one serious and two not so questions
Started Dec 10, 2013 | Questions
Alvin R Jelen Junior Member • Posts: 42
  1. What is the difference between 4, 5, and 5+Digic processors?
  2. I'm taking pictures of running horses. What continuous fps is needed to see legs in different positions. For instance left side legs forward and then back. I have cameras that give me the choice of 3, 5, and 6.3 fps. Is 8 necessary? 3 seems to be synchronized with their gate.
  3. What is the minimum shutter speed necessary to freeze flying butterfly wings. I have 4,000 and 8,000 available. Is 4,000 fast enough?
  4. 2 and 3 above are to settle a friendly disagreement.Thanks in advance for any comments.
arj
 Alvin R Jelen's gear list:Alvin R Jelen's gear list
Canon EOS 50D Canon EOS 350D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 28-105mm f/4.0-5.6 USM Canon EF 28-135mm f/3.5-5.6 IS USM +4 more
TTMartin
TTMartin Veteran Member • Posts: 7,304
Re: one serious and two not so questions
Canon Learning Center: DIGIC Processors Explained
There are several generations of DIGIC units, distinguished by a generational number. The Canon EOS 5D Mark II has a DIGIC 4 processor. The Canon EOS 7D uses dual DIGIC 4 processors (two separate processors, working in parallel), the brand new PowerShot G1 X has a DIGIC 5, and the flagship Canon EOS-1D X comes with dual DIGIC 5+processors, along with a separate DIGIC 4 processor that is dedicated exclusively to the new 100,000 pixel RGB metering system and subject recognition. The new EOS-1D X’s RGB metering system has the same processing power as many entire EOS bodies!
Now, let’s talk about speed. A DIGIC 5 processor is approximately six times faster than DIGIC 4. A DIGIC 5+ is approximately three times faster than DIGIC 5, and 17 times faster than DIGIC 4. In terms of image quality alone, this means the processor can perform more separate calculations, on a pixel-to-pixel basis, immediately after an image is recorded. This translates into more opportunities to evaluate each image and optimize its quality before it’s even written to the memory card.
If you want a feature by feature breakdown you can go the the Canon museum. For example :
The newly developed DIGIC 6 imaging processor, also included in the PowerShot SX280 HS, offers the following improvements over the DIGIC 5.
  • Higher picture quality (higher resolution still images and improved noise reduction whether shooting still photos or movies, 60 fps frame rate for smoother, higher-quality movies)
  • Dynamic IS (Compensation for tilt distortion and distortion when shooting movies)
  • MP4 (MPEG-4) recording format in movie mode (full-HD movie frame rate: 60/30 fps)
  • Improved user-interface display screen (higher quality)
Which gait? Canter, gallop, etc?
Yes, 1/4000 is way more than enough.
arj
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
