Tamron 200-500mm question
Started Dec 10, 2013 | Discussions
Carl Welsby Regular Member • Posts: 138
Hi guys,
Just taken delivery of a "mint" Tamron 200-500mm lens. I have a question about manual autofocus.
When I put my A99 into MF the lens allows MF fine - my question is about how smooth the MF ring on the lens is. Mine seems to have tiny, tiny, clicks (like a thumbwheel) - is this 'correct' My others lenses such as don't have this in MF mode - they are all feel 'smooth' when the focus ring turns in MF.
Also, again in MF, there is around 1mm of play / movement before the lens ring starts to change focus. Hardly anything but I'm wondering what the tolerance should be.
Hope I'm clear on this.
Apart from this it's looking like a good lens.
Carl
 Carl Welsby's gear list:Carl Welsby's gear list
Panasonic Lumix DMC-ZS5 Sony SLT-A99 Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Tamron SP 70-300mm F/4-5.6 Di VC USD +3 more
Sony SLT-A99
Carl Welsby OP Regular Member • Posts: 138
Re: Tamron 200-500mm question
Carl Welsby wrote:
Hi guys,
Just taken delivery of a "mint" Tamron 200-500mm lens. I have a question about manual MODIFIED ****focus****.
Carl
Old Pirate Senior Member • Posts: 1,432
I no longer own that lens, but did for a number of years and mine too has a stiff manual focus ring that tended to jerk rather than turn smoothly.
With good light it took very good images.
 Old Pirate's gear list:Old Pirate's gear list
Sony Alpha 7R Sony a77 II Sony E 16mm F2.8 Pancake Sony 50mm F1.4 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +9 more
Thanks Old Pirate. I think it does make a click like a thumbwheel - someone on Dyxum confirmed it.
Hopefully CaptBob will be able to do so too.
Carl
danny006 Senior Member • Posts: 1,080
Mine has that too, nothing to be worried about. But I don't use mf with that lens, always autofocus.
www.alex-digitalpics.be by Sony
 danny006's gear list:danny006's gear list
Canon EOS 6D Canon EOS Rebel T6s Samyang 14mm F2.8 IF ED MC Aspherical Sigma 150-600mm F5-6.3 DG OS HSM | S
Thanks Danny. I'm feeling better and better. It felt too mechanical to be a fault.
Carl
