Would you have gotten the same?
Started Dec 10, 2013 | Discussions
jpena
Regular MemberPosts: 366Gear list
Dec 10, 2013
Hello all,
I hate bothering people with my own particular problems but I also know I can learn so much from you. So here it is.
I attended Sunday a Christmas activity where I work and took this raw picture, unprocessed via Photoshop.
In case exif does not show, it is f/5.6, 1/160, iso 500, sony A700, with tamron 70-300@300mm. usd di.  Day was heavily cloudy, even rainy, so solar light was very low.  Ah, no flash, I was something like 30-40 feet away, I would say.
I processed it with Photoshop (levels and most likely contrast; no noise treatment) and cropped, and I got this one:
How good a job do you think I did?
Should I have pushed higher iso?
maybe shorter focal distance for a f/5, f/4.5 maybe?
is it as grainy on your monitor as on mine?
different post processing?
thanks in advance for your replies and for helping me learn.
 jpena's gear list:jpena's gear list
Sony a77 II
Sony Alpha DSLR-A700
Alan_S
Senior MemberPosts: 1,624Gear list
Re: Would you have gotten the same?
In reply to jpena, Dec 10, 2013
Hi, I think you did a fine job, nice compromise of ISO sensitivity and struck a good balance in post processing with sharpening/noise reduction. Just enough fine grain to provide detail without being overly grainy at all on my screen without pixel-peeping.
Just one note of clarification though, you labeled the first shot as raw, "unprocessed via Photoshop" (the unprocessed RAW file itself will not display as an image without some processing & conversion to an image display format)... I think what you meant was the RAW file was processed/converted to JPG in Photoshop with whatever default settings are applied (which was a bit underexposed until you applied PP adjustments in the second photo). Correct?
jpena wrote:
Hello all,
- AlanS
 Alan_S's gear list:Alan_S's gear list
Sony SLT-A99 Sony a77 II Sony 70-200mm F2.8 G Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +3 more
AlphaTikal
Senior MemberPosts: 1,847Gear list
I am on my mobile now, but it depends on what you want ll and is very personal thing. Do you just want talk about the iso and grain? What is your goal with that picture?
For the cropped one I would crop more the head below, if I wanted portrait of that woman.
· http://www.flickr.com/photos/blackhole_eater/
· (All photos are creative common licensed. Check them out.)
· English is not my native language.
 AlphaTikal's gear list:AlphaTikal's gear list
Sony RX100 Sony a77 II Sony DT 16-50mm F2.8 SSM Tamron SP 90mm F2.8 Di VC USD 1:1 Macro Sony SLT-A65 +10 more
jpena
jpena OP
In reply to Alan_S, Dec 10, 2013
Alan_S
thanks for the reply.
and yes, that is what I meant. Default values.
I may have applied light sharpening on camera raw but very lightly indeed. No noise reduction whatsoever though.
Sony a77 II
jpena
jpena OP
In reply to AlphaTikal, Dec 10, 2013
AlphaTikal,
All I want is to see if other fellow photographers would've done anything differently, what you think of my pic, combination of variables...in a nutshell, your take on my technique with this pic.
The cropped image is just for this thread's discussion's sake, nothing beyond that.
Sony a77 II
Michael Fritzen
Veteran MemberPosts: 4,418
Hi,
under these lighting and shooting conditions you left already the "comfort" or "security" zone at 1/160 and 300mm (BTW field of view of 450mm on APS-C) considering 1/FL as recommended exposure time. Shooting handheld this guards the risc of handshake. You could have increased the ISO - of course at the toll of more noise. There's no free lunch as it is the saying what means a compromise has to be found. I'd say under the given constraints I probably would have choosen similar parameters with a similar result. Perhaps I would have choosen ISO800 which is stll acceptable on the A700, always taking into account that one has a pack of capable noise reduction software at one's hand for eventually improving the result. Or one could downsize the image to the needed output resolution. So here are possible fixes. But there's none when the image is blurred due to handshake or subject move or both.
Michael Fritzen
digitalshooter
Forum ProPosts: 19,604Gear list
I would have used the flash for fill flash (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
yndesai
Regular MemberPosts: 325Gear list
Re: I would have used the flash for fill flash
In reply to digitalshooter, Dec 10, 2013
Flash is always welcome but it would flatten the image and ruin the background.
My Idea if you want to exploit same light.
1. Use a stand
2. I would use F6.3 (if 5.6 is the limit of this lens) and increase ISO to 800
3. Moving a bit close always helps if situation permits.
 yndesai's gear list:yndesai's gear list
Canon PowerShot SX130 IS Sony Alpha SLT-A58 Tamron AF 70-300mm F/4-5.6 Di LD Macro Sony DT 50mm F1.8 SAM Sony DT 18-55mm F3.5-5.6 SAM II +1 more
tbcass
Forum ProPosts: 22,548Gear list
jpena wrote:
Hello all,
That's a pretty heavy crop so flaws are likely to show up. I believe your biggest problem was the original was underexposed so when you adjusted levels the boise was also emphasized.
Tom
Look at the picture, not the pixels
Miss use of the ability to do 100% pixel peeping is the bane of digital photography because it causes people to fret over inconsequential issues.
http://www.flickr.com/photos/63683676@N07/
http://www.flickr.com/photos/25301400@N00/
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony SLT-A77 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +7 more
tbcass
In reply to tbcass, Dec 10, 2013
tbcass wrote:
jpena wrote:
Hello all,
boise=noise
Tom
Draek
Senior MemberPosts: 2,028Gear list
jpena wrote:
Hello all,
Don't; we all learn something from these kinds of discussions, not just the one asking. So feel free to ask anything you need.
