Best for Monitor Calibration AND icc Profile Creation?
Started Dec 10, 2013 | Discussions
Havanai Forum Member • Posts: 62
These questions have been on my mind for some time, but I am about to buy a new printer and now they are more urgent. Over the years, I have had two outside services create icc printer profiles for my printer and the papers I use. But they are both out of business now. In my experience, the profiles I have had custom made have yielded better results than the profiles provided by the paper manufacturers. So, I now would like to buy one of the calibrating packages that will calibrate my monitor AND enable me to create icc profiles for my printer/paper combinations.
Are there any strong reasons to select one calibration package over another? Spyder, ColorMunki, i1…what else is there? I am using an HP ZR22w monitor. My workroom has a lot of windows and, even with adjustable blinds, the light is variable during the day. It's very different in here when days are cloudy or bright. And sometimes I work at night too. If one device has a meaningful and reliable response mechanism to changing light conditions, that might be valuable to me. I am likely upgrade from an Epson 1400 to the 3880. I’ve been using HahneMuhle Bamboo and Inkpress Luster papers. I’d like to try some others, maybe from Red River or Canson, or some of the Epson papers.
Can anyone recommend, for my consideration, one of the packages that calibrates monitors and makes icc profiles for printers with various papers? Thanks for any input.
KK
 Havanai's gear list:Havanai's gear list
Canon EOS 5D Mark II Olympus E-M5 II Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8 Macro USM Panasonic Lumix G 20mm F1.7 ASPH +4 more
jtoolman
jtoolman Veteran Member • Posts: 5,605
Re: Best for Monitor Calibration AND icc Profile Creation?
KK
I have and use the Colormuki Photo mainly because I have over 15 printers that are using various makes of inks as well as OEM and many paper brands and types.
I could not live without my CMP!
Joe
My main printers ( there are more though )
2200/CX7400/R1900/R2000/R2400/R2880/PRO3800/R340/R380/1400/Artisan 725/Canon Pro9000MKII/Canon PRO9500 MKII / PRO-100
My videos!
PRO-100 Printing out of various sources
http://www.youtube.com/watch?v=fiYfoDpKk5Y
PRO-100 Setup and Basic Use:
http://www.youtube.com/watch?v=LlV7cqqladQ&feature=youtu.be
New way to refill EPSON OEM carts:
http://www.youtube.com/watch?v=BU6fi9VCOo0
01 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Intro
http://www.youtube.com/watch?v=gccxLvfknuE&feature=youtu.be
02 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part One
http://www.youtube.com/watch?v=9zJepnArTdo&feature=youtu.be
03 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Pro3800 PEM Refill Part Two
http://www.youtube.com/watch?v=TEeDpEIUkkQ&feature=youtu.be
04 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Refilling
http://www.youtube.com/watch?v=lRr-rUu9hkU&feature=youtu.be
05 Want to refill and reset your OEM PRO 3800 / 3880 Carts? Printing
http://www.youtube.com/watch?v=QaQju7xOKy4&feature=youtu.be
Cleaning the Purge Pad and Wiper on the Epson PRO 3800
http://www.youtube.com/watch?v=iKzxAm9QtWo
Basic Epson R2000 Maintenance
http://www.youtube.com/watch?v=wRZU1_XD7xE
Calibrating your monitor and Printing to the R2000
http://www.youtube.com/watch?v=-2X7MSd-ebE
Refillable 3800 3880 cart sticking problems
http://www.youtube.com/watch?v=rDi1lhDoWjM
Gloss Optimizing Prints
http://www.youtube.com/watch?v=9iRUoUwwSlA
Printing out of Photo Shop to Epson and Canon Printers
http://www.youtube.com/watch?v=mPV75Ak0R1g
Printing in LR-2 this time to the EPSON R2880
http://www.youtube.com/watch?v=huZ6BlXQqew
Multi Image printing in LR
http://www.youtube.com/watch?v=7xoJFJVemo8
Basic Printing in Qimage Ultimate
http://www.youtube.com/watch?v=uvrEAam6H_U
Canon PGI-9 Cart Refilling by the "Dribble" method
http://www.youtube.com/watch?v=mGBzHSQx5bU\
Refill Canon PGI 9 via Freedom Method
http://www.youtube.com/watch?v=VjgQIWLw10M
Refilling and resetting R2000 China Carts
http://www.youtube.com/watch?v=hh2wuzwezxM
Refilling Epson OEM carts - Thorough, Long Winded Version!
