Panasonic Lumix LX7 dash lines on over exposed areas?
Started Dec 10, 2013 | Discussions
Motonet Junior Member • Posts: 35
Hello,
I've recently bought a Lumix LX7, so far all is good except one thing. In high contrast scenes, when a spot or area is over exposed some dashed lines appear on those areas only instead of just being a really white spot. I've never seen anything like this in any small portable camera I ever had.
Any ideas if the problem is the camera or just a something inherent to the particular model?
Here are two examples, please just look at the bright spots in the sky:
http://farm8.staticflickr.com/7419/11254261805_70b6057e9b_b.jpg
http://farm8.staticflickr.com/7346/11254259255_06e3b05547_b.jpg
Thanks.
Cheers.
Panasonic Lumix DMC-LX7
AnalogJ
AnalogJ Regular Member • Posts: 473
Re: Panasonic Lumix LX7 dash lines on over exposed areas?
Hmmmmm.....very odd. I haven't seen that happen with mine.
Motonet OP Junior Member • Posts: 35
Yes, very odd. I think I will return the camera. I already tried with different apertures, ISO settings, etc, to no avail.
Thanks for your reply.
AnalogJ
I would replace it with another. it's a fantastic camera.
cainn24 Senior Member • Posts: 4,829
Then again, being punished that badly for blowing your highlights just might turn you into a better photographer!
If a blow a highlight with a mobile phone it will not add those lines. That is the point, not my skills.
It was just a bit of [attempted] humour on my part Motonet.  I wasn't criticizing your skills.
Pap38
Pap38 Veteran Member • Posts: 3,748
I think if it is blown highlights it would flash, streaks, no idea.
Pap
 Pap38's gear list:Pap38's gear list
Panasonic Lumix DMC-FZ28 Panasonic Lumix DMC-ZS8 Nikon D60 Nikon D5100
Fair enough, not that I mind being criticized, so far it's been the only way I found to learn
Cheers.
