How can I connect a TV to my MBPro?
Started Dec 10, 2013 | Discussions
Vernon Snider
Contributing MemberPosts: 891
Dec 10, 2013
I would like to use a TV as an external monitor for my MBPro.  What ports are needed on a TV and what cables are needed?  I am planning to get a 24" or so TV to do this and would like to be able to play DVD thru the MBPRO to the TV if desired.  Also, I'm open to suggestions for the TV brand for consideration.
Thanks for your help.
Vernon
seeblue
Senior MemberPosts: 1,399
Re: How can I connect a TV to my MBPro?
In reply to Vernon Snider, Dec 10, 2013
Year and model of MBP?
graybalanced
Veteran MemberPosts: 4,703
It's pretty straightforward. If you have a recent MacBook Pro, your Mac has Mini DisplayPort (Thunderbolt port) for video out, so one end of your cable should be Mini DisplayPort. The other end should be HDMI for your TV. Such a cable costs about $7 plus shipping at Monoprice.com, though they have them at Amazon too.
It's been possible to play DVDs from a Mac laptop to a TV for over 10 years now, so that part will be easy too. What usually confuses people is they plug in the TV and there's nothing on the screen except a blank desktop. That's because it's extending the desktop of the laptop. Just drag the DVD window over to the TV screen and go into full screen mode, and then you're set.
You can customize how any external display is connected (monitor, TV, projector...) using the Displays system preference panel.
As far as the TV, if it's only for DVD watching you can buy anything with an HDMI port on it. If it's for photo editing, you'll want one with color fidelity comparable to a computer monitor, not sure which brands that would be but you'd want to try to find some technical reviews.
james_the_first
Regular MemberPosts: 268Gear list
If you've a MBP with one of the more recent OSses then consider AppleTV - way more than a $7 cable (you'll need an HDMI cable between AppleTV box and TV) but along with a router will allow you to use your TV wirelessly (reflecting anything you do on your MBP, ipad or iphone) and mean that you can stream your films without having to muck about with plastic circles
We've not looked back since getting ours
j
graybalanced
In reply to james_the_first, Dec 10, 2013
Yes, excellent suggestion. (I haven't gotten an Apple TV yet)
Vernon Snider
In reply to seeblue, Dec 10, 2013
early 2008 MBPro
Vernon
seeblue
In reply to Vernon Snider, Dec 11, 2013
This old thread may be useful for your Mac:
http://forums.macrumors.com/showthread.php?t=792106
unknown member
(unknown member)
In reply to graybalanced, Dec 11, 2013
An Apple TV is especially awesome if you have an iOS device.
Have a Merry Christmas
