flash compensation range too small?
Started Dec 11, 2013 | Discussions
microbi
Regular MemberPosts: 136Gear list
Dec 11, 2013
hi, i own a ricoh gr for some weeks after seven year ago when i used a ricoh grd I fot the first time.
i like to take pictures with flashes, and my problem is the range of the flash compensation.
i use it in manual mode to select aperture and time to level the ambient light around -1.
then i use the internal flash, but the flash exposure is too bright.
it would be okay to a little bit overexposed if the flash light the only one.
but its not, and so i use the flash compensation at -2 and its not enough!
i would prefer a range like -3 to +1 like my dslr.
whats your operating experience and opinion?
marco.microbi
 microbi's gear list:microbi's gear list
Ricoh GR Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 24mm f/2.8D +13 more
phazelag
Senior MemberPosts: 2,996Gear list
Re: flash compensation range too small?
In reply to microbi, Dec 11, 2013
I just did some testing to confirm my suspicion on your issue.  In manual mode the camera is being told how to meter the scene or even if it is how would it know that what you expect.   I am guessing it starts at a baseline and moves up and down from there.  In using manual settings that I copied from spot metering a subject in Av Mode the FEV was week as you say.
But when I just tried it back in Aperture Priority with matching settings to manual mode and used Spot metering the flash match my scene much better and FEV minus 2 went very dark.  So I think TTL may not be used in Manual because how would it know which metering to use as you are setting the exposure not the camera.  I would have thought metering would still talk to the flash but maybe not on this camera?
Let me know if I have this wrong, but I have tested a few times now.
 phazelag's gear list:phazelag's gear list
Panasonic Lumix DMC-LF1 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Olympus E-M1 Olympus 12-40mm F2.8 +3 more
abluesky
Contributing MemberPosts: 545Gear list
In reply to phazelag, Dec 11, 2013
That is an interesting find!
 abluesky's gear list:abluesky's gear list
Ricoh GR Pentax K-01
msgf4pt5
New MemberPosts: 17Gear list
Have you tried to adjust the Manual Flash Amount setting?
Shooting menu>>>Manual Flash Amount
Play with the adjustment. You could also increase/ decrease your ISO for more/ less flash.
HTH
 msgf4pt5's gear list:msgf4pt5's gear list
Ricoh GR Olympus E-M1 Olympus E-M5 II Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +7 more
microbi
microbi OP
In reply to msgf4pt5, Dec 11, 2013
yes, this was my second choise - it works.
and i forget: flash mode was "slow".
i prefer this due the winter time and indoor shooting.
it works better in "flash on" (longest time 1/40).
i need more testing to find more regularity in the flash exposure.
marco.microbi