Lack of eyes notwithstanding I think you did well enough -- it's somewhat noisy, certainly, but not so much it'd be bothersome in a print, and I think a longer exposure would've introduced unwanted camera shake. Colors are a bit saturated for my tastes, however, but that's more a matter of taste -- they're not garish, either. Oh, and I would've left a tad more background, as well, but it does depend on the print size you're aiming for, if one at all -- small prints and online sharing, it's best to have a tight crop to maximize the subject's apparent size.
Considering the push you did in post, perhaps. Dunno if it would've affected things much, though.
Considering the crop you did, no, you shouldn't.
Yup, but not unpleasantly so -- looks like pushed ISO400 color film, to me. I do see some posterization on her shirt, but I couldn't tell whether it's a fault of the image or my monitor, since I'm at my work computer right now.
Other than the saturation thing and a wider crop, no, I don't think I would have. As I said, the grain looks noticeable but not unpleasant, and I think it'd print well, too.
You're welcome, hope it helps
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
jpena
jpena OP
In reply to Michael Fritzen, Dec 10, 2013
Michael Fritzen wrote:
Hi,
Michael Fritzen
Michael,
One of the first settings was shooting at 1/450 or equivalent, but I would have had to raise iso. Too far away for onboard flash be of much use, I thought too. Maybe wrongly.
Again, thanks for your time and interest.
Sony a77 II
jpena
jpena OP
Re: I would have used the flash for fill flash (nt)
I deemed it to open a space and too far away for onboard flash to be any effective.
Would you have used onboard flash under these circumstances? Interesting. I will make sure I give it a try next time.
Thanks for the reply and help,
Sony a77 II
jpena
jpena OP
In reply to yndesai, Dec 10, 2013
1. Use a stand
Yndesai,
I had my tripod with me but I did not want the risk of children/people tripping over it. Nor did I want to draw attention onto me.
I could have certainly gotten a little closer but I wanted the pic to be quite incognito. I love taking unsupected pics of people.
Again, thanks,
Sony a77 II
jpena
jpena OP
tbcass wrote:
jpena wrote:
Hello all,
Tom
Tbcass,
thanks for the time and reply.
Yes, I know it was dark to begin with. But let me ask you this:
Would you have used higher iso?  onboard flash being about 30/40 feet away?
Thanks so very many,
Sony a77 II
jpena
jpena OP
In reply to Draek, Dec 10, 2013
Draek wrote:
jpena wrote:
Hello all,
Thanks Draek,
Actually, the crop was just approximate, as I wanted to show her face above all. I did not care that much for how large or small the crop is as long as she can be seen in the cropped image.
I tend to like darkish  pics which, of course, hightens the noise.
Wonderful tips, thanks,
Sony a77 II
dlkeller
Veteran MemberPosts: 6,922
It is hard for me to see the focus well without the eyes, however, my general view is the image is very soft--possibly due to motion blur.
I believe you could shoot a shot like this at 1600 with the A700 and get reasonable noise levels which could have been reduced with noise reduction in post processing.  Given a choice between exposure noise and blur I will take the exposure noise every time as you can do something with it in post processing.
You definitely need to crop the guy at the bottom, although if his eyes are of similar sharpness to hers it would reinforce what I said above even more.
Dave
Undah
Veteran MemberPosts: 5,310
Was this RAW or JPG?
Maybe I missed it in your description.
Either way, this is too noisy at iso500.
If it was RAW, adjust the noise reduction during the RAW development.
If it was JPG, the only way it would be this noisy at iso500 is if you underexposed and brightened up the dark areas.  You would still be ok but you need some noise reduction.  Try Neat Image plugin.
Hope that helps.
tbcass
jpena wrote:
Tbcass,
It depends on why the photo was under exposed. Some + EV to brighten things up would go a long way toward reducing noise. Using iso 800 could help.
Tom
MrChristopher
Senior MemberPosts: 1,287Gear list
In reply to jpena, Dec 11, 2013
jpena, we can (and will) debate ISO and exposure on this image all day long, but I think what's lacking her is good composition and context.  This is not a studio, bright light, everyone smile and say cheese photo, it's an environmental portrait so it should reflect the environment and not a cameras ability to make it look like a sunny day. You accomplished that nicely, I can feel the weather in this shot and I like it.  But I cannot determine the subject and I assume the more prominent person is the subject yet my eyes are distracted from that and here's why:
A step back and you would have gotten the third person on the bottom right in the frame  and could have cropped to a standard 8x10 and moved it so the person on the far left is completely out.  That would have given you more environment to this environmental portrait and the stairs and other lines and such would help frame the subject (three people clustered together, with the main person looking off frame) and given you a more full background.
You're trying to convert it into a head shot and that's not working with half head man on the bottom right.  It is too distracting and the cropped image lacks context.  I can't stop looking at half head man.
I think your settings were perfectly fine (others will suggest otherwise) and the image captures the sort of over cast, dreary weather nicely.  But the confusing composition renders the image mostly unusable in my opinion.  Had it been me I would have stepped back to avoid extreme cut off of 3rd guy on bottom right and gone with the three of them.  Or I would have changed my angle so I could get a tight head shot of what seems to be the main subject without the guy below him showing up (photo bombing!).
People are suggesting lightening the image, well ok fine.  I might actually darken in to amplify the mood which I think you captured well.
And eyes are a critical part of judging a photo and blackening them out in not helping your cause. Are these criminals on the lamb who require anonymity?
These are just my opinions and suggestions, and most importantly, unless you are a commercial photographer the main person you need to please is yourself.  If you like the image and it speaks to you, it's a job well done.
http://chriscurnutt.tumblr.com/
 MrChristopher's gear list:MrChristopher's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R +1 more
