Is this noise normal for 5D III at ISO 2500?
Started Dec 11, 2013 | Questions
JAG007 Regular Member • Posts: 130
I have taken delivery of my 5D III and one of the reasons I bought the camera was improved low light performance over my 7D.  Am I being unreasonable to expect less noise in this image, shot at 1/160, f4.5 and ISO 2500?
 JAG007's gear list:JAG007's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 70-200mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 100-400mm F4.5-5.6L IS II +3 more
Canon EOS 5D Canon EOS 7D
cpkuntz
cpkuntz Senior Member • Posts: 1,003
Re: Is this noise normal for 5D III at ISO 2500?
2500 should be pretty clean.  It's hard for me to see the noise in your image because it has been downsized before uploading.  Try uploading the original image so we can view it at 100%.
This was at ISO 4000, and it's fairly clean.  I did some color noise reduction but luminance noise was untouched.  A lot of detail is still visible.  Is this the level of noise you see in your image?  If so, I'd say that's normal.  The 5D Mark III is no 6D or 1DX (not to mention D4/Df), but it's certainly better than the 7D.
Marquee Regular Member • Posts: 167
Looking at the image supplied, the noise looks to be reasonable for ISO 2500. For forum members to make a better appraisal you will need to post a crop of an area you think looks too noisy at 100% of native file resolution, Regards, Mark
 Marquee's gear list:Marquee's gear list
Canon EOS 5D Mark III Canon EF 100mm f/2.0 USM Canon Extender EF 1.4x II Sigma 50mm F2.8 EX DG Macro Canon TS-E 24mm f/3.5L II +2 more
Rick Knepper Forum Pro • Posts: 13,215
The noise looks fine (in this severely downsized image). I'd be more concerned about not having obtained a sharp pic, perhaps a faster shutter speed or smaller aperture or stablizing the camera better or you are using one shot with a moving target approaching the camera, etc.
Rick Knepper, photographer, non-professional, shooting for pleasure, check my profile for gear list and philosophy. Just say NO! to MAIL-IN REBATES.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R +2 more
Marx81
Marx81 Regular Member • Posts: 432
 Marx81's gear list:Marx81's gear list
Fujifilm FinePix X100 Canon EOS 400D Canon EOS 5D Mark III Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM +3 more
leroyvanhee Senior Member • Posts: 1,828
IMO it's not only important to compare noise at 100% zoom but to look at solid color areas and to assure in-camera and RAW conversion noise reduction is turned off. Here's such a sample of 6D noise at ISO 3200.
qianp2k Forum Pro • Posts: 10,350
I don't see much noise in this photo but a bit soft as Rick said.  ISO 2500 is not much for 5D3.  With appropriate NR, you should get pretty clean photo.
This one was taken at ISO 5000 in wildlife.
ISO 5000
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R +20 more
SeaScout851 Veteran Member • Posts: 6,195
I have a 7d which I have had since Oct of 2010.  I've done a lot of shooting at 1600 ISO and a little at 3200 ISO.  Like yourself I was wanting better high ISO performance.  Just one week ago I purchased a 5DIII.  I'm finding that the 5d III at 3200 is still much cleaner than the 7d at 1600.  You may need to adjust some settings.
Andy
shalou
shalou New Member • Posts: 7
I don't see a noise problem I see a focus problem.
curlyone
curlyone Regular Member • Posts: 469
I thought image looked flat, lacking contrast, i made a minor adjustment in p/shop  cs5  [levels]  this is the result.
shalou
No that is not noise it is bad focus. Perhaps soft are missed focus but not noise. I shot in 3600 for the first time thinking these are going to be awful but when I got home to look at them the were not bad at all. The 5D3 is capable of much higher iso settings before it will become noisy.
Cyl3X Regular Member • Posts: 102
For sure that is possible, I even have noise att ISO 800 with the 1DX if i put noise reduction off in the camera.
