Taking too long to install firmware on EM1
Started Dec 11, 2013 | Discussions
boris Fincheltub Contributing Member • Posts: 520
Im trying to install the 1.1 firmware update on my Em1 and its being conected for 20 minutes without finishing the install, is this normal? I dont know what to do
ant previus experience??
thanks
Boris
 boris Fincheltub's gear list:boris Fincheltub's gear list
Nikon D7100 Olympus E-M1 Olympus PEN-F Olympus 12-40mm F2.8
Olympus E-M1
drj3 Veteran Member • Posts: 3,932
Re: Taking too long to install firmware on EM1
Probably depends on your internet speed.  I don't remember how long, probably less than 20 minutes.  Don't disconnect unless you are absolutely sure something is wrong and I certainly would not give up after 20 minutes. Also it may be slower if your computer is connected wireless (not recommended) instead of connected by wire to internet or it could be something causing it to be slower on the Olympus site.  Be patient.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
Torsten Hoff Veteran Member • Posts: 3,301
Another poster recently had problems that went away the instant he disabled the firewall on his PC. If you are behind a hardware firewall built into your router or modem, it should be safe to temporarily disable the PC firewall.
 Torsten Hoff's gear list:Torsten Hoff's gear list
Olympus E-3 Olympus E-300 Olympus E-510 Olympus E-5 Olympus E-M1 +14 more
Lee Beasley Senior Member • Posts: 2,389
It takes quite a while... much longer than you think it should. I just did it today through Olympus Viewer. It seems to download and write the *.bin file, then unpack and install it while the screen just sits there blankly. Eventually I got some funky graphics and then finally a big white OK showed up. I have a decent internet connection, too.
 Lee Beasley's gear list:Lee Beasley's gear list
Pentax WG-3 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +3 more
RealPancho
RealPancho Senior Member • Posts: 1,291
This is disturbing. I live in a rural area and my internet is really horrible. I haven't been able to upload to my gallery here in quite a while without doing it at work.
Frank
 RealPancho's gear list:RealPancho's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +6 more
averacpa Forum Member • Posts: 86
Hi Folks,
Just checked the Olympus website for the USA and there is no 1.1 firmware update posted for the EM-1.  My camera has 1.0.
It shows up in Olympus Viewer 3. You can't just download an Olympus firmware and install it yourself. You have to let their software do it for you.
Shashinka73 Junior Member • Posts: 29
Just did mine: about five minutes before I got the graphics on the camera's screen and around a minute and a half before the "OK". That being said my connection is pretty lightning quick.
boris Fincheltub OP Contributing Member • Posts: 520
Thanks its all done and fine
it took more than 20 minutes but all fine at the end
regards
Boris
Thanks for the response.  The Olympus website was not intuitive or straight forward to indicate that you had to install the updater before seeing the update firmware.
bimmerman Senior Member • Posts: 2,396
Both my EM-1 and EM-5 fails to update at home. Successful at Starbucks!
The Olympus Updater software tries to update for more than 20 minutes and then fails. Indicating some sort of timeout error. I then took my cameras and laptop to the nearest Starbucks and managed to update both cameras in under 10 minutes.
I'm pretty sure it's your internet connection speed. My internet speed at home is 1Mbps and it seems to be the problem. I did a internet connection speed test and my local Starbucks clocks in at around 20Mbps.
Banger
Banger Contributing Member • Posts: 592
It took some 30minutes for the update to complete for my E-M1 using OV3, which was unusual for Olympus camera updates. But I suspect it was downloading a very large file and the Olympus server (s) were overloaded with update requests.
It did complete and works fine, ....but make sure you put a newly charged battery in the camera before you start, and just wait for it to finish.
Rob
 Banger's gear list:Banger's gear list
Olympus E-30 Olympus PEN E-P3 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +6 more
Beejung Junior Member • Posts: 27
I took almost an hour. (I'm in Thailand)
 Beejung's gear list:Beejung's gear list
Olympus E-M1 Olympus 12-40mm F2.8 +1 more
