Mr. Rokinon 35mm 1.4 - test at f/1.4
Started Dec 9, 2013 | Discussions
moimoi
moimoi Veteran Member • Posts: 3,690
Hello,
As I am a big fan of the 35 mm focal length, I have done more performance test of this lens at f/1.4.  My conclusion is that the lens deliver very good results wide open, it is sharp and the contrast remains strong.
The "Fluffy Ball" photo was shot with the beloved a900 and Mr. Rokinon 35mm at f/1.4 (f/ number in the exif is wrong because there is no communication between the camera and the lens).
The original photo 6048 x 4032 has been reduced to 1920 x 1280 in the first shot:
The Fluffy Ball
The Bokeh looks really quite good at this distance, the lens is sharp wide open, and there is plenty of contrast.
100 % crop
For pixel peepers, I attached a 1920x1280 resolution 100 % crop frame.   It looks pretty sharp at f/1.4, isn't it.
My conclusion:  For those of you who are not scared with manual focus, that lens is a real bargain (~425-450 USD), and it has great optics, and is decently built.   For those of you who seek AF capability, the Sigma is your best option.  Avoid the Sony 35mm 1.4 which is absolutely not sharp wide open, and is much more expensive (and you want some amount of sharpness at f/1.4, otherwise, what's the point to buy a f/1.4 lens)
moimoi
http://www.maximesiegler.com/
https://www.facebook.com/maxime.siegler.photography
Photography is about time, space, expression, and - ultimately - capturing light. This formula may sound easy, but actually capturing the "ideal" photograph is far more complex to accomplish as our own perceptions and responses vary according to each individual. Photography is inherently driven by human subjectivity, but the general feeling is that a superb photograph is widely appreciated, as it commonly depicts a striking and universal concept. I believe this process should be sought by many of us, who deeply enjoy capturing and sharing photographs that embrace life and depict what we are.
 moimoi's gear list:moimoi's gear list
Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Canon EF 16-35mm f/4L IS USM Canon EF 35mm F1.4L II USM
Vikas Rana
Vikas Rana Contributing Member • Posts: 910
Re: Mr. Rokinon 35mm 1.4 - test at f/1.4
Nice, I liked it but I'm scared of using MF. They should provide a screw-drive at minimal.
 Vikas Rana's gear list:Vikas Rana's gear list
Sony Alpha SLT-A58 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Sony DT 55-300mm F4.5-5.6 SAM Sony DT 18-55mm F3.5-5.6 SAM II Adobe Photoshop CS6
RussAdams Contributing Member • Posts: 831
Don't be afraid of MF with Focus Peaking...
Rokinon are building some really nice glass. I have both the 8mm and 14mm versions and LOVE them.
If you have not tried Focus Peaking, you can give it a try with any of your existing AF lenses.
Just set your camera to MF, and turn on Focus Peaking. A whole different world will open up. I find I use it more and more for cityscapes and landscapes. I can get a sharper result than AF, and it only takes an additional moment. I'm using it more and more with my old Minolta 125mm macro when I'm shooting 'general' photography.
Just my .02 cents.
Russ
 RussAdams's gear list:RussAdams's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 Sony a77 II
Nice!
Thanks for showing a great example of what the Rokinon can do wide open. These 'real life' samples are a big help.
Russ
moimoi
moimoi OP Veteran Member • Posts: 3,690
I understand it can be intimidating at first, but at such wide apertures, AF can be somewhat imprecise. Also, at those wide apertures, if you lock the AF, and the recompose, it is very likely that the primary target will no longer be in focus. With manual focus, you don t have to recompose. It requires patience, skills, a bit of luck as well. As time goes, you grow in experience.
moimoi
Re: Nice!
Indeed. You are welcome.
stan_pustylnik Veteran Member • Posts: 3,864
Nice photo, moimoi! Maybe it is the lens I was looking for!
Person is taking photos, not camera. When photograph is bad, it's because photographer doesn't know how to choose settings optimal to "own preferences". Then blames camera for bad IQ.
This is same as blaming car about arriving to wrong destination.
http://stan-pustylnik.smugmug.com
 stan_pustylnik's gear list:stan_pustylnik's gear list
Panasonic Lumix DMC-TS2 Sony Alpha DSLR-A850 Sony SLT-A55 Sony DT 18-55mm F3.5-5.6 SAM Sony 50mm F1.4 +11 more
dennismullen
dennismullen Veteran Member • Posts: 8,990
On the Sony 35/1.4G
I doubt many Minolta or Sony 35/1.4G owners will be trading their lenses for this or the Sigma 35mm lenses. I'm sure they are very sharp.
Opinions of the Sony lens are 99.9% what was read by that person on the internet.
Owners generally love the certain special quality of this Sony lens.
"Those who would sacrifice liberty for safety deserve neither liberty nor safety." - Ben Franklin.
