Is there any ttl radio flash trigger for Pentax?
Started Dec 11, 2013 | Questions
soheil
soheil Senior Member • Posts: 2,581
If not, what radio flash trigger to use my studio strobes with K5/K3 ? For now, I'm using the synch cord but it's a little bit limiting.
Soheil
It's the singer not the song.
 soheil's gear list:soheil's gear list
Pentax Optio 330GS Pentax MX-1 Pentax K-7 Pentax K-5 Pentax K-5 IIs +19 more
Pentax K-5
UtahManSir
UtahManSir Veteran Member • Posts: 4,645
Re: Is there any ttl radio flash trigger for Pentax?
I don't know about TTL, but the Yongnuo RF-602 triggers work great for me for speedlights, and the RF-603 series is supposed to be just a little bit better, best of all they are cheap to experiment with.
Best of luck!
Lloyd
“For every problem there is a solution which is simple, clean and wrong.” Henry Louis Mencken
http://lloydshell.blogspot.com/
http://lloydshell.zenfolio.com/
WSSA #354
http://lloydshell.zenfolio.com/img/s3/v41/p234497562-3.jpg
walgarch
walgarch Regular Member • Posts: 138
These are the only ones I've found. They don't work like regular triggers though so you might want to check out reviews first.
http://www.amazon.com/Aokatec-Wireless-Trigger-cameras-Speedlights/dp/B00946VPBY/ref=pd_bxgy_p_text_y
 walgarch's gear list:walgarch's gear list
Pentax K-3 Fujifilm X100S Pentax K-5 Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +7 more
kitsios_spyros
kitsios_spyros Senior Member • Posts: 1,962
Best of luck!
Lloyd
WSSA #354
If you do not need them asap wait for the 603 version ii and the 560-tx controller. It allows for manual remote flash control. They are announced and about to hit the market.
Nikon mount is compatible with Pentax hot shoe, Canon mount is not.
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Pentax K-5 II Samsung NX300 Pentax K-3 Pentax K-3 II +13 more
soheil
soheil OP Senior Member • Posts: 2,581
Kind Regards,
Spyros
I've checked the Nikon mount and although the contacts seem close the distance between the centre contact and the front right contact isn't the same and I doubt if they're compatible. I would appreciate if anyone has experience with the compatibility.
Soheil
soheil
Interesting
Thanks for your reply.
Do you know if the shoe mount is universal or it differs for each brand?
Soheil
walgarch
Re: Interesting
Yes and no... the setup is kinda weird to explain. Best watch and read the reviews
http://www.youtube.com/watch?v=-I94S9VhFsM
http://www.konraddwojak.com/2013/04/aokatec-ak-ttl-speedlightflash-trigger-short-review/
The setup is unique and is camera/flashgun independent, so any review should be helpful. I haven't tried it myself since I don't do much flash work, but from what I've heard it's fairly reliable. You can also get a starter kit for about US$80 on eBay, so the buy-in isn't bad. It's been on my to-buy list for a while now, right after some LumiQuest gear
Infrabasse
Infrabasse Regular Member • Posts: 342
Kind Regards,
Spyros
Soheil
I have successfully used nikon mount youngnuo triggers on my K-5. Can't remember the model, it was either 602 or earlier. Used without issue up to 1/160, haven't tried faster.
additionnal thought: The new yongnuo flashes are GREAT as they have the wireless receiver BUILT IN. Just 1 trigger required!
You might also want to consider cactus v5 triggers, still no TTL but very feature rich.
 Infrabasse's gear list:Infrabasse's gear list
Canon PowerShot S95 Pentax K-5 Pentax Q Pentax K-30 Sigma 10-20mm F4-5.6 EX DC HSM +10 more
altis
altis Contributing Member • Posts: 831
For studio use why not just stick with an optical system? If you don't want to 'see' the flash from the camera then get an IR trigger. Plenty of old Wein SSR systems about.
Infrabasse
Just checked and it was actually a 603N that I used
kitsios_spyros
Kind Regards,
Spyros
Soheil
It is veryfied by YN-560 users in Amazon.com and the other forum
I am on my mobile, so not easy to send a link.
Google will do it for you
Kind Regards,
Spyros
soheil
Hi,
Thanks for the reply. Actually my own studio kit has the optical trigger built in. I just wanted to have the freedom to put them anywhere out side the line of sight. I wanted the ttl trigger to use my external flashes the same way and preserve the pttl function as well.
Soheil
soheil
Thanks for the info N/T
Soheil
soheil
Thanks a lot. N/T
Soheil
soheil
Thank you N/T
Soheil
