E-M1 for Sports?
Started Dec 9, 2013 | Discussions
mack13
New MemberPosts: 22Gear list
E-M1 for Sports?
Dec 9, 2013
I have decided to try to take some pictures of my daughter playing basketball.  My only camera at the moment is the Fuji X-E2 and I just don't think it's going to be fast enough for sports.  So.... there's a 2nd system in my future.  Is the E-M1 going to work well for sports or am I better off going with a DSLR (which I prefer not to do).  Thx!
Fujifilm X-E2 Olympus E-M1
rcjim
Regular MemberPosts: 318Gear list
Re: E-M1 for Sports?
In reply to mack13, Dec 9, 2013
I don't know about the E-M1, but I discovered this past weekend that the Panasonic GX7 did a good job of photographing an 8th grade basketball game. See the link to the set below.
http://www.flickr.com/photos/30161756@N00/sets/72157638451234325/
I used the Panasonic 25mm f/1.4 lens...not the farthest reach, but decent if you are close to the court. I shot in Shutter Priority Mode with SS at 1/500 sec. and ISO set to Auto. Most of these photos were shot in burst mode, as well...which is a testament to the lightning fast AF of the GX7.  Also, out of the 300+ photos shot, not a single shot was out of focus...another testament to the very high performing AF system of the GX7.  I think when paired with the proper lenses, the GX7 can make a recent sports photography camera.
 rcjim's gear list:rcjim's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Leica Summilux DG 25mm F1.4
Torsten Hoff
Veteran MemberPosts: 3,301Gear list
Provided you turn off the image review in the EVF (to keep from getting confused between your last image and the live scene) and don't try to shoot faster than 6.5fps (AF doesn't work at higher continuous shooting rates) you will be fine.
C-AF + TR has given me mixed results, with uniforms it is difficult for the camera to track actual players. It's best to rely on simple C-AF, which works very well on the E-M1.
 Torsten Hoff's gear list:Torsten Hoff's gear list
Olympus E-M1 Olympus E-300 Olympus E-510 Olympus E-3 Olympus E-5 +14 more
Skeeterbytes
Veteran MemberPosts: 8,553
With the E-M5 I've done a little soccer and volleyball, even dabbled with surfing. With native system lenses it's able to acquire focus fairly well and does a pretty good job. What's missing from my kit are long, fast system lenses, so I get best results with close action (e.g., positioned by the soccer goal or on the near sideline). My longest µ4/3 is the 40-150, which focuses moderately fast but is very slow, certainly too slow for indoor action unless the lighting is blazing bright. Unfortunately, the E-M5 does less well with 4/3 lenses, which are my main sports lenses.
From what I see here, that last issue is better dealt with on the E-M1, if not necessarily as good as an E-5. I'd think the 40-150/2.8 would be just right for indoor hoops, but it's vaporware right now. The 35-100 might be long enough(?) but I'm not personally tempted by that option.
High-speed burst mode is a fantastic feature, by the way.
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
DonTom
Contributing MemberPosts: 533Gear list
Surely you should have a go with the camera you have, unless you don't have a suitable lens.
The X-E2 has a pdaf system which should make it suitable for sports. The X-E2 for Fuji and the E-M1 for Olympus are their first generation PDAF mirrorless cameras, so I doubt one will have a clear advantage over the other.
If you are intending to buy a second system regardless, I personally would look at a DSLR. Sports and action photography is one area where a DSLR has had a clear advantage over mirrorless. That advantage is shrinking, but there is still a considerable gap.
"Is that a Filofax?"
"No, it's a Moleskine with interchangeable leaves....."
 DonTom's gear list:DonTom's gear list
Olympus PEN E-PL1 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
horsth
Regular MemberPosts: 279Gear list
I photographed an indoor handball-match over the weekend with the E-M1 and mostly the 45mm/f1.8. I used both C-AF and S-AF alternately with success. Forget about C-AF and "tracking". This works only with very slow subjects, especially with videos. You have to track fast subjects yourself with the finder.
Greetings
 horsth's gear list:horsth's gear list
Fujifilm X20 Olympus E-M1 Panasonic Lumix DMC-GH4 Olympus 12-40mm F2.8 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +7 more
Deleted010614
Regular MemberPosts: 248
In reply to rcjim, Dec 10, 2013
I dont mean to hyjack this thread but WOW you did a tremendous job with that basketball game and a 25mm reach!!! That could not have been easy to get that level of quality, bravo!
OK now for the original posters question. I was going to say I bet my EM1 would do fine at this but after seeing the post above I'm going to say the GX7 looks like a huge winner here also.
GIGO
dennis tennis
Senior MemberPosts: 2,999
In reply to mack13, Dec 10, 2013
Simplify your life and get a DSLR.  The 7D or its replacement next year.  I assume the D400 will show up one day.  Sony A77 is good but the buffer is too small.