You can see larger versions of my pictures at www.dennismullen.com.
moimoi
Re: On the Sony 35/1.4G
I think owners can also be in denial. Here is one review of the Minolta/Sony 35/1.4G
http://slrgear.com/reviews/showproduct.php/product/981
"We tested two samples of this lens, as the first sample gave us what we considered to be unacceptably high softness wide open for a lens with this price tag. When the second lens tested identically, we accepted that this is just the nature of the lens."
Wide open, the Minolta/Sony is (very) soft while Rokinon or Sigma are sharp to very sharp (Sigma is a tad sharper). Sigma is the most impressive of the 35mm f/1.4, like it or not. Rokinon/Samyang is not too shabby either.
http://photographylife.com/reviews/sigma-35mm-f1-4
http://photographylife.com/reviews/sigma-35mm-f1-4/4
Both lenses are also cheaper, the Rokinon is the cheapest (but does not have AF, which is fine with me), the Sigma is cheaper than the Sony by 500 USD, which is not insignificant.
AarSee
AarSee Veteran Member • Posts: 4,654
That 35mm looks like it might be another lens I need to get in the future.
I recently got the Rokinon 85 1.4, and that is a great MF lens for the price.
It looks like Rokinon is making some great cost effective lenses.
Cute dog too!
Rick
 AarSee's gear list:AarSee's gear list
Sony SLT-A77 Sony a6000 Sony a77 II Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-3N +10 more
tex Veteran Member • Posts: 6,842
Yes, the Sam/Rok is terrific, great value too /nt
tex_andrews, co-founder and webmaster of The LightZone Project, an all-volunteer group providing the free and open source LightZone photo editing software.
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Sony Alpha 7R Pentax 645Z Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm 1:3.5 ED AS UMC +15 more
moimoi
Cute dog too!
Rick
The Roki cine version is on my list. Is it sharp on FF?
moimoi
i meant the 85 t1.5
N/t
brian14478
brian14478 Senior Member • Posts: 3,703
Looks great for 1.4. How is the color rendition of the rokinon? I have thought and looked at the 85mm but I have 75-135 @ 2.8 covered very well and am not sure I would use it enough.
I have been doing more and more portrait work though.  A faster 85mm could be sweet. Is there fringe with the 35? or 85.
Thank you-brian
AarSee
Cute dog too!
Rick
I bought the 85mm 1.4 regular version.  It has the aperture ring with the "clicks" unlike the smooth motion of the t1.5.  The t version also has some electronics to show some data, I believe.
Unfortunately I have not tested the 85 f1.4 on a full frame as I only have crop cameras.  But on my equipment it seems to be quite sharp @ f1.4.  The depth of field is wonderfully shallow, but also perplexing.  The focus peaking and zoom focus assist is great.
After reading many reviews raving about the Rokinon lenses, I am very happy that it is proving to be a very nice performer.
Good to hear about other Rokinon primes and their high performance.
Rick
brian14478
I use manual with zoom assist...focus on the eye(or whatever). click...done deal.- Easy really.
Before Minolta came out with autofocus in 1985 everyone manually focused, its not rocket science.
But I can only imagine the frustration/heartache though with film, very fast lenses and those 'just off' shots that didn't reveal themselves till the film was developed.
It is the action and bif's with manual that take a bit of work/luck.
Thanks-brian
how is CA/PF with this lens?
I too would be interested to hear about PF/CA issues.
moimoi
I can only speak for the 35mm 1.4 (but I plan to get the 85 mm 1.4 whenever I get focus peaking). Color rendition is very nice, on the warm side generally. It is a sharp lens at f/1.4-2 and becomes very sharp at f/2.8 and beyond. I sold my Zeiss 24-70 f/2.8, and there is a good reason for that
Those f/1.4 lenses are best to be used at f/1.4-2, the rendering is very smooth as expected for such a fast lens. It really opens a new artistic area.
For the 35 mm, the CA/CF are well controlled (although inevitable at f/1.4). CA can be easily removed via ACR (if you shoot raw). The Samyang (Rokinon) has been tested by Dxo marks and Photozone.  This review was done with the D3x, the closest camera to the Sony a900.
http://www.photozone.de/nikon_ff/658-samyang3514fx?start=2
Thank you-brian
moimoi
Re: how is CA/PF with this lens?
Stan,
Check the photozone review that has been done with the Nikon D3x (sensor is very similar to the A900) and the Samyang 35 mm.
It has very good marks.
Moimoi
Lucas_
Lucas_ Veteran Member • Posts: 3,018
That's a sharp shot, with very good contrast and colors. I have the Rokinons 85/1.4 an 8/3.5 and they're both very good, I bought them when I had A77 and A900. With the A99 and Roki 85 the peaking seems not to be working so well ( many times won't show - I must be doing something wrong? ). Anyway I'm planning now in getting the 14mm/2.8 and the 35/1.4 ( though IMO looks a bit large ).
... Lucas
Always having fun with photography
http://www.lucaspix.smugmug.com/
 Lucas_'s gear list:Lucas_'s gear list
Minolta DiMAGE A1 Sony RX100 Konica Minolta Maxxum 7D Sony a6000 Sony Alpha 7 II +41 more
