stellar compact macro for A7r?
Started Dec 10, 2013 | Discussions
Paul Richman
Paul Richman Veteran Member • Posts: 3,160
Any such RF lenses you'd recommend? Would like at least 1:2. Would prefer 1:1. Must have super IQ.
Paul Richman
Pixels By Paul
 Paul Richman's gear list:Paul Richman's gear list
Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +8 more
EinsteinsGhost
Re: stellar compact macro for A7r?
For compact, you will have to settle for shorter FL. Sony's native macro lens is a fee months away. If you have EA3 (or EA4), I would recommend Sigma 105mm/2.8 HSM OS on A-mount.
But of course Zeiss makro planar 100mm would be impressive.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
Paul Richman
Paul Richman OP Veteran Member • Posts: 3,160
Oseont something much more compact than those.
Paul Richman
Pixels By Paul
Paul Richman
Paul Richman
Pixels By Paul
Those first words should have been " I want ". Cell phone garbling. Sorry.
Paul Richman
Pixels By Paul
Richt2000 Senior Member • Posts: 2,900
You could look at the tamron 90mm or if you want small, how about the canon 50mm 1:2
Landscape portfolio
http://www.pbase.com/richthompson/rich_thompson___landscapes
 Richt2000's gear list:Richt2000's gear list
Sony RX100 Olympus OM-D E-M5 Sony Alpha 7R Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Canon EF 70-300mm f/4-5.6L IS USM +9 more
DavieK Contributing Member • Posts: 700
I'm using the 30mm SAM on LA-EA3. Not only is the SAM excruciatingly sharp on the A7R, it focuses to 1:1, and as a bonus is also cover the full frame as a very acceptable 30mm wide angle with a little vignetting in the extreme corners and hardly any sharpness loss - plus, super straight line geometry. Altogether unexpected.
David
Tuloom Senior Member • Posts: 1,805
Paul Richman
Pixels By Paul
Leica Macro-Elmar-M 90mm only does 1:3. I'm not aware of any RF lens that does 1:1 or even 1:2 without bellows... or Visoflex... or whatnot? Understandably, rangefinders just aren't a popular macro format.
You can mount any M lens to a Helicoil, though, for close(r) focus. This is a 50 Cron on a Hawk's Helicoil.
Lightshow
Lightshow Veteran Member • Posts: 4,501
The Elmar 90 Macro, OM 50/35 or 50/2 will probably be the smallest options, another option is diopter or close-up filters.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony Alpha 7R Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +1 more
Paul1974 Junior Member • Posts: 41
Paul Richman
Yes, I'm thinking about the Leica 90mm macro, even though it's only 1:3, and that only with its "goggles".    I'm wondering what kind of magnification I could get with this lens on either a Sony extension tube (to take the place of the "goggles" or with the helicoid.  Any idea?
Paul Richman
Pixels By Paul
Here's my lightweight set-up which uses a Pentax 50mm f/4 macro SMC screw thread (I've used extension tubes before the adaptor stage, but could use the same between the lens and adaptor). This is a relatively small light macro with exceptionally good performance.
Here's the lens reversed on bellows for 3X magnification -
This is the first shot I took with it (using the same studio flash as set up for the product images)
It is the Alpha logo from the 30mm SAM (49mm) lens cap, which I measure up as 0.5 inch here enlarged to 1.5 inch, which makes 3X. The A7R is a versatile camera but of course macro rigs are not a huge problem on any DSLR either - just a whole lot easier in the hands with a Leica-sized body.
David
jpfisher Regular Member • Posts: 262
Rangefinder glass is not known for its macro capability.
Hawk's adapter will provide a more dramatic difference in close focus with wide-angle lenses. Consider a 28mm. But you won't get the perspective that you would with a proper macro.
In the not super compact world, but fairly light and darned inexpensive, the old Micro-Nikkor 55mm f/3.5 is a good one. Just be aware that older lenses don't have coatings that modern ones do, so try to avoid backlighting.
With the e-mount you have lots and lots of options for a good 1:1 macro via an adapter. But unfortunately not a lot are rangefinder designs. Maybe Zeiss or Voigtlander will change that given the existence of the A7/A7R and live view M 240? Would certainly be nice, rangefinder coupling to 0.7m, live view after that.
Jim
http://www.pcmag.com/reviews/digital-cameras
http://www.daguerreotyping.com
 jpfisher's gear list:jpfisher's gear list
Ricoh GR Sony Cyber-shot DSC-RX10 Leica M Typ 240 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +25 more