If you want to go cheap and classic.  Canon 1dmk2 or 1dmk3, get an old 70-200 f2.8, non IS.  Life is good and simple.  Get yourself a RapidStrap and mono pod that that's it.
I tried shooting college soccer with EM1 and my SHG and HG lenses.  painful.  Can it be done?  yeah.  Is it enjoyable?  No.  Feels like work.
Barry Stewart
Veteran MemberPosts: 8,569Gear list
Even the E-PL5 is good enough (don't tell my wife!)...
In reply to dennis tennis, Dec 10, 2013
… Even without an EVF, which can be a challenge, especially when the LCD is tilted.
I've gotten basketball and hockey photos with the E-PL5 and Sigma 60 for my weekly sports stories for the Hope Standard newspaper (western Canada.)
I know… sounds crazy, but I'd rather shoot with it than my E-5 in many situations. 8 FPS sure adds to the possibilities.
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus C-5060 Wide Zoom Olympus PEN E-PL5 Olympus E-1 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +9 more
bimmerman
Senior MemberPosts: 2,396
Yes the EM-1 is capable but I think a bug exists...
For outdoor action I have found the EM-1 to be almost as good as a Nikon D7100. While the C-AF can sometimes pause momentarily and continue tracking again, the overall experience is very positive and DSLR like.
But I think I may have found a fault with the EM-1 which may or may not be fixed by Firmware in future. The problem may not affect indoor sports because the ambient brightness should be quite good but for darker venues or practice sessions where ambient brightness drops below a certain level, the EM-1 EVF will judder badly when you're panning the camera up or down thus making it difficult to follow the action.
You can read about it here:
http://www.dpreview.com/forums/post/52677489
bimmerman
But the weight!
Yes Dennis, a DSLR still works better for sports but a 1DMkII with 70-200IS F2.8 is hard labour for most of us. I had to hoist my much lighter 70-200VR and D7100 for a recent catwalk shoot 3 months ago for 45 minutes per session and the damage it did to my shoulder and back can be felt even right now. If I don't shoot sports for a living, I'd rather not go the DSLR route.
Yeah, I know, maybe I should hit the Gym.
Deleted010614
Re: But the weight!
In reply to bimmerman, Dec 10, 2013
Me too! I have all the big Canon DSLR gear and have shot with it for years but I'm really tired of all that weight and bulk. If I was shooting a basketball game I would probably drag it out but but to be honest my big, full frame gear is not getting much use these days. Going forward I don't see that changing "for me".
GIGO
Lab D
Senior MemberPosts: 6,938Gear list
DSLR? Yes and no. (EM-1 works very well for sports)
And when people say DSLR, they mean something like a 7D or up and a 70-200mm F/2.8 lens or one made for shooting action. They don't mean a rebel with an 18-250mm zoom or other kit type lens.
The E-M1 with the right lens also is great for sports action. I have not had any issues with shooting people (or dogs) running at me full speed.
 Lab D's gear list:Lab D's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GH4 Nikon D600
Logan3-1639
Regular MemberPosts: 139Gear list
A DSLR may be better for sports, but the E-M1 is certainly capable of shooting a basketball game, and it's noticeably lighter, more comfortable, and more fun to shoot than a DSLR, IMO. Here are several shots captured with the E-M1 (shutter priority @1/400s and C-AF) and Olympus 75mm f/1.8 lens from a recent game where a family member was participating...
~Ed
Judging others does not define them... it defines you as a person who needs to judge.
 Logan3-1639's gear list:Logan3-1639's gear list
Ricoh GR Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Martin.au
Forum ProPosts: 10,078Gear list
With the right lens, then I found sports to be a piece of cake, with either of the OM-Ds.
Check these threads.
http://www.dpreview.com/forums/thread/3576794
http://www.dpreview.com/forums/thread/3559598
http://www.dpreview.com/forums/thread/3472108
 Martin.au's gear list:Martin.au's gear list
Olympus E-M1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic Lumix G Fisheye 8mm F3.5 +6 more
Paulmorgan
Veteran MemberPosts: 4,638
Most sports are pretty slow and there hardly what could be called action.
Makes you wonder how people managed with film or plate camera`s.
Your XE-2 should be fine with a little practice.
Its not the camera or the lens.
http://w2.sydsvenskan.se/bildspel/ldasmfriidrott/
http://www.digitalphotopro.com/profiles/axel-heimken-the-art-of-selective-focus.html
mack13
mack13 OP
In reply to Paulmorgan, Dec 10, 2013
I agree with you.  I'm pretty sure I could zone focus with the X-E2 and get some positive results.  I think the alluring thing about the Olympus alternative is their 75mm lens.  This is a very fast lens and is highly regarded and coupled with the quick responding E-M1 makes a compelling alternative.  I've also considered the Pentax K-3 but that's about as large as I'd go.
Lab D
It is easy to guess where the "action" will be too.  Goal, net, line, base, etc.
