D800 shutter dying?
Started Dec 10, 2013 | Discussions
imAvalanche
Regular MemberPosts: 101
D800 shutter dying?
Dec 10, 2013
Dear All,
I have this D800 with around 140k Shutter actuations, recently i have noticed something weird with the pics..
As you can see at the bottom of the pic there is this bar of darkness, it appears in many photos.. bare in mind that a SB-910 was used.. is this the shutter dying on me?
Nikon D800
Hugo First
Contributing MemberPosts: 780
Re: D800 shutter dying?
In reply to imAvalanche, Dec 10, 2013
probably not. check your flash sync speed settings. shutter speed is probably too fast...
imAvalanche
In reply to Hugo First, Dec 10, 2013
It was shot at 1/160s..
shigzeo
Senior MemberPosts: 1,637Gear list
It is possible it is just the flickering lights above causing the camera to miss-meter. I've had this happen with a D800/D4 at a basketball game. However, it looks very much like what happens when I accidentally nudge the exposure dial to 1/320. You might get it looked at if it isn't a problem with inconsistent lighting.
 shigzeo's gear list:shigzeo's gear list
Nikon D200 Nikon D800 Fujifilm X-Pro1 Sony Alpha 7R Fujifilm X-T1 +9 more
DezM
Forum ProPosts: 34,097
In reply to imAvalanche, Dec 11, 2013
You need to shoot at or below your flash sync speed. Your flash sync speed was probably slower than your shutter speed.
Marianne Oelund
Veteran MemberPosts: 5,155Gear list
Light source?
You haven't told us much that we need to know.
What was the light source for the example photo?
Does the problem occur consistently?  If not, what conditions seem to cause, or not cause it?
Is it always the lower edge of the image that is darkened?
Does the issue occur in daylight?
Qualities possessed by God in infinite proportion: Love, Grace, Power, Righteousness, Wisdom, . . .
Qualities possessed by humans in infinite proportion: Ignorance.
- Marianne
Horshack
Veteran MemberPosts: 5,731
Does it happen with every flash photo? Can you try it with the on-board flash to eliminate hot-shoe timing issues and problems with your Speedlight.
Daniel Bliss
Senior MemberPosts: 1,788Gear list
Flash firing late, or for longer than the duration of the shutter?  I'd think it's firing late, if you have 1/160th as stated.
iwannabesedated
Senior MemberPosts: 1,217Gear list
imAvalanche wrote:
Dear All,
Very interesting. Can't say for sure, but I think I may have had the same problem with my D800E. At approximately the same shutter count as you stated (140K), I started seeing dark streaks across the bottom edge of my frames. Sometimes, the streak was fairly faint. Other times, it was quite large and very dark. The problem was evident with several of my lenses, and occurred when I was shooting in broad daylight (i.e., no flash). Over time, the dark streaks got blacker and bigger.
For example, here's the shot associated with shutter actuation 140,791. Note that I was holding the camera in portrait orientation, so the right edge corresponds to what would be the bottom edge in landscape orientation. The streak is quite evident.
I sent my D800E to the Nikon Service Center in Los Angeles with an explanation of the problem and a few sample photos demonstrating the streaking. The camera was nearly 4 months out of warranty, and I was expecting a big bill. To my surprise, Nikon fixed the problem at no charge. I'm away from home and don't have the final repair invoice with me, but here's a snippet from the estimate they emailed me.
The final repair invoice which Nikon shipped back to me with my camera indicated that they had replaced the mirror box (which, I assume, must have been faulty and played some role in creating the dark streaks), along with several other parts, including the rubber grip, and, ugggh, I can't remember what else. They also checked the camera for proper focus alignment, cleaned the sensor, and cleaned out all the dust and dirt that had gotten into the camera (I shoot a lot of beach sports).
Whatever they did, my D800E looked and worked like new - no more dark streaks! And, it's worked fine after several thousand additional shutter clicks. Anyhow, that's my story. I wonder if other D800/E owners are going to have similar experiences. Regards. -iwbs
 iwannabesedated's gear list:iwannabesedated's gear list
Nikon D800E Nikon D810 Sony RX100 II Nikon D200 Nikon D300 +1 more
Bernard Delley
Contributing MemberPosts: 503Gear list
take the external flash out of the investigation
you might do test shots on a white wall (diffusely reflecting, no gloss) using the built in flash.
