7D and usable ISO?
Started Dec 11, 2013 | Discussions
Multi-SportsMom
Multi-SportsMom Contributing Member • Posts: 595
7D and usable ISO?
What do you find is the highest ISO you can use without the photos lacking sharpness? Another season shooting indoor sports and I am disappointed once again.
My outdoor track shots don't have this issue. So I assume its the high ISO.
Most would say my photos are usable. But they still arent what i want and see of other photographers. This is my 8th year shooting and 4th digital camera. I have improved but my photos still lack pop/clarity. I shot 6400 last night in our bad lighting gym.  I lowered it to 4000-5000.  And used an aperture of 2 instead of 2.5.
Maybe its my PS skills lacking. Anyone have any unedited shots i could see?
Signed Picky Penny
 Multi-SportsMom's gear list:Multi-SportsMom's gear list
Canon EOS 7D Canon EF-S 55-250mm f/4-5.6 IS II Canon EF 100mm f/2.8 Macro USM Canon EF 135mm f/2.0L USM Canon EF 35mm f/2.0 +5 more
Canon EOS 7D
mailman88
mailman88 Veteran Member • Posts: 5,548
Re: 7D and usable ISO?
.....usable at 6400ISO and print 11x14....I can do it with my 7D.  Of course I spend a lot of time with 3 noise reduction programs and use all 3 at once. LR4, Denoise and noiseware pro
 mailman88's gear list:mailman88's gear list
Canon EOS 7D Canon EOS 30D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 28-135mm f/3.5-5.6 IS USM Canon EF 200mm f/2.8L II USM +4 more
Surb
Surb Regular Member • Posts: 208
Is it possible to use external flash and RF trigers there?  Noticed a thread not to long ago where someone placed two flashes off camera to use them remotely
 Surb's gear list:Surb's gear list
Canon EOS 5D Mark III Canon EOS 7D Canon EF 35mm f/1.4L USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 100-400mm f/4.5-5.6L IS USM +6 more
Thorbard
Thorbard Contributing Member • Posts: 688
Signed Picky Penny
I suppose it really depends how you are defining usable. Are you trying to sell the photos to the players and their families, or feature on a website or newsletter, or are you hoping to sell to glossy magazines?
There are more effects to high ISO than just noise - high ISO shots can lack general sharpness (as you have noted) but are also less contrasty and less saturated. Could you also be suffering from less-than-sharp focus or motion blur, both of which may also be characteristic of low-light photography.
At 100% noise is the most obvious fault of an image, but looking at the whole image (especially if it lacks "pop") it could be a combination of other faults. IF you are trying to sell, remember that the general public don't notice noise much!
 Thorbard's gear list:Thorbard's gear list
Canon EOS 7D Canon PowerShot G15 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 40mm f/2.8 STM Canon EF 85mm f/1.8 USM +2 more
AndyMulhearn
AndyMulhearn Regular Member • Posts: 453
For me, the subject matter and how much cropping you have to do has a big bearing on what you can get away with. If you have a noisy background, i.e. one that isn't just flat tones, then you can ignore a lot of noise that would otherwise be unsightly. Also, if you have to crop then the effect of noise can be magnified significantly.
So it really depends I'm afraid.
 AndyMulhearn's gear list:AndyMulhearn's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF 70-200mm f/4.0L USM Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +2 more
leopold
leopold Forum Pro • Posts: 13,991
ISO 800
Depends on your tolerance to noise, for me i tend not to go above ISO 800 with the 7D, above that i find it noisy, i shoot in RAW.
But i don't like noise.
 leopold's gear list:leopold's gear list
Fujifilm X-E1 Canon EOS 7D Fujifilm XF 27mm F2.8 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF 400mm f/5.6L USM +3 more
happysnapper64
happysnapper64 Senior Member • Posts: 5,156
Signed Picky Penny
Hi PP. Maybe you are just trying too hard to live up to your signature?? [only kiddin'] However it does really depend on your tolerance to noise, as others have said. I have only been shooting for 2yrs & have had the 7D for 1yr & I heard all this talk about the poor high ISO performance before I bought it. I had already owned a 600D/T3i which has the same sensor, & I was quite happy with it. I only started to really notice "noise" after joining the forum. I have used ISO 1600 on a number of occasions, I may have some of those shots in my gallery, i'm not sure, but I have snapped away while experimenting with ISO settings & viewed on my 21" monitor they seem OK to me! Maybe I am easily pleased? but as one poster said, your average buyer would probably not notice it unless it is blindingly obvious. I have gone to 6400 before I noticed a real noise intrusion, but that was viewing from a couple inches away!!
Yes, I do try & keep ISO to a minimum, of course, but I haven't [yet] seen any reason for me to get too concerned about bumping it up if need be.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I'm so fast, when I turn off the light, i'm in bed before the room gets dark" The great Mohamed Ali.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 7D Canon EOS 5D Mark II Canon EF 70-200mm f/4L IS USM Canon EF 100mm f/2.8 Macro USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +9 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 5,444
I use ISO 3200 on my 7D for basketball, with the EF 200mm F2.8L II. This gets me 1/1000 at F2.8 in Coors Events Center (the basketball arena at the University of Colorado). I shoot JPEG for sports (RAW for everything else), in camera NR set to low, and add a little NR in Lightroom afterwards (20 luminance), a little shadow and highlight recovery, a little sharpening (about 35 with a 0.6 radius), and a little clarity and vibrance boost. I apply all the settings at once to all the pictures I select to put up in the web, so it takes almost no time at all. I like the results. These aren't for selling, just for my own amusement, so perhaps my standards aren't particularly high (though I've been told by friends that the shots in the local paper aren't any better than mine). I shoot from the stands. If I could shoot from the baseline, with my 70-200 F2.8L IS II, I'm sure the results would be better. Here are some examples from the most recent game I attended, against Jackson State:
Most of these were cropped, some quite a bit. The less cropping you do, the less the noise will be visible. Shooting from the baseline with a zoom, you could cut cropping to a minimum.
