question about image that you get from a 8mm fisheye on a full frame
Started Dec 10, 2013 | Questions
RoxanneY Contributing Member • Posts: 641
Hi!
So I've recently become obsessed with the coolness of fisheye pics and my hubby says that he'll get me one for my Christmas present, but that I have to tell him exactly which one to get.
Can someone tell me if my a99 will give me a fully circular image if I choose a Rokinon/Bower 8mm fisheye without a hood?  I've been reading around and someone mentioned that it is "nearly" a circular image which is not what I want.
I'm also considering asking for a 16mm since it's been so highly touted here, but I really would rather have a fully circular image.
Thanks all in advance for your help!
Roxanne
Sony SLT-A99
RoxanneY OP Contributing Member • Posts: 641
Re: question about image that you get from a 8mm fisheye on a full frame
Also I would love to have a get an F2.8 if possible and see that these are only being made for the E mounts.  Should I consider this using a A to E mount adapter?
Any recommendations on the best or better one to get/do would be appreciated.
Thanks!
Roxanne
falconsusi Contributing Member • Posts: 560
The Sigma 8mm fisheye is reported to give a full circular image on full-frame. Reports say it is not fully circular on cropped cameras.
I don't have a full-frame camera, but I do have a full circular fisheye and a diagonal fisheye for my cropped cameras. You might hear several people who prefer diagonal fisheyes, but I love having the full circular image.
Go for it! The circular fisheye I own is actually an adapter for my Sigma 18-250 that I bought with the filter adapter for under $50. Used at exclusively 18mm it produces full circle images. I use it way more than my Sigma 10mm diagonal fisheye.
 falconsusi's gear list:falconsusi's gear list
Sony a77 II
IanML Senior Member • Posts: 1,647
Your camera is an A-mount. It is not possible to make an adapter for E-mount lenses to be used on A-mount without inclusion of an extra lens system, which is why such an adapter is not available.
The reverse, i.e. an adapter to use A-mount lenses  on E-Mount, is not a problem, and there are plenty to choose from.  You may have been confused by these.
Ian
 IanML's gear list:IanML's gear list
Sony SLT-A33 Sony Alpha NEX-5N Sony SLT-A57 Sony a77 II +1 more
alanlinde
alanlinde Regular Member • Posts: 300
Please see this thread:
http://www.dpreview.com/forums/thread/3580236
Alan
MediaArchivist
MediaArchivist Senior Member • Posts: 2,585
Another thread
 MediaArchivist's gear list:MediaArchivist's gear list
Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +16 more
Thanks Falcon!
I don't think we want to spend quite that much on it since it is just for fun.  Can I assume that the Rokinon 8mm would perform much like the Sigma 8mm?
Roxanne
MediaArchivist
Sigma 8mm?
Sigma no longer makes an 8mm fisheye for the A-mount, do you mean for the E-mount (or 10mm)?
Check out the full list of what's available here, there are plenty of sample photos from many different A-mount cameras:
Dyxum index of fixed focal A-mount lenses
Want a roXplosion!?
Ian
Thanks Ian!
I was confused.
Roxanne
Alan
Thanks Alan!
A picture is worth a thousand words.  The Rokinon 8mm fisheye does not give a fully circular image.  I guess the only way to get one is to cut it out in photoshop.
Roxanne
Re: Sigma 8mm?
Want a roXplosion!?
Hi MediaArchivist!
I found this:
http://www.sigmaphoto.com/product/8mm-f35-ex-dg-circular-fisheye
Thanks for the Dyxum link!
Roxanne
Re: Sigma 8mm?
Want a roXplosion!?
Hi MediaArchivist!
I found this:
Roxanne
oops, wrong mount.  guess Rokinon is my only option.
RussAdams Contributing Member • Posts: 831
Advantage of Rokinon/Samyang is it's rectilinear format
Roxanne
Hi Roxanne:
The Rokinon is a rectilinear fisheye. You will not see as much distortion as with a classic Fisheye.
If you are looking for that really distorted look the Rokinon/Samyang does not quite go there.
The *advantage* of the Rokinon is the ability to adjust (in post processing) the resulting image so it comes out with a 'normal' perspective. So you can get super wide angle shots without the really odd perspective.
Ken Rockwell reviews the lens here:
http://www.kenrockwell.com/tech/8mm-f35.htm
It can be used to really good effect. But not that really round ball fisheye.
I truly enjoy my copy. And it's slightly bigger brother the 14mm Samyang.
A77 though, not FF.
Russ
 RussAdams's gear list:RussAdams's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 Sony a77 II
Re: Advantage of Rokinon/Samyang is it's rectilinear format
RussAdams wrote:
Roxanne
Hi Roxanne:
A77 though, not FF.
