Solutions to the crap hood of the 23mm
Started Dec 10, 2013 | Discussions
zenpmd Senior Member • Posts: 1,129
Any small 3rd party ones out there a la 35mm? Thanks!
Al Valentino Senior Member • Posts: 4,664
Re: Solutions to the crap hood of the 23mm
Remember, it is only crap until the sun the gets in and ruins a shot.
Fuji XE1 w/14, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
mr moonlight Senior Member • Posts: 1,789
Just get yourself a cheap metal vented screw-on hood. It obviously won't offer the same amount of protection as the OEM one, but it still offers some protection without the size.
zenpmd OP Senior Member • Posts: 1,129
Thanks Mr Moonlight. I heard they might cause vignetting?
Asylum Photo
Asylum Photo Senior Member • Posts: 1,277
Yes, some do. You'll have to test them to see how they work for you.
My screw in hood works fine without a filter. It vignettes a little with a filter. I'm not too horribly offended by the standard hood, though.
 Asylum Photo's gear list:Asylum Photo's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R +2 more
Activatedfx Contributing Member • Posts: 905
I just got this one:
http://www.ebay.com/itm/New-Metal-Wide-Angle-62mm-Screw-in-Lens-Hood-Cap-/360810412459?pt=LH_DefaultDomain_0&hash=item5401f9f9ab
It's pretty short, about a 1/2" deep, and does NOT vignette, even on top of a slim filter. I'm not sure how much flare protection it will give - I mainly wanted it for some "front end" protection.
WT Jones Senior Member • Posts: 2,495
I agree. It also comes in handy if it is snowing! I did buy a shorter metal screw in to use as well. But I find myself using the Big Ugly one more often than not.
Warren
flbrit Veteran Member • Posts: 3,665
YM do not match mine :-)
I don't find the hood crap at all. Form follows function in my view. But hey, everyone is entitled to their own artistic opinions.
Brian
 flbrit's gear list:flbrit's gear list
Sony Alpha 7R II Carl Zeiss Distagon T* 1,4/35 ZM Canon EF 100-400mm F4.5-5.6L IS II Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +6 more
naftade Regular Member • Posts: 282
Yes, the hood is ugly. Since I kind of like flares and ghostings every once in a while, I decided just not to use it. I put on a good UV filter for protection though, which by the way offers better protection against the ever sticky fingers of my toddlers.
 naftade's gear list:naftade's gear list
Fujifilm X-E2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R
afragisk Senior Member • Posts: 1,291
Hi, does this mean that if you do not see flares or ghostings in the photo, you will bear no image degradation - in the absence of a hood ? Will it not affect colors or contrast in any way not immediately visible ? Thx.
Fuji XE-2, Canon FD 50 & 85 1.2L, Fuji 14mm 2.8, 27mm 2.8, 35mm 1.4, Bower 8mm 2.8
I really like this, good idea. Based on your experience so far, does it actually improve the quality (colors, contrast) of the photos that you can tell ?
Fuji XE-2, Canon FD 50 & 85 1.2L, Fuji 14mm 2.8, 27mm 2.8, 23mm 1.4, Bower 8mm 2.8
In most situations i do not see any difference. But this goes for all lenses with multi-coated glass I ever used. A fall off in contrast should not be noticeable in any but the brightest surroundings or (of course) when a light source is directed straight into the lens.
And there is another thing. Hoods are no magic items. They can only be as effective as they are capable of shielding the lens against stray light. Thus when using a wider angled lens the effect necessarily becomes less obvious as the hood has to be wide open in order not to vignette. Being a wide standard lens, I'd claim the 23 1.4 is not one of those lenses that practcally 'have to be used with a hood'.
Hi afragisk - I haven't really done any with or without hood testing. I bought it mostly for a little "front end" protection, as I don't like to use UV filters. My main concern was that it didn't vignette. I'm sure it's better than nothing, but obviously it's not going to be as good as the Fuji OEM hood!
pluton Senior Member • Posts: 2,794
I plan to obtain a second Fuji hood for the 23mm, and then saw off the long petals.  That way I'll have the original for maximum flare suppression, and the sawed-off unit for compact requirements.
The problem with screw-in metal hoods are:
1.  They're screw-in, and therefore interfere with filters and come closer to vignetting.  And,
2.  They're metal, which clearly offers less impact protection that pliant plastic.
I wish the hoods on all my Zeiss ZF lenses were plastic for this reason.
-KB-
 pluton's gear list:pluton's gear list
Nikon D800 Nikon D800E Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R
