My findings about K3
Started Dec 9, 2013 | Discussions
JimBim
JimBim Regular Member • Posts: 221
It's time to upgrade my K20. There are a lot of opinions on the web, so I decided to visit a local camera store and test myself. I assume, that all cameras below ISO 1600 are doing well. So my starting point was ISO 1600. I need a camera for dog shows (I'm running website for dogs) to shoot inside and landscape, holiday outside.
I tested cameras inside the camera store. There is no day light, only fluorescent light. WB was on Auto, AV mode, lens FA50, aperture 2.8, SR ON, hand held. I tested four cameras: my old K20, K01, K3 and Nikon D610. For my surprise all Pentax cameras were not able to adjust right white balance (I tried Nikon 610 and there was no problem with WB). All shoots were underexposed. I found, that output from K01 was better as from K3! I think this camera is good option for my holidays.
Audrius
PS Sorry for my english
There are my results (ISO 1600):
K20
K01
K3
D610 (Cropped)
 JimBim's gear list:JimBim's gear list
Pentax *ist DL Pentax K20D Canon EOS 7D Mark II Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +3 more
Nikon D610 Pentax K-01
MightyMike
MightyMike Forum Pro • Posts: 33,879
Re: My findings about K3
The funny thing is Nikon used to be horrible with auto WB in tungsten lighting, did you set the tungsten correction to subtle or strong?
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
JimBim
JimBim OP Regular Member • Posts: 221
Mike, I don't know Nikon, so I asked a guy from camera store to set WB it to Auto.
Jim in Hudson
Jim in Hudson Senior Member • Posts: 1,774
Audrius
K20
K01
K3
D610 (Cropped)
Thanks for sharing.  Do you recall the real color of the Mitsubishi photo printer?  Red or orange?
 Jim in Hudson's gear list:Jim in Hudson's gear list
Pentax K-3 Fujifilm X-T10 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 17-70mm F4.0 AL (IF) SDM Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +4 more
FrancW
FrancW Regular Member • Posts: 202
I rather would like to now on what the metering was set. That makes a difference as well
 FrancW's gear list:FrancW's gear list
Pentax K-7 Pentax K-3
JimBim
The color of the printer was red (like in Nikon picture); Multi-segment metering mode.
Kaso
Kaso Senior Member • Posts: 2,546
My "low tech" eyes vote for the K-01 image first, then the Nikon D610 image.
Richard Smals
Richard Smals Senior Member • Posts: 1,781
The K-3 has a custom setting to correct tungsten light: Strong or subtle. When auto WB used this is of huge influance. Candlelight ambiance vs cool look.
Bye4now
http://members.home.nl/rsmals/DPR/Me.jpg
http://www.indots.nl
I have the deepest respect for all those people who like me.
VaLeX
VaLeX Senior Member • Posts: 1,067
Starting even with K100D, and K10D after it, white balance in low, yellow light has been a problem with Pentax.
Nice to see they're persevering with this "ethos". (as the phrase was made famous in this review:
http://www.imaging-resource.com/PRODS/K10D/K10DA.HTM )
Comments, criticism, suggestions: it goes without saying!
http://s86.photobucket.com/albums/k107/huzururmuz/
 VaLeX's gear list:VaLeX's gear list
Pentax K10D Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited
Cane
Cane Senior Member • Posts: 6,900
Bye4now
He said there was only fluorescent light, folks.
rogerstpierre
rogerstpierre Veteran Member • Posts: 3,893
Not sure what to make of of your test to be honest.  The Nikon is over-exposed IMO by 1/3EV compared to K-01, which is underexposed by 1/3EV (pretty typical of Pentax) at same speed and aperture.  The K-03 metered even lower for some reason, but WB balance is pretty much consistent with K-01, just darker image. The K20 ISO is obviously not accurate (and I wonder about the Nikon also but I am surprised since Nikon's ISO values usually tend to be over stated, but it would almost seem the reverse here).
If WB is a concern, you shouldn't shoot Auto WB to begin with.  If it's really a concern, you should us Manual WB.  Different makers make different assumptions about what the "right" WB ought to look like.  Pentax chose to have a warmer artificial light.  This is neither right nor wrong, just a different taste setting.
Roger
 rogerstpierre's gear list:rogerstpierre's gear list
Pentax smc DA 21mm F3.2 AL Limited Pentax Optio 33WR Samsung TL500 Pentax K10D Pentax K-01 +18 more
rogerstpierre
Notwithstaning that the OP reports fluorsecent light in these tests, which seem strange given the yellow cast, yellow light is not a "problem" with Pentax. Pentax choose to correct Thungsten light on the warm side to preserve the feel of the scene under Auto WB.  Turning everything to pure Daylight white under Auto WB is wrong, as this isn't what you're seeing.  Auto WB in theory attempts to replicate the light as your eyes see it. If/when you apply the appropriate WB setting, Pentax handling of WB is quite good actually compared to many.  The last thing I want, is my Sunset photos to turn out as if it was noon time !
Roger
Bruce Trail Hiker
Bruce Trail Hiker Senior Member • Posts: 1,337
The Nikon 610 render the printer Orange! And Jim recall that the printer is Red!
Audrius
K20
K01
K3
D610 (Cropped)
 Bruce Trail Hiker's gear list:Bruce Trail Hiker's gear list
Pentax K-3
Robgo2
Robgo2 Veteran Member • Posts: 4,650
Someone needs to point out the obvious fact that all of the Pentax pics are underexposed, the K-3 most of all. I think that explains why the latter's output looks to be the worst. Still, I am not surprised that the FF Nikon's looks best. It should at that ISO.
Rob
Jim in Hudson
Audrius
K20
K01
K3
D610 (Cropped)
Regardless as whether it's described as orange or red, the OP I think is claiming the D610 image we see here is closest to how he remembers the printer to actually look.
JimBim
To be precise the color of the printer is a little bit darker as in Nikon shoot, but not as dark as in Pentax pictures in reality. I think all pictures from Pentax are underexposed, because Pentax cameras are not able to find right WB (the calendar on a shelf must be white) and it influence an exposure. I don't know, might be it happens only under fluorescent light.
MightyMike
My question about tungsten correction was related to the Pentax
Mike from Canada
Richard Smals
Bye4now
Yes but the setting mentioned has also influance on 4000/4500 Kelvin lights not only on 3200 Kelvin or lower.
Bye4now
