Set up af-on button and shutter button on 6d
Started Dec 10, 2013 | Discussions
tomtek1221 Regular Member • Posts: 221
What is one of the best ways to set up the AF button and shutter button on the 6D. I believe most use the AF button to meter and AF and the shutter button to only trip the shutter. If that is correct could you explain, in the menu, how to set up. Thank you
Canon EOS 6D
billythek Veteran Member • Posts: 5,258
Re: Set up af-on button and shutter button on 6d
Google "back button AF 6D".  You'll get lots of hits.  I doubt if "most" use it, but it is popular.  I made the switch a few years ago, and now it is deeply ingrained.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
VictorTrasvina
VictorTrasvina Regular Member • Posts: 161
 VictorTrasvina's gear list:VictorTrasvina's gear list
Fujifilm FinePix X100 Fujifilm X100T Canon EOS 5D Mark III
stratobill Senior Member • Posts: 1,561
YOu have it right, except that I believe the shutter button still sets exposure when used.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM Canon EF 16-35mm f/4L IS USM +1 more
