Is there a foliage issue with the X trans sensor ?
Started Dec 9, 2013 | Discussions
baobob
Veteran MemberPosts: 6,959Gear list
Dec 9, 2013
Old subject and debate
The answer is definitly no. The issue is with the JPEG of foliage
If you develop the RAF in a good raw developper like C1 this is what you get
http://www.dpreview.com/forums/post/52682516
The same with my EOS 52 and ACR gives excatly the same results with a samll advantage to the Fuji
The JPEG engine does not processe correctly foliage with loss of fine details
This is typically the part of the shoots where RAW development is needed
No issue, just proper handling even if other cameras can handle foliage in JPEGs in a better way
Fujifilm FinePix X100 Sony RX100 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
unknown member
(unknown member)
Re: Is there a foliage issue with the X trans sensor ?
In reply to baobob, Dec 9, 2013
I think it's fair to say in some situations there is an issue and in others there isn't.
For those who have their workflow geared around Lightroom (such as myself) it is a problem still
Avoiding the problem does not necessarily remove the problem. I am still hoping Adobe & Fuji can work together to fix this.
WT Jones
Senior MemberPosts: 2,491
I have yet to see a problem with any of my shots. My raw conversion is 100% LR
Warren
tinpusher
Senior MemberPosts: 1,338Gear list
In reply to WT Jones, Dec 9, 2013
This summer some of the greens like pastures didn't look quite right in the jpegs.
Since using Photo Ninja on the RAW files those same shots look fine and much nicer than the ACR conversions.
 tinpusher's gear list:tinpusher's gear list
Sony RX100 Sigma DP3 Merrill Nikon D3 Sony Alpha 7 Olympus OM-D E-M10
Sal Baker
Veteran MemberPosts: 8,842Gear list
In reply to baobob, Dec 10, 2013
I haven't tried Photo Ninja yet, but I have tried Iridient Developer.  No issues with foliage.  I haven't downloaded the LR beta as it expires soon.  I'll wait to see how Aperture and the release of the new LR handles raw before I commit to another converter.
If you must use OOC jpegs with folliage and have the Nik Collection, use Sharpenor 3 and sharpen based on color range.  Select the folliage color with the eye dropper, and only the folliage will be sharpened.  Looks very nice.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +7 more
Chris Dodkin
Veteran MemberPosts: 6,573Gear list
In reply to Sal Baker, Dec 10, 2013
Got to love NIKs products - they were worth it when they were individually priced
As a bundle it's a no brainer
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
baobob
baobob OP
In reply to tinpusher, Dec 10, 2013
I use C1 7E and also find foliage much better than ACR
hexxthalion
Contributing MemberPosts: 536Gear list
CaptureOne user here - no problems at all (been LR user since the first BETA)
 hexxthalion's gear list:hexxthalion's gear list
Fujifilm FinePix X100 Sigma DP2 Merrill Fujifilm X-Pro1 Nikon AF Micro-Nikkor 60mm f/2.8D Fujifilm XF 18mm F2 R +11 more
Alessandro63
Contributing MemberPosts: 797
The correct answer is, well, yes, because the most used raw converter (Camera RAW, the engine of Photoshop and LR) shows it.
I agree it's not a sensor's issue. Third-party developers demonstrate that there is a better way to extract detail from this sensor, but this doesn't mean there is not a problem. We don't exactly know where the origin is, but until Adobe's converter and perhaps fuji's own in-camera conversion will be fixed, the problem is there and WE solve it by using different software when needed.
unknown member
(unknown member)
In reply to Alessandro63, Dec 10, 2013
Problem is it's not just foliage, ACR can often smudge and smear details of the X-Trans RAWs or bleed color. This is why some pros and bloggers dislike the X series - not so much the camera, but the roadblocks in workflow to those who use Lightroom / Photoshop.
I just don't think the X cameras are successful enough yet for Adobe to really give much of a care to be honest. Hopefully in time they will start to take notice.
Alessandro63
In reply to WT Jones, Dec 10, 2013
Warren
Because, perhaps, you haven't looked for it...
