RX10 Long Exposure
Started Dec 11, 2013 | Discussions
jameswyatt
jameswyatt Regular Member • Posts: 169
RX10 Long Exposure
I'm just getting in to long exposures.  This is one of my first attempts.  I had a great subject but obviously I need more practice.
 jameswyatt's gear list:jameswyatt's gear list
Sony Cyber-shot DSC-RX10 Panasonic Lumix DMC-FZ1000 Sony a77 II Sony DT 18-250mm F3.5-6.3 Sony 70-300mm F4.5-5.6 G SSM +1 more
Biological_Viewfinder
Biological_Viewfinder Senior Member • Posts: 1,853
Re: RX10 Long Exposure
It looks funny to me.
I would suggest that you try f/6.3, ISO-400, connected to a remote using Bulb for about 60 seconds.
The reasoning here is that all lenses, including the $2000 full-frame f/2.8 lenses have "a sweet spot", and this is typically at around f/6.3 and everything should be sharper.
The remote will get your hands off the camera and it also allows you to shoot past 30 seconds. This is quite useful because starting with an aggressive ISO brings distortion in faster. Usually lots of distortion isn't as uniform as when ISO noise is less chaotic.
Think of ISO as a volume control on a stereo system; it doesn't take long for it to get too loud and once it does, there is so much distortion that tonal clarity is gone and whole sections of the sound spectrum begin to sound more and more like only noise instead of music.
If you start with a less distorted version and enhance it by time instead, then the distortion (noise) should be less obvious and in some cases nice enough to be viewed as a texture rather than a problem. In other cases noise can be reduced enough so that an image is acceptable.
A little controlled distortion is okay. We distort our pictures anytime we post-process them. As long as we don't take it too far, the result is more pleasing than the camera's original output.
There are 10 types of people in this world, those who understand binary and those who don't.
elliottnewcomb
elliottnewcomb Forum Pro • Posts: 10,460
Keep going, you do all the work, I get to learn something about it, I never tried it either.
Curious, why that focal length? Was that for the end of the pier?
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX100 Sony RX1R Olympus Stylus 1 Sony Cyber-shot DSC-RX100 III +1 more
Bejersey
Bejersey Forum Pro • Posts: 12,198
Set the RX10 at the lowest ISO
If you are using a tripod or other ways to secure the camera it's best to set the iso to 80.
Rick
elliottnewcomb
Re: Set the RX10 at the lowest ISO
Rick
Even with a tripod, I use self timer to avoid shutter button shake.
And, you can use the flash, cut it's strength way back, (menu, camera, pg 3, flash comp) and pull it back with your finger if you want to bounce it. Maybe to get a little light on more of the front of the decorations, Wait between shots, it needs a bit of time to recharge due to the small battery, otherwise, the flash strength will not be consistent.
Elliott
jameswyatt
jameswyatt OP Regular Member • Posts: 169
Great advice all.  I really like thinking of ISO as volume on a radio (nice).  After the fact I was also thinking that I should have opened the aperture more and used the ND filter if it was needed.  I used the long focal to catch stars and airplanes.
Also, any zoom lens has sweet spots as well. But this is more difficult to nail down. Some lenses are great only on 1 end, some like the Nikon 18-200mm are good at both ends but terrible from the middle toward the tele. Some like the Nikon 70-300mm are soft at the long end.
Until this lens is tested more, we won't know what it's strong and weak focal lengths are at. My guess was that you would be okay with your chosen focal length.
I would like to see you try this again James.
elliottnewcomb
I read here that focusing on infinity/stars can be problematic, full zoom might not give good focus. As you have a tripod, and framing is not too exact, I would think Manual Focus would be the sure thing if something in the sky is bright enough.
others?
Elliott
others?
You're right. Ideally, get out there during or before twilight, so you can set up your focus while you can still see the camera. You could use a flashlight, but believe me when I say that it's just easier to get it right before dusk is done. Then set it for manual focus and leave it alone.
If you're already out in the dark, then it would be nice to know if just-before-infinity works well enough. That's been my experience, but I'll have to see if the Rx10 behaves the same.
jameswyatt
A couple more attempts.
Re: A couple more attempts.
Thanks James. These are lots better.
I'm a bit concerned about the blue halos around the lights. The effect makes it look sort of like a negative or anti-light or something.
But that noise is back in control again. I just read a B&H purchase review where the photographer had the large noise you had on your original posted image; so I am relieved that you could adjust it out.
MingTyh Maa
MingTyh Maa Regular Member • Posts: 143
For a long exposure on AV, why does the RX10 not allow a shutter speed slower than 8 sec?  I have to go to full manual to set a shutter speed slower than 8 sec.
 MingTyh Maa's gear list:MingTyh Maa's gear list
Olympus OM-D E-M5 Sony Alpha 7 Sony Alpha 7R II Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Sony FE 35mm F2.8 +6 more
nannyg
nannyg Contributing Member • Posts: 741
For night-time shots you will see some star trails after about 15 seconds on close inspection & after about 30 seconds it becomes obvious. So if you want to avoid that, you will have to adjust your aperture and ISO to keep the shutter speed under about 15-20 seconds.
elliottnewcomb
The Halo's of stationary objects? You might want them, but if you don't: Are you turning Steady Shot OFF for tripod shots, and starting with self timer shutter activation to avoid initial shake? Was it windy? On a bridge that moves? My tripod has a hook for extra weight to stabilize it for long shots, never tried it. You can fill a gallon bottle with water, dirt, whatever you can figure out to hook on there for stability.
Elliott