Russ
Thank you Russ!
I guess I'll give it a try.  I think it will be fun enough.
Roxanne
MediaArchivist
I think the correct term is stereographic?
http://photoropter.berlios.de/phtrdoc/techback_geom.html
Whatever the term, I agree it is a more "even" projection. The edges are not squished as much.
Want a roXplosion!?
Re: I think the correct term is stereographic?
Want a roXplosion!?
Ah, so the Peleng is a truer fisheye than the Rokinon.
Thanks MediaArchivist!!!
MikeInOr
MikeInOr Contributing Member • Posts: 795
I loved playing with fisheye effects way back when I used to shoot film on my Maxxum 7000. I bought one of those .42x wide angle extension lenses that screws into the filter threads of pretty much any lens.
Originally I put the .42x extension on my 50mm 1.8 which does not cause a fisheye effect. I liked the wide angle capability of this combo so much I bought a 24mm prime lens. Then I decided to put the .42x on the 24mm lens and the combo made a beautiful fisheye effect. When I picked up a 24-70 zoom I put the .42 extension on it and had a bit of a zoomable fisheye. All for about $50 for the .42x extension.
Just a thought on a way to get a really cheap way to get a fisheye lens. Fisheyes are fun to play with but I found I would never use one enough to invest serious money in one.
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A33 Sony SLT-A77 Sony DT 55-300mm F4.5-5.6 SAM Sony 20mm F2.8 Sigma 30mm F1.4 EX DC HSM +5 more
Dave Oddie Veteran Member • Posts: 3,997
According to this you are out of luck.
http://www.dyxum.com/lenses/results.asp?chbLensType=1
All the 8mm full frame fisheye's are out of production. Looks like only Sigma ever made a circular fisheye for full frame A mount cameras.
The 8mm Samyangs are aps-c diagonal fisheye lenses so I assume that would not give a full circle on full frame. Looking at their web site here
http://www.samyang-lens.co.uk/samyang-8mm-f35-fisheye-csii-dh-lens.html
It says:
On Full frame cameras, it produces a vignetted image, which is almost circular with the lens hood detached.
So it is not a true circular fish eye on FF
add on lens
This is what I use on my cropped camera. Zeikos 0.18x fish eye adapter .
Roxanne - I noticed you have the a550 and an 18-55 lens. With the adapter above selling for $37 at amazon you could know cheaply if a more expensive fish eye is what you want. Or you could just have cheap fun with this combo. To give you the circular image you will need to be able to keep your lens at 18mm. You will also need a 55 to 58mm step up ring which can be bought for $3 on ebay 55-58 step up ring
Here are a few old examples of me using this adapter on my 18-250 lens
Unedited straight from camera. I love fish eye portraits. Me and my mom on the blue ridge parkway in the rain.
Fairly sharp. Edges not bad. This pic is edited around the edges to not show the lens barrel (see above photo)
Skin sharpening and other stuff. Fun fish eye face! Me
Just to show some distortion
Sort of edited in photoshop. I like lens flare so I kept it in this photo when I edited it to get rid of most of the barrel.
Not bad for a cheap adapter!
You have reminded me of how much fun I have with this lens. I have to get it out again soon.
Sony a77 II
Renato1 Veteran Member • Posts: 3,324
8mm Peleng Lens
Maybe what you are after is the 8mm true fisheye Peleng lens which is also reviewed at Dyxum
http://www.dyxum.com/columns/articles/lenses/peleng/peleng_8mm_fisheye_review.asp
It is sold all the time on Ebay. Though I wasn't that pleased with the M42 adapter that came with it, and I sand papered it down to make it thinner and the lens closer to the camera. And you have to remember to set the camera to work without a lens attached, since it doesn't recognise that a lens is attached.
Believe it or not I have the Peleng lens and I have the A900, but I cannot really answer your question as I've never tried using the two together. This is mainly because I've been using Nikon fisheye adapters on my point and shoot cameras for the nice circular fisheye images.
Main problem with the lens in APS cameras was that images at the dark edges were never sharp, and there might be some internal refelection there as well. But this was easily fixed by cropping. Just use the ellipse tool in Photoshop or Photoshop Elements. It is usually the alternate to the rectangle tool, where pressing the Shift key limits the tool to drawing circles or squares.
Just cut the circular image out (leaving off the edge distortions) and paste it into a prepared blank image of a certain size.
One advantage of having a true fisheye lens is that you can get programs which let you unwrap them into standard photos if you should want to (not that I ever wanted to).
Renato