Beware of shading, if you are close up, or use a wide angle lens.
The manual flash power settings help to vary the flash duration : highest power (100%) makes longest flash duration. 1/250s shutter speed is the most critical setting.
NormN
Forum MemberPosts: 82
In reply to iwannabesedated, Dec 11, 2013
Same problem happen to my D800E and NPS called and told me that my camera is waiting for parts and under warranty. My shutter count is also around 140K.
I got a loaner for the time being. I guess that is a known issue to Nikon.
BTW, It is nothing related to the sync speed and flash......
imavalanche, I guess they also change the shutter.Right ?
Norm
imAvalanche
In reply to NormN, Dec 11, 2013
Hello Everyone..
I went today and shot an engagement session.. what a damn shame :'(
Every single shot had this stupid frame, i tried every single shutter speed from 1" till 1/320*FP
I have even tried using the camera's built in flash.. still the same issue..
my problem is i live in Egypt.. we have no nikon service centers here, and i am pretty sure it is a grey market camera, we never get premium stuff like these in here, i don't even know what to do, i will pay the shop i bought it from a visit and hope for the best
Until then.. my D600 all the time :/
iwannabesedated
In reply to imAvalanche, Dec 12, 2013
imAvalanche wrote:
Hello Everyone..
That ugly, black, irregularly shaped streak is EXACTLY what I was getting just before I sent my D800E in for repair. My deepest sympathy to you. -iwbs
imAvalanche
In reply to iwannabesedated, Dec 20, 2013
Okay now after receiving it from the local store.. the issue with the black bar is fixed completely.
HOWEVER..
The focusing system is screwed.. the camera is unable to autofocus on anything, no matter what it is or how i am focusing.. i can see it in the viewfinder.. the subject at the focus point is actually out of focus and when i am trying to autofocus the camera keeps hunting..
i guess they screwed something while fixing the mirror :/
Do you think this is an easy task to fix or am i screwed? i will try to get a refund for the camera but it won't be an easy task, at all..
Marianne Oelund
Who performed the service work?
In reply to imAvalanche, Dec 20, 2013
HOWEVER..
As long as Nikon or an authorized service center - or any reputable independent service center - performed the work, you should have a service warranty.  It's their responsibility to correct the issue they caused.
Sounds like the camera was re-assembled incorrectly.  Don't panic; just stand up for your rights.
- Marianne
cyclop20
Junior MemberPosts: 27
In reply to iwannabesedated, 6 months ago
Dear friend nice to read your experience. Unfortunately my D800 face the same problem yesterday, shutter count around 121k, the first failure sound is a weak shutter sound follow by screen showing ERR. The picture is dark at the bottom part. Later I check the mirror box, try clean image sensor method, and found that the mirror not lift up completely. Thus it causing the pics had black shadow at bottom.
The sub mirror arm seem had come out as I can see. That seem is causing the mirror can't lift up completely.
I've send to Nikon service centre HQ at PJ, Malaysia, now is waiting for their quote... My camera had been use for three year... I think they gonna charge me, although I don't think this is my fault, I've use my cam so careful and nvr drop it once... But it just fail in this way.
I'll update this after I got further info from Service centre.
Update 14/8/15, get the sms reply from Nikon Service Centre Malaysia, They ask for RM1013.2 to repair, didn't mention what to replace whatsoever, just a simple sms ask me want or not, lol it was so convenient. I cant reply or inquiry further bcos they are close today, so I've email some thoughts to nikon Asia and let see how. So disappointment to see a big company making multi billions a year to treat their loyalty customer in this way...
Leonard Shepherd
Forum ProPosts: 10,048Gear list
In reply to imAvalanche, 6 months ago
If it happens with no flash the problem is likely the shutter.
If it happens only with the SB910 it is almost certainly a sync issue which might be the body or the flash.
Leonard Shepherd
Often good photography is about being in the right place at the right time with the right kit and especially with the right experience.
You can buy kit. The rest is mainly down to you.
Nikon D800 Nikon D7100 Nikon D810 Nikon D750 Nikon D7200 +22 more
