Help with S100 sensor
Started Dec 10, 2013 | Discussions
dave61 Regular Member • Posts: 181
I'm getting a vertical line down the RHS of the image (zoom to see). No apparent issues with lens. Is this a sensor flaw? Thanks for any advice on this.
S100
dave61 OP Regular Member • Posts: 181
Re: Help with S100 sensor
No thoughts?
Helstor Regular Member • Posts: 243
That looks more like a scratch in the wall you've photographed than any lens/sensor issue.
 Helstor's gear list:Helstor's gear list
Panasonic Lumix DMC-TS1 Canon PowerShot SX40 HS Panasonic Lumix DMC-ZS50 Canon EOS 5D Panasonic Lumix DMC-G3 +3 more
Thanks but no, the mark is consistent through all shots.
brianj Forum Pro • Posts: 14,657
It could be the sensor but equally could be the memory card.  BTW your sensor appears to be covered with fluff.
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
Steen Bay Veteran Member • Posts: 6,974
My guess is that it's the sensor. A row of pixels that becomes a curve after distortion correction. Probably too expensive to fix. You won't see it if changing the aspect ratio to 1:1.
S100
Brian
Thanks, Brian,
The fluff was probably on the blank surface  used. I'll try a different card.
