A7r Imperfect E-Lens Compatibilty
Started Dec 10, 2013 | Discussions
JerryM7 New Member • Posts: 9
Just received my A7r and 35mm FE lens this week.  A great combo, with outstanding resolution and clarity at 36 Mpx.  Was pleased to see I could also use all my earlier E-lenses work on the A7r in crop mode at about same resolution as my NEX6, but with 1-stop greater ISO sensitivity.
I discovered, however, that OSS stabilization does not work on some E-lenses on the A7r.  They include Sony's 55-200mm and 16-50mm E-lenses.  OSS does work on Sony's 10-20mm and 18-200mm (old version) lenses.
Sony Alpha 7R Sony Alpha NEX-6
nevercat Senior Member • Posts: 3,193
Re: A7r Imperfect E-Lens Compatibilty
Did you tell Sony direct of this problem, I think they should adress this in a FW update (if possible)
blue_skies
blue_skies Veteran Member • Posts: 9,645
Do you see one stop advantage in crop mode? I thought that this applies only to using the entire FF sensor...
Yes, odd...
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Carl Zeiss Biogon T* 2/35 ZM +33 more
MG Nivard Junior Member • Posts: 35
This is unfortunate. I was gonna go for the ultimate low weight kit for backpacking:
A7, 55-210, 24-70 zeiss and 50mm canon FD or 55mm zeiss FE.
The cynic in me thinks this might be on purpose to drive up sales for the upcoming 70-200 f4. As I rarely use tele lenses this lens might not be for me, especially if I decide to drag it halve-way across the globe on a 6 month backpacking adventure. I would be inclined to bring the 55-210 for the occasional bird or landscape pic, OSS would obviously be a big plus.
Horshack Veteran Member • Posts: 5,803
What doesn't work?
Do you mean you can't turn OSS on when those lenses are mounted? Or that the OSS doesn't seem to be effective?
viking79
viking79 Forum Pro • Posts: 14,137
You only see any advantage using the full sensor.  Jerry might be referring to the fact the A7 offers more selectable ISO values?  The actual performance will be the same as APS-C.  It just makes for a really expensive APS-C camera  Still nice for people to use the lenses, even though I have no plans to use any of the APS-C lenses.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
JerryM7 OP New Member • Posts: 9
Re: What doesn't work?
You can't turn on OSS when those lenses are mounted.  When you try to turn on OSS the camera gives a message that OSS is not supported for that lens.  The lens also definitely behave as if there is no OSS.
The one-stop advantage of the A7r I mentioned previously is real in crop-mode (15 MPx mode), presumably because of the superior sensor in the A7r.  With a full-frame FE lens you get that same sensitivity for a full 36 MPx photo.  If you turn off the APS-C crop with an E-lens, the center of the image appears exactly the same as the APS-C on cropped image when blown up to 100%.  In my comparisons using a 10-20mm E-lens, ISO 6400 photos taken with the A7r have about the same noise as ISO 3200 photos taken on my NEX6.
Thanks, that's curious to hear.
I'll have to try this out. By the numbers the A7R's crop performance should be within spitting distance of Sony's 16MP APS-C cameras since the underlying sensor performance isn't all that different on a per-area basis. The A7R's sensor is better but it would be hard pressed to show a 1 stop advantage for the APS-C area.
Clayton1985 Veteran Member • Posts: 5,281
I would certainly expect Sony to update the FW to support all OSS lenses...   and hopefully Sony will acknowledge the issue and let us know that they plan to fix it.
viking79
Running crop mode on full frame is exactly the same as using the smaller sensor.  My guess is there is some other factor involved here (shutter speed, ISO, and aperture need to be exactly the same and should probably compare RAW or with the same JPEG settings).  You lose all benefit of full frame running in crop mode.  This is why APS-C sensors are often referred to as "crop sensors" as they are a crop of a full frame sensor.
With full frame you get added ISO performance because you use a larger sensor area so you don't need to enlarge the image as much to reach the same viewing size.  The more you enlarge the image, the more you enlarge noise and make it more obvious and the softer the image will look.
Eric
Paul1974 Junior Member • Posts: 41
I don't believe Sony overlooked this. So either you are using some faulty units or these compatibility issues are in the specs. How many units did you test and what was the reply from your seller?
ZzzooM3
ZzzooM3 Regular Member • Posts: 270
E-mount 35mm f/1.8 OSS is also supported by A7
 ZzzooM3's gear list:ZzzooM3's gear list
Canon EOS 6D Sony Alpha 7R Canon EF 70-200mm f/2.8L IS USM Sony FE 55mm F1.8 Canon EOS-1D Mark III +10 more
EinsteinsGhost
Eric
1.8 will have 1+ stop metring advantage.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sony 135mm F2.8 (T4.5) STF Sigma 70mm F2.8 EX DG Macro +12 more
PeterTX Contributing Member • Posts: 932
So does this mean that my A7 wont be able to use OSS on the 55-210 either?
That is a concern since that would have been my perfect combination for the odd occasions when I need telephoto and stabilization.
I really dont want to invest $1k for a telephoto lens for full frame.
 PeterTX's gear list:PeterTX's gear list
Sony Alpha 7S II Sony FE 24-240mm F3.5-6.3 OSS Sony FE 35mm F2.8 Sony FE 55mm F1.8
I notified Sony of the problem and received the following response:
"Thank you for contacting Sony Support.
I understand that the Steadyshot option on your A7r camera is not available when using the SEL55210 and SELP1650 lenses.
As of this time, there are 4 E-mount lenses that when used on the A7 and A7r cameras make the Steadyshot option unavailable. These are:
? SEL1855
? SEL55210
? SELP1650
? SEL18200LE
Our engineering team is still looking into these. Information with regard to a firmware update is not available yet."
So does this mean that we can look forward to a firmware upgrade to fix the issue or_
I have not owned a Sony before so no history of how they deal with issues like this.
tomtom50 Veteran Member • Posts: 3,244
15 months later, no firmware update.
I think by now we can surmise that Sony intentionally disabled OSS on cheaper lenses to "nudge" users into buying new lenses.
 tomtom50's gear list:tomtom50's gear list
Sony RX100 Sony Alpha NEX-3N Canon EOS M Sony a6000
Graham Best Veteran Member • Posts: 3,413
Another explanation. OSS doesn't work with a crop sensor lens on a full frame body.
 Graham Best's gear list:Graham Best's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha DSLR-A850 Sony Alpha 7R Sony a77 II Sony FE 55mm F1.8 +13 more
Except it does, so long as the lens is more expensive. 50mm 1.8, 35mm 1.8, 10-18 zoom, expensive 18-200... IS is fine.  IS is only disabled on the three kit lenses.
And keep in mind that Canon IS, FF or APS-C, works fine on a7x on an electronic adapter. There is nothing special about FF or APS-C, the job of len-based IS is to stabilize the image it projects.
Zenza R
Zenza R Regular Member • Posts: 186
Are they still not fully compatible? (oss)
