RX1 or x100s
Started Dec 10, 2013 | Discussions
Zaax
Regular MemberPosts: 350Gear list
Re: The X100S has a wide angle option - WCL-X100
In reply to 1drey, Dec 14, 2013
Bought recently used (X100s + converter) for $1100 - exactly the same reasoning
Seems that this combo at 28mm and f2 is noticeably less sharp, but it is not a deal breaker for me.
Actually my experience with the adapter is the exact opposite. I found that the adapter is just as sharp as the built in lens.
Zack S
Shoshin ni modoru - go back and remember the feeling of being a beginner
Flickr http://www.flickr.com/photos/10025089@N05
 Zaax's gear list:Zaax's gear list
Fujifilm FinePix X100 Sony RX100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +10 more
Graham Hill
Senior MemberPosts: 1,355Gear list
In reply to Zaax, Dec 14, 2013
Absolutely true.   I use the wide angle adapter 50% of the time or more.  There is no degradation to IQ.  At all.   Tack sharp deep into the corners.
Moondancer
Forum MemberPosts: 74
Re: RX1 or x100s
In reply to Don Mario, Dec 14, 2013
Dears
I did use the search option and I went though similar threads. However, I'm still not clear about all the pros/ cons and still can't make up my mind!
The question is: if the $$$ was not a problem, 35mm was the perfect one and you were able to sacrifice the viewfinder - which one would you pick - rx1 or x100s? And why?
Thank you for your help!
Don Mario
Have both X100 and RX1. Love using both.
So my suggestion is get both.
When I go traveling I have someone else carry one and trade with them from time to time.
1drey
Senior MemberPosts: 1,380Gear list
In reply to Graham Hill, Dec 14, 2013
It is just great!!
 1drey's gear list:1drey's gear list
Fujifilm X10 Fujifilm X100S Canon EOS 5D Mark II Fujifilm X-E1 Sony Alpha 7R +7 more
Daniel Lauring
Veteran MemberPosts: 9,010
Re: RX1 or x100s
RX1 vs. X100s initial impressions
Don Mario wrote:
Dears
Don Mario
Don Mario
New MemberPosts: 16
Re: RX1 or x100s
In reply to Moondancer, Dec 14, 2013
Imagine that you can keep only one. which one would that be?
Moondancer
Re: RX1 or x100s
In reply to Don Mario, Dec 15, 2013
For me I'd prefer X100 for its
image color tone
hybrid OVF/EVF shooting experience
looks/design/form factor
and the RX1 for
FF format sensor
So it's a simple choice for me and comes down to whether I must have a FF sensor or not.
If yes then get the RX1. If not then X100s.
It's really tough choosing between two great cameras but that's part of the fun.
LaFonte
Senior MemberPosts: 2,744Gear list
Re: RX1 or x100s
In reply to D Mac, Dec 15, 2013
D Mac wrote:
Don Mario wrote:
Dears
Don Mario
If money isn't a problem then I would suggest the A7R, full frame and has a viewfinder. But again, you could get 2 x100s for that.
I would also go with A7 + 35mm instead of RX1. The rx1 is too expensive for a limited camera (the first x100 was said to be expensive, and see how rx1 pushes the bar)
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