LR does a very good job in general. But there are occasions in which you can actually see a big difference in small detail/foliage when compared to "better" converters (those that extract more detail as C1, Iridient, RPP and the like).
OOF small details, and a sort of "facet" effect, in particular on the foliage (the one someone call watercolor and such) are visible even without pixel-peeping. Also, sort of blurred borders you may find on some coloured object against a blue sky (that may result in a lighter border on buildings/roofs when converting to B&W).
These are known conversion problems using camera raw (PS and LR). They're getting better, but there's still room for crisper results, as demonstrated by other converters.
What "saves" camera raw is that, compared to crisper developers, it shows way less noise (guess: adobe's using some anti-aliasing/noise "under the hood" procedure). It would suffice adobe offered a way to choose between the crisper/noisier and the softer output...
unknown member
(unknown member)
Warren
Well if you haven't used anything else, you have no real basis for comparison.
You may find this interesting - some good recent comparisons and also a bit on the false detail issue as well
http://blog.thomasfitzgeraldphotography.com/2013/11/iridient-developer-lightroom-fuji-x-trans-files/
Indeed a lot of users who switch say it's like having a new camera the difference is so obvious at 100%.
Alessandro63
In reply to stimpy, Dec 10, 2013
On the contrary, I think X cameras are quite successful. In my opinion, it's the software department at Fuji that's not the most brilliant one. Adobe's big enough to do a better job but I think they need help by the maker. After all, it should have been Fuji to give technical details on the sensor and development to Adobe, am I wrong?
Perhaps I could be wrong, judging from the results coming from free software (I mean DCRAW and all its derived converters). But we must take into account that there are many other things apart pure detail, and there are good photographers getting sensational stuff out of LR with X-Trans.
In fact the use of, say, Iridient as an alternative engine for LR is useful only in certain, particular situations. I'll repeat that, if Adobe offered the choice to disable its pre-denoising/antialiasing, we would get the best out of its products in any case. But I cannot know if it would indeed be switchable or if they would have to rewrite the converter...
All in all, we know that Adobe has not made the best but is also slowly correcting things. Pity, its bad development at start has induced a sort of X-Trans paranoia, where the sensor is instead a very good one, and capable of lots of detail too. It's having a good success despite these hiccups with development, this is meaningful, isn't it?
baobob
baobob OP
Good detailed analysis of the issue indeed!
Using C1 Ninja IR, ... solves the problem
Spud0
Regular MemberPosts: 233Gear list
I guess its a good thing I don't take tired, hacky landscapes of trees.
 Spud0's gear list:Spud0's gear list
Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8
unknown member
(unknown member)
What I mean is user base. 700,000 sales since the X100 is pretty insignificant. Ojly Fuji would know if this was 'a success' or not.
unknown member
(unknown member)
In reply to Spud0, Dec 10, 2013
Helpful.
kewlguy
Senior MemberPosts: 1,697Gear list
I prefer C1 and Iridient over LR and way better than ooc JPG.
 kewlguy's gear list:kewlguy's gear list
Canon EOS 6D Fujifilm X-T1 Nikon 1 J5 Canon EF 70-200mm f/2.8L IS II USM Canon EF 70-300mm f/4-5.6L IS USM +18 more
Tony Bonanno
Contributing MemberPosts: 756Gear list
Made me laugh :-D.  In reality though, the issue of "smearing" fine detail is not just with foliage, although it reveals itself with foliage perhaps more severely.  Occasionally an issue with certain "skin" detail when compared side by side with Bayer sensor file.  As others have pointed out there are RAW conversion tools that address the issue better than LR/ACR.
Tony Bonanno Photography, Santa Fe, New Mexico
ASMP General member
www.bonannophoto.com
 Tony Bonanno's gear list:Tony Bonanno's gear list
Nikon D810 Fujifilm X-E1 Fujifilm X-E2 Fujifilm XF 35mm F2 R WR
Spud0
In reply to Tony Bonanno, Dec 10, 2013
ASMP General member
No doubt, I just meant that in jest(thought with a tinge of honesty to it - but to each their own :-P)
