70D: Wireless transfer images to computer
Started Dec 9, 2013 | Discussions
Timzee Senior Member • Posts: 1,052
TONS of articles and videos out there explaining how to connect the 70D wirelessly to phones & tablets, but I can only find passing mention of how to transfer images to a PC (Windows 7) wirelessly. I'd appreciate a very brief overview of the process if this something you've done successfully?
Also, are there any limitations (other than video) of the size of files, such as full res RAW files?
Canon EOS 70D
digitalcuriosity Senior Member • Posts: 1,169
Re: 70D: Wireless transfer images to computer
First connect camera to computer using the USB this allows the needed drivers to be installed,then look in control panel at devices,if the camera is now found great if not try adding a new device. Camera has to be in your devices to use the 70Ds Wi-Fi. Then in cameras Wi-Fi program give the camera a nick name.
Now the real fun starts getting the camera to connect with the computer. Using my Canon G16 the Wi-Fi was very simple,but so far getting my camera connected to computer has not happened. IMHO Canon has not done a good job with the 70Ds Wi-Fi software.
erikkross New Member • Posts: 2
It is fairly complicated to setup the first time. Once it is setup it is pretty easy to use though. This document helps quite a bit: http://learn.usa.canon.com/app/pdfs/quickguides/WFT_EOS_Utility_OSX.pdf
You need to have the EOS Utility with WFT Pairing software installed on your computer.
The thing that confused me was that I needed to create a brand new WiFi setting on the camera in order to do the WiFi download, even though I had already connected the camera to my WiFi network for my smartphone. You have to create a new connection using the "Remote Control (EOS Utility)" option in the WiFi menu. Menu > WiFi function > Remote Control (EOS Utility).
 erikkross's gear list:erikkross's gear list
Canon EOS 70D
After downloading that Canon EOS Utility and reading through the setup instructions, all I can say is thank god I can use the USB on my Canon 70D to transfer picture and video files. Thanks Canon but NO Thanks....
pdqgp Forum Pro • Posts: 10,616
I set this up today.   Nice for when I'm in the house and not taking hundreds of shots.
"If you're not having fun at whatever it is you're doing, you're doing it wrong"
Barry Krueger
Barry Krueger New Member • Posts: 19
I'm all Mac, so can't help you with Windows connectivity.. but just a word
on the 70D's transmit/receive range:  I have a 6D and 70D and I've found that to
insure a good wireless connection, my 70D has to be within 10 - 15 feet of my wireless router (latest Apple Time Capsule).
Not so with the 6D.  It connects fine at double the distance - the other end of the house.  I thought my 70D was faulty until I walked near the room with the router and it took off like a banshee.
FWIW.
Krueger
Barry K. Krueger, Sr.
Canon 6D, 70D, 5Dmkii
24-70mm f2.8L IS II, 50mm 1.2L, 24-105mm f4.0L,
70-300mm 4-5.6L USM IS, Tokina SD 11-16mm f2.8 (IF) DX II
 Barry Krueger's gear list:Barry Krueger's gear list
Canon EOS 6D Canon EOS 80D Canon EOS M50 Canon EOS R Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
marczi New Member • Posts: 1
Hi! Those who have recently upgraded to Windows 10 like me, let me share how resolved the following EOS Utility firewall problem for transferring files through WiFi to my computer. When I run the EOS Utility and got the following message:
-To connect to the camera via LAN, some Windows Firewall settings must be changed. Do you want to make these changes?
After clicking on Yes, the message I got: "WFT FirewallSettings has stopped working". The next message is "Could not change the Windows Firewall settings":
I was browsing forums for hours without finding any solution to the problem. Finally, what fixed the error was to allow *ALL* Canon applications (Canon Utilities EOS Utility - Version 2.14) to communicate through Windows Firewall: "EOS Utility.exe", "EOSUPNPSV.exe", "EULauncher.exe", "WFT FirewallSettings.exe".
Hope this helps!
