Good "adapted" portrait lenses for Fuji?
Started Dec 9, 2013 | Discussions
crashwins Regular Member • Posts: 260
I've done my due diligence and searched around on this topic, but didn't find much.
I just picked up an XE1 and have the 14mm 2.8 coming in the mail. I have a Canon mount Rokinon 35 (all manual) and wondering how this would be adapted to the Fuji. If not good, I'll likely grab the 35 1.4. Clearly, the Rokinon would be on the large end, but might be worth a shot.
Otherwise, a good portrait-length lens for Fuji is a must. Wondering what folks are using as solid adapted options? Nikkors seem good, even Canon FD, but Leica is probably out for me. Thanks in advance!
Fujifilm X-E1
57LowRider Senior Member • Posts: 3,766
Re: Good "adapted" portrait lenses for Fuji?
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +10 more
Spud0 Regular Member • Posts: 269
57LowRider wrote:
Cheap cheap cheap, brilliant -
http://www.flickr.com/photos/95540165@N08/8724096506/
Would you need an adapter mount?
 Spud0's gear list:Spud0's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8
Yes. I have an expensive (!) OM-FX one that was £29
crashwins OP Regular Member • Posts: 260
Thanks - nice lens, but a little slow on a crop IMO.
afragisk Senior Member • Posts: 1,291
Canon FD 85 1.2L with or without speed booster for the ultimate blur.
Fuji XE-2, Canon FD 50 & 85 1.2L, Fuji 14mm 2.8, 27mm 2.8, 35mm 1.4, Bower 8mm 2.8
kewlguy Senior Member • Posts: 1,761
My favorite is FD 55/1.2 SSC. Sharp at f/1.2, very sharp at f/1.4 - esp in low light.
 kewlguy's gear list:kewlguy's gear list
Canon EOS 6D Canon EOS 70D Canon EOS 5DS R Nikon 1 J5 Fujifilm X-Pro2 +24 more
wcowan
wcowan Regular Member • Posts: 494
I'm going to try the Takumar 55mm F1.8 when my X-E2 arrives. I already have the lens and adapter. It is a very small combo and the lens receives nothing but glowing reviews. Build quality and focus feel is as good as it gets. Dirt cheap too.
William Cowan
See some of my photos at http://www.radiantphotograph.com
 wcowan's gear list:wcowan's gear list
Fujifilm X-T1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Samyang 12mm 1:2.0 NCS CS Fujifilm XF 50-140mm F2.8 +1 more
TThorne
TThorne Senior Member • Posts: 3,013
I handled and shot briefly on an X Pro 1 yesterday with a Nikon 105mm f/2 DC. That lens is AWESOME for portraits. The 135 is quite nice too but a little bigger.
A lie gets halfway around the world before the truth has a chance to get its pants on. - Sir Winston Churchill
 TThorne's gear list:TThorne's gear list
Leica M Monochrom (Typ 246) Leica M Typ 240 Leica SL (Typ 601) Leica Summilux-M 35mm f/1.4 ASPH Leica Summicron-M 35mm f/2 ASPH +11 more
daddyman Regular Member • Posts: 179
The Konica Hexanon 50/1.4 and 85/1.8 are both very nice, depending upon the focal length you need.
Mike
 daddyman's gear list:daddyman's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
Les Berkley
Les Berkley Senior Member • Posts: 1,362
Second the vote for the Oly 50 f1.8. Plenty fast, sharp and very light, to go with the Fuji.
Guy With Piercings
RogerMuss Forum Member • Posts: 52
With the Oly lens do you focus wide open then stop down to shoot? This is what I did when I used it on my Olympus M4/3 but I kept knocking the focus adjustment when I reached over for the aperture ring.--
Roger
 RogerMuss's gear list:RogerMuss's gear list
Ricoh GR
hexxthalion Contributing Member • Posts: 536
in my old days of Nikon ownership that was the lens I wanted - defocus control. they're hard to get though
 hexxthalion's gear list:hexxthalion's gear list
Fujifilm FinePix X100 Sigma DP2 Merrill Fujifilm X-Pro1 Nikon AF Micro-Nikkor 60mm f/2.8D Fujifilm XF 18mm F2 R +11 more
hellocrowley Senior Member • Posts: 1,271
Voigtlander 58/1.4. Small, cheap, sharp, looks good.
biza43 Veteran Member • Posts: 4,221
Some other options are the M mount lenses, from Leica, Zeiss, or Voigtlander. Leica has some nice 90mm f2.8 and f4 that don't break the bank used... Zeiss has a very nice 50 f2 ZM (I have one)... they also have a 85 f4. Voigt has an excellent 75 f1.8 VM (I am getting one of these too). There are literally hundreds of options available.
Not forgetting Fuji's own upcoming 56 f1.2 of course...
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Sony Alpha 7 Sony Alpha 7 II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 +2 more
Elusivesouls Regular Member • Posts: 117
No one likes the Minolta Rokkor 58 1.2?  I thought it was considered to be legendary.
Les Berkley
No. With the focus peeking (sic) I can do fine up to about f5.6, which is as stopped-down as I usually go.
baobob
baobob Veteran Member • Posts: 7,222
For portrait I use either my XF 35mm 1.4 or my XF 60mm 2.4
The 600mm IMHo is better suited since the distance camera subject is wider F 2.4 is ok for bokeh and DOF It's wise just to stay at f 2.4 since the lens is IMHO a bit too sharp after
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
Wow! Awesome suggestions. My email didn't notify me after the first 2-3 emails that anyone had responded so sorry I had no idea. I think I'll probably lean towards the Nikkor or Canon FD lenses because they're pretty good doubles for video too. I'm also picking up a Fuji 35 so that might actually have me covered for a lot. Thanks!
