What is the point of an 85mm portrait lens vs a 135mm?
Started Dec 10, 2013 | Discussions
zenpmd Senior Member • Posts: 1,129
For me, my portraits are likely to be ad hoc, and travel orientated, where sometimes more reach is helpful, and I am sort of lusting over Fuji's upcoming 85mm equivilent as its so fast, but on the other than the 50mm equivilent would most likely do, despite not offering quite such as natural look for a face.
It seems to me the only benefit of an 85 vs a 135 is its size, and being able to use in tigher spaces, but such spaces are going to be few and far between.
135 offers more reach and shallow DoF control (although I suppose if you compare a Canon 85 1.2 and a 123 f/2 then they have roughly the same shallowness ) so maybe the only benefit of a 135 is more reach?
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,267
None, if you can't appreciate it.
One's "ways' are usually a subset of the many ways one might take on a particular subject. (The world is bigger than one person's experience of it).   In time you might tire of your habits and look to make a change in your expressions, and come to appreciate the different perspective and approach.   And if you don't, it really doesn't matter if you ever understand the difference, as long as you're happy with your approaches and results.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
dsjtecserv Veteran Member • Posts: 3,113
Re: What is the point of an 85mm portrait lens vs a 135mm?
Keep in mind the principle that on the same format, for the same subject framing and f-number, depth of field is the same. Thus the 85 set at f/2 would be equivalent to the 135 at f/2, assuming that you have framed the subject the same with each. Thus the 85 at f/1.2 would give shallower depth of field than the 135 at f/2.
Dave
 dsjtecserv's gear list:dsjtecserv's gear list
Canon EOS 5DS R Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8L Macro IS USM Canon TS-E 24mm f/3.5L II Canon EF 24-105mm f/4L IS USM +4 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 16,675
I think "reach" is the key. . .
Clearly, you should use what gives you the results you want.  However, I think the 85 makes a great portrait lens in that provides the shallow DOF and pleasing perspective without having to step back too far from the subject to acquire a nice frame filling (but not too full!) image.
From your description of what/how you shoot, this might not be much of an issue for you. But for people trying to do portraits in small rooms or studios, the 85 (or even a 60-75) might make more sense.
Life is FULL of compromise, this is just one more!
I still like soup. . .
Now that you've judged the quality of my typing, take a look at my photos. . .
http://www.flickr.com/photos/7267302@N03/
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +11 more
EinsteinsGhost
Its not just shallower DOF (one can achieve that with slower but longer lenses too). It is also about the perspective. 85mm equiv will provide a wider FOV (less compression).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
PenPix Senior Member • Posts: 2,220
+1  Sometimes you don't want the extra clutter in the background, or you have a narrow background to work with.
RhysM Senior Member • Posts: 2,211
Variety
It's just variety. Neither is tangibly better, some may prefer the perspective of 85mm some the 135mm. Some prefer to be a little further away from the person they're photographing to make them feel more at ease, some prefer to be a little closer to interact more.
digitalride New Member • Posts: 18
Dave
Many times the goal is the blurriest background, not necessarily the shallowest depth of field.   The 85 1.2 will always have a blurrier background than a 135 f/2:
http://howmuchblur.com/#compare-1x-85mm-f1.2-and-1x-135mm-f2-on-a-0.9m-wide-subject
but a 100mm f/2 is blurrier than a 50mm f/1.4 beyond 2 meters:
http://howmuchblur.com/#compare-1x-50mm-f1.4-and-1x-100mm-f2-on-a-0.9m-wide-subject
 digitalride's gear list:digitalride's gear list
Canon EOS Rebel T4i Canon EOS 70D Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 100mm f/2.8 Macro USM +1 more
zenpmd OP Senior Member • Posts: 1,129
Thanks everyone. I am still a bit confused by FOV - because surely it is the same if the composition is the same? Eg. you just stand nearer with the 85mm?
With the graphs, how to you interpret them? I don't get it! Thanks
Also, a longer focal length gives a narrower view so it can be easier to exclude distracting background elements.
