Powershot S110 and Lightroom questions
Started Dec 10, 2013 | Discussions
BlueGreenRed New Member • Posts: 2
So when I view the raw files from this camera in a regular picture viewer the distortion is pretty bad, but when I import to Lightroom all of a sudden they're fixed, without any lens profile correction selected, why is that?
Lightroom makes improvements but I'm not sure which is the best, most accurate (to the native camera jpeg) I should pick?
So which should I pick?
Camera profile: Camera standard or Adobe standard?
Lens profile: no lens correction or S100 lens profile?
Canon PowerShot S110
FrankieJ
FrankieJ Senior Member • Posts: 1,551
Re: Powershot S110 and Lightroom questions
Because it's automatic based on camera exif ID.
camera standard is closer to camera's jpeg engine output, BUT both are an interpretations, neither should be thought of as accurate. get a color checker passport and increase your hands-on involvement in RAW post-production if you want accurate.
Perhaps you can try both and see which you prefer then share your results here with us?
You use the word "should" a lot. I understand wanting to receive some guidance in matters where you are not experienced but there is no Should in photography, it's an art form with few firm rules as to what is right. Try different things and see what feels right to you.
philzucker Veteran Member • Posts: 7,629
Answers - and questions of my own
BlueGreenRed wrote:
[...] Lightroom makes improvements but I'm not sure which is the best, most accurate (to the native camera jpeg) I should pick?
I'm resurrecting this thread because I've acquired a used S110 myself and now am asking myself about the same questions - and also some others.
First my answer to one of the questions of the OP:
Lens profile: "No lens correction" is the correct answer here, because the S110 has lens correction information embedded in its CR2 files, and those are automatically applied while importing the RAWs into Lightroom 5.4 or ACR 8.4. The latter states this explicitly, BTW.
But now for the IMO more complicated question:
Camera calibration profile: This is the question I'm asking myself. The Adobe profile renders considerably warmer colors (much too warm IMO) than the S110's JPG engine does (I tested this with some shots made with RAW+JPEG mode). The "Camera neutral" profile is a very subdued profile I don't like to have as a starting point for RAW editing - it's much to flat for my taste, and I don't want to correct saturation and dynamics for every single pic.
The "Camera standard" profile comes closest to the in camera JPG rendering, but it still warmer and a bit punchier, especially in the reds. Because of that I tweaked the Primary Reds a bit to my liking, added some sharpening (didn't want to overdo it here, the S110 default JPG sharpening is a bit too much for my taste), and arrived at these new default settings for RAW import into LR 5.4:
  • Camera profile: Camera standard with Red Primary corrections as follows: Hue -5, Saturation -14.
  • Sharpening: Amount 50, Masking 20
  • All other parameters at their default values.
I'd like to know your experiences / default values for the import of the S110's CR2's into LR5. Any input would be much appreciated!
Phil
Re: Answers - and questions of my own
Refined that a bit for a more overall pleasing appearance.
Starting point still is the "Camera Standard" camera calibration profile - with these alterations:
  • Red Primary: Hue = 0, Saturation = -7
  • Green Primary: Hue = +46, Saturation = 0
  • Blue Primary: Hue = +13, Saturation = 0
Any thoughts?
Phil
