X-M1 Evening in Kiev
Started Dec 11, 2013 | Photos
vivanchenko Regular Member • Posts: 224
5
Thought may be I should share this - evening in Kiev. Basically a test shot, but I liked something about it. Fuji magic? :-).
 vivanchenko's gear list:vivanchenko's gear list
Fujifilm X-M1
Comment & critique:
Fujifilm X-M1
ThachLy Regular Member • Posts: 243
Re: X-M1 Evening in Kiev
I totally agree. There is a majic to X cameras ... the colours, even in night shots, look so so cool. Perhaps that 's the ... X factor :0)
I just like the colours of this shot, perhaps needs a bit of PP.
 ThachLy's gear list:ThachLy's gear list
Fujifilm XF 60mm F2.4 R Macro Panasonic Lumix DMC-LX3 Olympus OM-D E-M5 Fujifilm X-A1 Fujifilm X-T1 +6 more
Tom Zimmer
Tom Zimmer Contributing Member • Posts: 547
It is a nice shot, and i agree there is something about it that I like. My only criticism would be that there looks like a small amount of motion blur in the image, which was probably because of the shutter speed and I am supposing it was handheld. At ISO 800 the X-E1 should have had a bit more sharpness than I see. But of course that is pixel peeping, and without doing that it looks very nice, and would probably print well. Thanks for sharing.
Tom Zimmer
http://photobubba.com/
Fuji X-E1, Sony A77
And my old friends - Sigma DP2, SD10, SD14
vivanchenko OP Regular Member • Posts: 224
Thank you all for your nice comments. ThachLy - amazing colors!
Yes, there is a fair amount of motion blur in that picture. It is not camera's fault though, it is the shooter. Had to do it on the run because I had two little evil clowns by my side whining: "daddy it has got far too cold...", "I am hungry..." and "you really, really, got us with that stupid little camera...". So, I had to do it all on the run :-).
Fujifilm X-M1
Tom Zimmer
Well, under the circumstances, that's one of the best shots I have ever seen. Truly miraculous.
I can hardly wait to see what you come up with when you have more than 5 un-interrupted seconds to turn the camera on, set it for the scene, compose and shoot.
Keep it up,
Tom Zimmer
Fuji X-E1, Sony A77
Thank you! You are very kind!
Fujifilm X-M1
Al Valentino Senior Member • Posts: 4,582
The sky and shadow areas are well exposed. Did you use the DR settings to capture this exposure range? It would seen difficult to get all that in without it. I us that function often with great success.
Fuji XE1 w/14, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
jimr Forum Pro • Posts: 11,405
Fuji colors have always been a source of  praise...
Wondering how the XA1  would  compare  image quality wise....
Yes, I believe I had DR set at 400. I also had Highlights at -2 and Shadows at -2 as well. In my experiences this settings give the best DR.
But this particular file is not an in-camera jpeg. I shot raw and then converted it to jpeg using silkypix at all default settings. I remember that I so liked the result on opening the file that I did not feel the need to change anything and I just went ahead and saved the jpeg file. That's all.
Fujifilm X-M1
1drey
1drey Senior Member • Posts: 1,408
Disappointed. I expected to see photographs of clashes with riot police from Iron Maidan
 1drey's gear list:1drey's gear list
Fujifilm X10 Fujifilm X100S Canon EOS 5D Mark II Fujifilm X-E1 Sony Alpha 7R +7 more
Here are some interesting pictures from Maidan, some of them are very touching:
http://korrespondent.net/ukraine/politics/3275719-ot-sotny-tysiach-do-myllyona-masshtabnyi-evromaidan-v-kyeve-8-dekabria#21
Some of them show the opponents (the angry, ageless ladies)
It is not Fuji though :-).
I am with all my heart with these people, but I got ill and have to stay at home for a while. Will join them later. I believe they will hold out.
Fujifilm X-M1
jm10 Senior Member • Posts: 1,744
Thanks for posting the demonstration pictures. Looks like history is being written as we speak but the outcome is not certain. Too much pre-occupation with trying to get the exact size of the crowd though...good luck to you - stay safe!
 jm10's gear list:jm10's gear list
Ricoh GR II Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
alexzn
alexzn Senior Member • Posts: 1,705
what a waste...
And this is all you were able to photograph in Kiev today?  What a waste of fine photo equipment.    I'd say go out on the streets and capture some history in the making...
Re: what a waste...
I promise I will. Will post results.
Fujifilm X-M1
Yes, agree. And thank you! You all are very kind here!
Fujifilm X-M1
alexzn
Re: what a waste...
Good luck!   I am saying it seriously.
Re: what a waste...
Thank you!
Fujifilm X-M1