Edit: I've no idea why the EXIF here doesn't show the aperture. These were all shot in manual, with aperture F2.8 and shutter 1/1000, except for one where I accidentally bumped the shutter speed down to 1/800.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon PowerShot S100 Canon PowerShot S100 (2000) Canon PowerShot S45 Canon PowerShot SD450 Canon PowerShot SD870 IS +16 more
elfroggio
elfroggio MOD Senior Member • Posts: 2,527
Wow! I do not mean to be impolite, but can we see some samples? and how did you use them?
I am almost OK at 1600, and 3200 is definitely not. I do a lot of 11x17, and some 16x20/16x24 on higer ISOs (like 1600, but mostly as 800).
http://www.sritch.com
Street Photography: The Dogs of Vancouver, BC
Multi-SportsMom
Multi-SportsMom OP Contributing Member • Posts: 595
Re: ISO 800
YES! thats my problem.  I don't sell my shots. Don't think they are good enough yet. They dont meet my standards.  I'm sure mine are better then others and I know are not as good as others.
Multi-SportsMom
Alastair
I could never shoot with thse settings around here.  I want the 70-200 lens. But Not sure I would be happy shooting 2.8 and 6400ISO.  Your photos though are the quality I'm trying for. There is just so much clearness to them. My alwyas look soft/flat or smooth as if I have already applied noise reduction. (NR disabled in camera)
Alastair Norcross
Alastair
What other settings are you using in camera (sharpness, contrast, etc.)? And what shutter speed are you using? And what do you do to them in post? It could be that a little clarity and sharpness boost is all you need. Can you post some of them, so we can see what you mean by "soft/flat or smooth"?
Alastair
Multi-SportsMom
Alastair
Alastair
Standard..sharpness 4, contrast, saturation. color tone all 0. I do apply sharpness and clarity in PS. It helps but just don't get this look.
Jerry-astro
Jerry-astro Veteran Member • Posts: 6,520
He's not kidding...
Hopefully Mailman88 will post some of his high ISO examples but he is definitely of of the real masters of NR around these parts (well, at least IMHO).  He's found a way to preserve lots of detail and eliminate noise in a way I've had a hard time duplicating on my own.  He's posted lots of ISO 3200 examples in the past and some are pretty mind boggling.
This is NOT a paid advertisement... just an admirer of his PP skills.
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Carl Zeiss Touit 2.8/12 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
steve88
steve88 Contributing Member • Posts: 905
ISO 3200 is About the Max for Me
Signed Picky Penny
I've never had much luck above 3200 ISO. I'm lucky because I shoot college volleyball in a building that's only two years-old and the lighting is very good. I can usually shoot games there around ISO's of 1600 to 2000 at the most but I've gone higher with decent results. Here are some samples (all shot with either a Canon 85mm f/1.8 lens (at f/2.8 to f/3.2) or a Canon 200mm f/2.8L lens (shot at the same apertures as the 85mm):
http://stevenmitchell.zenfolio.com/p334789359
http://stevenmitchell.zenfolio.com/p555810226
I reduce noise in Canon's DPP as well as in LR 3 and I'm pretty happy up to about 3200.  I've shot volleyball and basketball games in other gyms (mostly high schools) where the light is horrible and I'm shooting at ISO's of 5000-6400 but I've never been able to reduce the noise enough to my liking.  ISO 6400 is really pushing it on a crop sensor in terms of noise and IQ.  You might just have to live with it and accept the fact that a crop sensor can only do so much under those conditions.
You can still capture all of the drama and action of the game, however...and that's a big part of what really matters.  You just might have to accept some noise in the final images, though.
I'd really like to get a 5D3 as the full-frame sensor would help a great deal in terms of high ISO noise but I just don't want to spend that kind of money at the moment.
Anyway, I hope this has been of some help!
 steve88's gear list:steve88's gear list
Canon EOS 7D Canon EF 28mm f/1.8 USM Canon EF 85mm f/1.8 USM Canon EF 200mm f/2.8L II USM
giraffe
giraffe Senior Member • Posts: 2,381
I shoot hockey in indoor arenas with my 7D and 70-300L lens. Unfortunately sometimes I have to use ISO 6400 to freeze the action although I will always use the lowest ISO I can. I shoot in RAW and post process in photoshop. I also use noise reduction programs - my 2 favorites are Topaz denoise and imagenomic Noiseware. I find I can get decent prints up to about 8x10. The key is to ensure that your photos are properly exposed to minimize noise. I also shoot in manual mode adjusting ISO, fstop and aperture to ensure I freeze the action.
Suave
Suave Senior Member • Posts: 1,196
I could do 3200, but I hated every second of it - AF was always going haywire, PP was a pain in the neck, and still I was never happy with the outcome.
Where's my new 50, Canon?
 Suave's gear list:Suave's gear list
Olympus PEN E-PL2 Canon EOS 5D Mark III Canon EOS 700D Canon EF 50mm f/1.4 USM Canon EF 24-105mm f/4L IS USM +6 more
Multi-SportsMom
Right, even with correct exposure i'm disappointed.
Multi-SportsMom
YES that sounds like my problems too!
Alastair Norcross
I wonder what the problem is? You said that your results aren't as pleasing as mine, and I'm using 3200. Is there sensor variation in high ISO noise response?
Alastair
