Getting tack sharp photos on a canon7d
Started Dec 10, 2013 | Discussions
Jamesishere60
New MemberPosts: 5
Dec 10, 2013
Using a 24-70 L lens on a 7d, what are proper settings for tack sharp photos.
Dougs_Photo
Regular MemberPosts: 127Gear list
Re: Getting tack sharp photos on a canon7d
In reply to Jamesishere60, Dec 10, 2013
Not really different than other cameras, Low ISO, Lighting that is not flat, Shutter speed high enough to prevent motion blur, and Focus that is spot on. This is all just basic stuff.
Doug
 Dougs_Photo's gear list:Dougs_Photo's gear list
Canon EOS 5D Mark III Canon EOS 70D Canon EOS 7D Mark II Canon EOS D30 Canon EOS 50D +28 more
BAK
BAK
Forum ProPosts: 20,367
If you change lenses to one with stabilization, use a tripod with stabilization turned off
Be careful of breeze. They make leaves shimmer.
Hot days can make the air distort your shots.
Viewing device matters - printer, tv, computer
BAK
Philip Kendall
Contributing MemberPosts: 789Gear list
To echo and often repeated theme around here: it's the photographer which gets the photo, not the settings. There are no "magic settings" which somehow make a photo sharp.
 Philip Kendall's gear list:Philip Kendall's gear list
Canon PowerShot SD1000 Canon EOS 550D Canon EF 50mm f/1.8 II Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS II
ktownbill
Senior MemberPosts: 2,190
Follow up the other posters advice by sharpening your photos with an editor.
http://digital-photography-school.com/an-introduction-to-sharpening-photos
Follow up this introductory article with one specific to your editor.
If you shoot jpeg only you can set the in-camera sharpness in the menu both by choosing "picture style" and using the sharpness slider for same. The landscape setting has the highest default sharpness setting.
An editor will assign a default sharpness setting as well.
Learn how to use masks, brushes, and layers to selectively sharpen areas of a given photo.
Bill
TTMartin
Veteran MemberPosts: 7,304Gear list
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
Austin_Luker
Contributing MemberPosts: 569
In reply to TTMartin, Dec 10, 2013
I love these posts, its like people think because they read it online and use the same settings they think they will have the same exact image. It boils down to PHOTGRAPHERS skill and knowledge of different aspects of the sport that all come into play to make a clean, sharp image.
AustinLuker.com
7D-5DMKII-1DMKIV
MarshallG
Veteran MemberPosts: 3,340Gear list
James,
It really depends on what you're shooting. If you have some photos that came out soft, why not post them here? Or explain the type of photo you took and what didn't work.
For example, if I want maximum sharpness, I put the camera on a GOOD tripod, I focus using LiveView at 10x, and I use a remote release. But if you're photographing people, that won't work, because you usually can't have a tripod. So for people, I use single point AF and I configured the joystick so I can set the AF point on the subject'a eyes without having to recompose. After I shoot, I review by zooming in on the eyebrow. When I can see each hair at full magnification, I know that the sharpness is perfect. I never get perfect focus every time.
I also MFA'd my lens, and it needed a +10.
 MarshallG's gear list:MarshallG's gear list
Canon EOS 7D Mark II Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon Extender EF 1.4x II Canon EF 70-200mm f/2.8L IS II USM +2 more
Sailor Blue
Veteran MemberPosts: 8,676Gear list
In reply to Jamesishere60, Dec 11, 2013
Doing an AF Microadjustment shouldn't be forgotten.
There are always small manufacturing variations in things like the lenses and camera body and lens mounts.  Sometimes these variations cancel each other out, sometimes they add up. AF Microadjustment allows you to zero these out so that you are getting the maximum sharpness from your lens.
This is the best way I have found to manually set the AF Microadjustment.
Bird Photographers Net - AF microadjustment tricks
This inexpensive program completely automates setting the AF Microadjustment.
Reikan Photography - Automatic AF Microadjust Calibration Software
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
elfroggio
elfroggio MOD
Senior MemberPosts: 2,491
7d, f/4.5, iso 1600 70-200 @ 186mm handheld @ 1/80s
To see it very sharp, you need to see the full size. DPR doesn't do a good job in the shrinking process.
The first thing, you need to realize that sharpness is an optical "illusion". Light makes a huge difference, the more at an angle, the better the sharpness (same as for landscape at early mornings/later afternoons).
The low DOF and the contrating colors help a lot.
BTW, there is also some PP in Lightroom: clarity: +30
http://www.sritch.com
Street Photography: The Dogs of Vancouver, BC
