sd card question
Started Dec 11, 2013 | Discussions
falconsusi Contributing Member • Posts: 560
sd card question
(I could just do this and find out, but I don't want to mess up anything.)
If I use the same memory card from my a57 to my a77 without formatting the card will the card record the next photo as the next number photo or will the memory card recognize a different camera and change the number on the photo file to whatever number is next on my camera?
I haven't labeled my sd cards and I need to know if I get them mixed up do I have to format them in the camera?  So that I can keep track of the number of photos taken with each separate camera.
Or is my question totally being misunderstood?
 falconsusi's gear list:falconsusi's gear list
Sony a77 II
Sony SLT-A57 Sony SLT-A77
alpha604 Regular Member • Posts: 243
Re: sd card question
The file structure is the same in both sony cameras.... it may ask you to rebuild the database, but unlikely unless swapping between brands or between APS-C and Full Frame. The naming scheme will continue from where it left off in my experience, regardless of the Sony camera body.
While shooting, work out a system to know which card is full or not, or dedicate a specific card to each camera. Worst case scenario, if they get mixed up just organize the files later on your computer by camera model. Alternately, if you are looking at your images on your A57, you will not be able to magnify any of the images from the A77 as they will be too high resolution for the A57 to display... identifying your A77 images, albeit not the easiest way
Just keep the cards straight and shoot, worry about it later in the computer!
 alpha604's gear list:alpha604's gear list
Sony RX1R II Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II Sony Alpha 7S II +45 more
thebustos Senior Member • Posts: 2,752
Also, if you get them mixed up, the camera used will show up in the exif data.
Good luck and happy shooting!
 thebustos's gear list:thebustos's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 50mm F1.8 SAM Sony DT 30mm F2.8 Macro SAM Sony DT 16-50mm F2.8 SSM +17 more