http://www.youtube.com/watch?v=fB8QspjBbhk
Taking out the CURL on prints done on from roll paper
http://www.youtube.com/watch?v=Q8Zj9dtzeU0
Taking out the Curl - TWO.mpeg
http://www.youtube.com/watch?v=VataFqqN-Jo
R2000 Push Buttom Reset Carts
http://www.youtube.com/watch?v=xzYreszSdAM
Creating a Color Profile & Printing on the Canon Pixma PRO 9000 MKII using Color Managent
http://www.youtube.com/watch?v=D0N-jgaJY94
Print Room Visit + Filling and Priming Refillable fro Epson 3800
http://www.youtube.com/watch?v=0ARPQ74_9N0
Color Management PART 01
http://www.youtube.com/watch?v=ScojQ7dWAFU
Color Management PART 02
http://www.youtube.com/watch?v=hqda4F9YlLU
Color Management PART 03
http://www.youtube.com/watch?v=IhmkI5EcPbI
Epson Stylus 2200 using refilled OEM carts and Roll attachment
http://www.youtube.com/watch?v=WEVDIPt_0tU
FJJ Regular Member • Posts: 117
I can't speak for the CM, but I have the Datacolor Spyder Studio kit and it comes with their monitor profiler and their SpyderPrint profiler - its served me well for creating ICC profiles for my printers as well as calibrating my monitor.  It also comes with a Spyder Cube to help with camera exposure and color balance in the field.
 FJJ's gear list:FJJ's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +9 more
Serhat Abaci Regular Member • Posts: 265
if you want to provide ICC services in printer profiles i would go for an X-Rite i1Pro 2 plus i1IO automatic scanning table so you can relax and lay back when scanning printer profiles
the i1IO automatic table cost about 2000 USD
and the X-Rite i1Photo Pro 2 for about 1300 usd....
if you just need a spectrophotometer for calibration Your gadets i would go for the colomunki and use it with argyllcms. bought mine 6 month ago and already did so many profiles for customers with it that it paid itself like three times
 Serhat Abaci's gear list:Serhat Abaci's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EF 40mm f/2.8 STM Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +3 more
DanlB Regular Member • Posts: 184
I have the ColorMunki Photo as well and it does a great job.  No more prints not matching the screen color and exposure.
 DanlB's gear list:DanlB's gear list
Canon EOS 5D Mark III
Hugowolf Forum Pro • Posts: 12,545
To add a few points:
Paper manufacture and reformator’s profiles have generally improved over the last few years. Almost all of the canned profiles for the 3880 that I have come across have been very good.
If you are using only a half dozen or so papers on a couple of printers, then it is still much more economical to outsource profile making. There are still profiling services out there: itSupplies, for example, although I haven’t used them for this service.
One of the reason why there are fewer profiling services available now was the merger of two of the largest hardware manufactures, and the subsequent changes to the resulting software licenses, which prohibit the sale of profiles without further license fees.
There are certainly systems out there that adjust to ambient lighting conditions, but I have never found them to be very accurate. You can always make two or three monitor profiles, and manually switch from one to another when lighting conditions change. NEC monitors, with their included X-rite colorimeter and SpectraView software, allow profile switching with the click of a button.
Colorimeters, used in the less expensive display-only calibration systems, ColorMunki Display for example, give slightly better monitor calibration than the more expensive spectrophotometers. But spectrophotometers can be used for both monitors and printers, colorimeters can’t.
There have been problems in the past with magenta colorcasts from DataColor generated paper profiles – I presume they solved that at some point. X-rite makes both the ColorMunki and i1 devices and software. For the most part the devices differ little, but the i1 software is better than the ColorMunki software.
The i1 Photo Pro2, offers built in UV and UV cut, for better profiling of papers with moderate to high OBA content. The software creates a larger number of patches, which allows faster production of profiles. With the ColorMunki’s iterative approach, you produce one set of patches, let them dry, scan them, produce another set of patch, let them dry, and then scan them; that could be 48 hours. The i1 Photo Pro2 is about three times the price of the ColorMunki Photo.
Brian A
