Shooting Beauty in the Studio with the X-Pro1
Started Dec 9, 2013 | Discussions
nathanelsonphoto Junior Member • Posts: 45
5
Some recent work using mixed light and the X-Pro1 + XF 35mm 1.4:
http://nathanelson.com/the-fuji-xpro1-in-studio-part-1-of-2/
Fujifilm X-Pro1
flbrit Veteran Member • Posts: 3,665
Re: Shooting Beauty in the Studio with the X-Pro1
Very good work and an excellent review. Thanks.
Brian
 flbrit's gear list:flbrit's gear list
Sony Alpha 7R II Zeiss Loxia 21mm F2.8 Zeiss Batis 85mm F1.8 Canon EF 100-400mm F4.5-5.6L IS II Carl Zeiss Distagon T* 1,4/35 ZM +6 more
(unknown member) Contributing Member • Posts: 614
Wowzers, what stunning examples!! The second photo is syrupy sweet, such nice colouring & tones.
I really like how you have left some detail in the skin, seems increasingly rare these days. Love it!
Did you do much post? If so I'd be interested to read a quick workflow as I am sure others on here will too. JPEG / RAW for example?
nathanelsonphoto OP Junior Member • Posts: 45
Thanks Stimpy, and yes, I leave all the skin texture in my photos, but with the photos that size it's harder to see
My post is pretty basic. I shoot RAW, then import to LR5 where I make some contrast and tonal adjustments along with adding some clarity, then export to PS CC and work the skin with the healing brush to take out any glaring flaws and smooth out any redness in the skin. That's pretty much it.
Glad you like them. Cheers!
Chris Dodkin
Chris Dodkin MOD Veteran Member • Posts: 6,817
Love the mix of flash and long exposure - the motion effect works really well, especially on #5 and #6 for me.
Adds a real dynamic to a normally static portrait set-up
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS 5D Mark II Canon EOS-1D Canon EOS-1D Mark II Canon EOS 30D +34 more
dark13star
dark13star Senior Member • Posts: 1,373
Really nice work. Did you trigger the flash remotely or via cable?
Rich
"I would be an historian as Herodotus was." -Charles Olson
http://herodot.us
 dark13star's gear list:dark13star's gear list
Fujifilm X100S Olympus Tough TG-4 Fujifilm X-E1 Fujifilm X-E2 Fujifilm X-T1 +9 more
Rich
Hey Rich,
I use the Einstein heads with the Cyber Sync triggers so everything is triggered by wireless. These were all shot using at least 3 strobes, and using sync cables with slaves would be a huge pain in the ass
Cheers
-Nate
dark13star
Hey Rich,
Cheers
-Nate
Thanks for the info on the setup. I figured it was likely remote. I still haven't determind my lighting strategy for Fuji. I'm invested in Nikon CLS and am considering a remote system to use the same heads.
http://herodot.us
Al Valentino Senior Member • Posts: 4,661
Excellent work!!!
Fuji XE1 w/14, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
cheddargav Veteran Member • Posts: 4,493
Photography and writing, A+ Great stuff, cheers
www.twitter.com/gavphotography
 cheddargav's gear list:cheddargav's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GX7 Canon EOS 6D Canon EF 24-105mm f/4L IS USM Sigma 50mm F1.4 EX DG HSM +4 more
BRPWS
BRPWS Contributing Member • Posts: 567
I like the way you brought all of the lighting elements together as well.  Very artistic.  Using the slow shutter speeds certainly added a great deal to the image.  Big impact on all of the images.
Very well thought out and executed.
Elliot
Elliot
 BRPWS's gear list:BRPWS's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 35mm F2 R WR
Al Valentino wrote:
Excellent work!!!
Thank you.
Thanks!
afragisk Senior Member • Posts: 1,291
This is unbelievable.. Can you plus advise how did you take the photos ? Flash, movement, shoot? I can't think how you achieved the amazing glowing effects. Thx.
Fuji XE-2, Canon FD 50 & 85 1.2L, Fuji 14mm 2.8, 27mm 2.8, 35mm 1.4, Bower 8mm 2.8
ryan2007 Forum Pro • Posts: 12,001
Could you not use the Fuji 55-200 since this was a studio shoot it may have work. You could get that depth of field potentially since the longer focal length is a shallow DOF.
You also have the Fuji 60 mm as a Prime lens option.
I think it would work and I am sure the 56 mm will be great to have as well.
WT Jones Senior Member • Posts: 2,495
The second & third ones really grabbed my eye, the detail and depth for lack of a better term are supurb. Bravo
Warren
57even Senior Member • Posts: 9,443
Beautiful work.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
I'll never own a variable aperture zoom lens, not that it wouldn't work in the way you described, because it would, but for my own personal shooting preference I prefer fast primes.
The 60mm is also an option, but again, for my style I prefer a faster lens, and the 56mm f/1.2 has my name all over it
Thanks afragisk.
The process is actually fairly simple. I would use one or two of the modeling lights on my Einstein heads (depending on the look I wanted) as a constant light source, then turn off the modeling light on any strobes that were lighting an area that I wanted to 'freeze', such as the face. After the flash would fire, the areas that were not being hit by a modeling light fell into darkness, so the camera would then only pick up the areas that were being lit by the modeling lights, creating light trails as I moved my camera around. The exposure time was around 2 seconds.
Hopefully that makes sense Thanks for checking them out.
That is fine, but the 56 mm only exists on paper. Fuji has already pushed back the 10-24 f 4.0. The only lenses that exist or anything for that matter are what is on the shelves today for use today.
So what will you do if Fuji keeps delaying the 56 mm release? Do you have a plan B or just make due with the 35 mm?