Erik Magnuson Forum Pro • Posts: 12,237
No, the AOV for a lens is constant. If you move closer, you may get the same size subject but the amount of background behind the subject will be wider.   Think about what would happen if you used a 28mm (or 14mm) and stood really close to get the same framing.
Erik
 Erik Magnuson's gear list:Erik Magnuson's gear list
Canon EOS 5D Mark II Canon EOS 450D Sigma SD10 Sony Alpha NEX-5 Nikon D3200 +28 more
Thanks. I think I am starting to understand. Are there any pages showing examples of this?
MediaArchivist
MediaArchivist Senior Member • Posts: 2,709
... is the spice of life
Or at least portraits. I don't do many formal seated portraits, but I often do "ad hoc" portraits at events. I have 4 lenses for portraits (all on FF, no crop factoring):
  • 50/1.4
  • 70/2.8
  • 85/1.4
  • 135/2.8
There certainly is a difference between 50mm and 135mm, but I would not say that 50mm is "bad." For full body shots it works great, and I also have many great head shots. 85 and 135 probably have the overall best count of "great" shots, about evenly split between the two. These are completely different lenses with completely different characteristics, neither is better or worse strictly due to the focal length or any other attribute. 85mm is easier to work with if space is cramped, in other situations 135mm is better.
Is is nice to be able to provide shots from both!
Want a roXplosion!?
 MediaArchivist's gear list:MediaArchivist's gear list
Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +16 more
digitalride wrote:
Dave
Absolutely correct. I was responding to the mistaken assumption about the depth of field. And if I may add to the references:
http://www.dpreview.com/forums/post/52635436
Dave
Mark Scott Abeln Veteran Member • Posts: 7,801
Not much of a market?
I know that Nikon doesn't make a modern 135 mm prime lens, while they come out with refreshes of the 85 mm frequently.
Now the AF DC-Nikkor 135mm f/2D is a marvelous portrait lens, from what I've seen, but is rather old.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 50mm f/1.8D +1 more
joejack951 Senior Member • Posts: 2,682
Don't confuse shallow DOF with a magnified background. Long telephotos compress scenes and magnify the background and thus can blur out a distracting background better than a wider angle lens. But, for a given f-stop and subject framing (note that camera to subject distance will vary for different focal lengths to keep the framing the same), DOF is equal regardless of focal length (as has been stated already). F/1.4 at 24mm yields the same shallow DOF as f/1.4 at 85mm for a given subject framing, but the 24mm includes a much less magnified and thus less blurred background than the 85mm lens.
It should be noted that both wide apertures and long telephotos can be utilized to create subject isolation which is a combination of the DOF and background magnification in an image.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Re: Not much of a market?
The 135mm f/2 DC AF-D was introduced in 1995 just like the 85mm f/1.4 AF-D, the latter of which was only recently updated to a G lens. Nikon does not make a slower aperture version of its 135mm lens so you can't really compare refreshes comprising of both 85mm lenses (f/1.4 and f/1.8). The 85mm lenses seem to me to be a lot more popular in general which is likely why Nikon has paid more attention to them than the 135mm lens, but not by much if Nikon releases a new 135mm lens in the next year or two.
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 13,235
Rat Cheer
http://stepheneastwood.com/tutorials/lensdistortion/strippage.htm
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
chkproductions
chkproductions Senior Member • Posts: 1,054
sean000 Veteran Member • Posts: 7,156
Re: You answered your own question
You just answered your own question... at least in terms that matter most to you. There may be other pros and cons, but a big pro of the 85mm is that it's going to be smaller/lighter and easier to use in tight spaces. The advantage of the longer 135 is that it gives you a bit more reach in larger spaces (or outdoors) and will isolate the subject even more.... which you often need in outdoor spaces where you can't control the background.
Of course there are other pros and cons to each lens, depending on the two lenses you compare and your wants/needs. Keep and eye on the minimum focus distance... that's a very important metric. For example an 85mm portrait prime often has a shorter minimum focus distance than a 70-200mm f/2.8 zoom. Of course you can always stand back with the 70-200 and zoom into a longer focal length, but only if you've got the room to back up.
Sean
 sean000's gear list:sean000's gear list
Olympus Stylus XZ-10 Nikon D70 Nikon D200 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 +14 more
