Canon Lens/Camera/flash
Started Dec 10, 2013 | Discussions
GPasswaters New Member • Posts: 4
I'm trying to figure out what is going to be the best lens, camera, and flash to purchase.  I currently own a Canon 60D with 17-55 2.8 IS USM, 50mm 1.4, and 55-250 IS.  I have been doing mostly senior portraits, engagements, and baby/pregnancy pics.  I have started doing some wedding photos and I'm finding I'm having some issues with low lighting.  Now since I need to get a second camera body anyway I'm trying to figure out what is best.  My options that I have looked at are getting the canon 7D with a with a 430ex ii flash and just using the lenses that I have.  Next would be the 7D with the tamron 17-50 2.8 vc and no flash.  Last option I've considered is just getting another 60D and 2 430ex ii flashes and continue with the lenses I have
Canon EOS 60D Canon EOS 7D
Jeff Peterman
Jeff Peterman MOD Forum Pro • Posts: 11,885
Re: Canon Lens/Camera/flash
Why would you get the Tamron 17-50 f2.8 when you already have the Canon 17-55 f2.8? Your best bet might be to get a 600EX flash and a 430EX flash, with a good modifier/reflector or two. You could use a single flash when shooting weddings and add the second flash when setting up in more of studio situation.
BUT, if you're shooting seriously you should really consider buying a second body for backup.
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +18 more
TTMartin
TTMartin Veteran Member • Posts: 7,304
Avoid the Tamron 17-50 f/2.8 VC it uses Tamron's old focus motor, it hunts in low light. The Sigma 17-50 f/2.8 OS HSM is a better choice.
The 7D isn't going to give you significantly better low light capabilities than your 60D. It has a different control layout than your 60D. Both control layouts work equally well, but, switching back and forth between the two is awkward, and not something you want to have to think about while photographing a once in a lifetime event like a wedding.
The 60D, 70D, and 6D all share a similar control layout.
I would either get another 60D they are very in expensive now, a 70D which will give you about one more usable stop than the 60D, or ideally a 6D which will give you much better image quality, and low light capability.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
GPasswaters OP New Member • Posts: 4
Would the performance I get out of the 7D be worth the extra $400.  The reason I ask is because my father in law(best f-i-l ever) gave me the money to buy a new camera.  Originally I planned on getting the 6D but he didnt give me enough for that-not complaining though. But I have enough to either get the 7D with the 430ex II flash or the 60D with a 600ex-rt and 430 ex II flashes.  I dont want to be short sighted and get the 60D if the 7D is going to be way better just because I would be able to get an extra flash now.
thanks, I just wrote a different response/question to another reply asking all the questions you just answered lol.
TTMartin
Personally I would skip the 600EX/RT flash and get 3 430EX flashes instead of one of each.
Especially at receptions, you can set up a couple flashes on stands to bounce off the ceiling and trigger them remotely, for more even lighting.
Jeff Peterman
The advantage of the 7D is that it is more rugged and it is very good at focusing/tracking moving subjects. But from what you've said about your shooting, neither one of those matters to you. Why pay for features that won't matter? But consider the 70D if you can - it is better for your type of shooting than either of those other bodies, but not as good as a 6D.
Ok so I should probably lean more towards the 70D because, correct me if I'm wrong, my 17-55 will not work with the 6D because it is a full frame camera and that lens is from the ef-s line.
TTMartin
That is correct.
The 70D is a great camera, and a big step up from the 60D.
BAK Forum Pro • Posts: 20,690
double check commander mode.
You'll need a camera body that will send commander flash signals to a 430EX flash.
Make sure the camera is capable.
BAK
Jeff Peterman
Re: double check commander mode.
True if you want the camera flash to trigger off-camera flash modules. Can the 430EX act as a master unit? If not, the this becomes critical unless a 580EX or 600EX are bought for on-camera use.
TTMartin
The 430EX can not act as a master flash, but, the built in flash on the 60D and 70D can.
MarshallG
MarshallG Veteran Member • Posts: 3,384
You need better flash
Your 60D is perfectly capable, and so are your lenses. But you have no lighting.
I own the 430 EX II flash. It is excellent, but not great. The main deficiency is that it is not as powerful as the 580 or 600. The reason power matters is because, if you do event photography, you will most likely use one flash, on camera, with a diffuser and bounce. This causes the flash to output about 4x more light than a direct-forward flash. While this is no problem for the 430, what happens next is: Recycle time gets very long on the 430, and overheating can occur. The recycling can be a big problem if you're trying to take many consecutive photos. For this reason, your "event" flash should be the 600EX.
For portrait photography, the situation is different: The standard is to use two or three flashes to professionally light a portrait. Of course, these flashes are off-camera: one to the left, one to the right, and one behind the subject. A nice thing about the Canon Speedlight system is that your built-in flash can control the three off-camera flashes. This "optical slave" system works pretty well, but if you don't position the flashes correctly, they may not see the trigger light. It also fires a dim flash from the camera, which you might not want (reflections, etc) But I use this method and it gets the job done. People who haven't used it don't understand how great it is: You can adjust the light output of each flash independently (or in groups) from the camera's menu. This is especially good if you've got the strobes inside a softbox or on an umbrella.
An even better thing is that the 600EX can be controlled via radio instead of light, but this gets expensive: $500 per flash, and $325 for the radio transmitter you attach to the camera. I'm hoping that, soon, Canon adds the radio feature to lower end Speedlights (for the 2nd and 3rd flashes) and build the radio transmitter into a new camera body.
So I'd suggest that you begin with a 600EX-RT and a diffuser, and buy Syl Arena's Speedlighter's Handbook (better yet, take his seminar when he's in town).
 MarshallG's gear list:MarshallG's gear list
Canon EOS 7D Mark II Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon Extender EF 1.4x II Canon EF 70-200mm f/2.8L IS II USM +2 more
Wm. L. Senior Member • Posts: 2,166
Re: You need better flash
What he said. I have 430 and 580 flash units. Photography is capturing light. Bigger flash is more light which is the answer to problems fairly often.
FYI: My 430 and 580 are both great but the 580 power can show up in ways one might not expect - superior bounce flash performance.
 Wm. L.'s gear list:Wm. L.'s gear list
Panasonic Lumix DMC-ZS7 Olympus Tough TG-2 Canon EOS 70D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM +5 more
