My 12-35 arrived
Started Dec 10, 2013 | Discussions
Enir4
Enir4 Senior Member • Posts: 2,359
My 12-35 arrived
I used to like the 12-32, and now I could trash it. It's always the same story, the newer and greater shows the shortcomings of the older stuff. So much for walking around with my GM1 and kit 12-32. Oh well.
Enrique
 Enir4's gear list:Enir4's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Samyang 8mm F2.8 UMC Fisheye +4 more
Panasonic Lumix DMC-GM1
Chas2
Chas2 Veteran Member • Posts: 3,128
Re: My 12-35 arrived
Well then, I will take your 12-32 if you no longer want it!
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-LX5 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +18 more
Robert Deutsch
Robert Deutsch Forum Pro • Posts: 10,148
Enrique
Mmmi...Could you elaborate? Maybe share some comparison samples? The 12-35 has the extra speed, of course, with the attendant ability to keep up the ISO in low light, and the ability to have shallower DOF, but in other respects, in good light,I expect the IQs to be comparable.
Bob
 Robert Deutsch's gear list:Robert Deutsch's gear list
Olympus E-M5 II
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,040
Don't ditch the 12-32 just yet...
My somewhat similar situation is that I have the Olympus E-M5 and as standard zoom lenses I have the Panasonic 14-42X (pancake zoom lens) and the 12-40 f/2.8. Your post suggests that the 14-42X should be gathering dust. But it does not and in fact the 14-42X is on my camera most of the time because it makes for a very compact setup that I can carry just about everywhere. The 12-40 only comes out for real "shoots" that are planned. Most of the time when I just want to be ready to take a good shot of an unexpected event the 14-42X is on the camera and does an excellent job.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
Enir4
Enir4 OP Senior Member • Posts: 2,359
Deal! 700 euros and it's all yours!
Enrique
Enir4
Enrique
Bob
The 12-35 is not only much sharper, it also has more accurate colors and better rendering. They didn't put only bigger glass, but better glass. I will try to post some examples, maybe tomorrow.
Enrique
Enir4
Re: Don't ditch the 12-32 just yet...
You have a point. I can take my GM1 with the 12-32 without even noticing it.
Enrique
photofan1986
photofan1986 Senior Member • Posts: 2,773
The big 12-35 on a GM1? Doesn't that defeat the purpose of the GM1?
I would take a GX7 any day if I would like to use a large lens like this one.
To me, the GM1 makes sense with pancakes, like the 14, 20, 12-32 or at most something like the 45 1.8.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Canon PowerShot S100 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
Enir4
I agree. In fact, I have the 12-35 on my GX7.
Enrique
photofan1986
Ah ok, sorry
Don't know why I assumed you only had the GM1 as a body.
targut
targut Regular Member • Posts: 456
you mean, it has better contrast.
 targut's gear list:targut's gear list
Samsung NX200 Samsung NX2000 Panasonic Lumix DMC-GM1 Samsung NX 30mm F2 Pancake Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +4 more
Enir4
As I said, better rendering and resoltution, and more accurate colors. It's non only contrast.
Enrique
Jolly Oly
Jolly Oly Contributing Member • Posts: 978
I would much appreciate
if you could post some comparison shots @ 12mm f/3.5
No doubts 12-35 is better, but I wonder how much. An ooc jpegs will do, and a link to RAW files would be awesome
 Jolly Oly's gear list:Jolly Oly's gear list
Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Enir4
Re: I would much appreciate
I don't have an FTP site to place raw files. I guess the best I can do is posting here some comparison photos, JPEG's out of camera, maybe crops at 100%, so files are not too big. I will do it tomorrow if it's sunny, otherwise I'll wait because light changes influence too much.
Enrique
Enir4
Enrique
Bob
And I think you were right and I was wrong. This morning I put the GX7 on tripod, no IS, 2 seconds delay, both lenses at 24mm and f/4.0. Light conditions were not ideal, with low clouds passing rapidly and changing light. Still I think I can say that differences in the center are minimal, a bit bigger in the edges. This afternoon sky was finally clear, but I was out and it was very windy, so I didn't dare to change lenses. I used the 12-32 on the GM1 and the 12-35 on the GX7, both at 24mm and f/4.0. So we are comparing both, cameras and lenses, sorry about that. Even with too many variables, I think it is clear that differences between these two lenses are not at all as big as I thought.
Enrique
12-32 on GM1, 100% center crop, JPEG OOC
12-35 on GX7, 100% center crop, JPEG OOC
Advent1sam
Advent1sam Senior Member • Posts: 2,756
Enrique
Bob
Enrique
Hard to say at that angle
Robert Deutsch
They look very close--close enough that I could make either one look better than the other by minute adjustments of post-processing parameters (like the Clarity slider if opening the file in Camera Raw in Photoshop CS6).
The GM1/12-32 is about $800, whereas the 12-35 is $1200 by itself, so the 12-32 can be considered a bargain--and much easier to carry.  Still,  if you need f/2.8, there's no substitute for it.  (Well, the Olympus 12-40, but those two are close enough that the Panasonic's IS makes it preferable for those using Panasonic bodies.)
Bob
Olympus E-M5 II
duartix
duartix Veteran Member • Posts: 3,568
(...) but in other respects, in good light,I expect the IQs to be comparable.
Bob
Well, this is a real shock to me.
I know the 12-35 is weather sealed and has a 1(+)EV advantage, but everywhere else I can't see anything that justifies it's price.
Amazing performance for a kit lens!!!
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
Marcello Zini
Marcello Zini Contributing Member • Posts: 892
Enrique
Bob
Enrique
They appear to have the same color rendition which is great. The thing that gets my attention is the different SP which may show, given the same light and the same frame, the different T stop as the bigger and wider aperture glass lets in more light.
Thanks for the test, I will buy the 12-32 when it becomes easily available
...slowly building my gallery at
http://picasaweb.google.com/marcellozini
Marcello
 Marcello Zini's gear list:Marcello Zini's gear list
Fujifilm X-Pro1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XC 16-50mm F3.5-5.6 OIS Fujifilm 50-230mm +3 more
Enir4
Two more pictures from this afternoon, GM1 with the 12-32 and GX7 with the 12-35. OOC, no PP at all. Colors are more like the real thing in the photo shot with the 12-35 and GX7.
Enrique
GM1
GX7
