok, I'm just kidding.
David
Re: Looking Up
thanks for you advice I will check it out.
