my first images with the 20-40mm
Started Dec 9, 2013 | Discussions
Thomas Streng Senior Member • Posts: 2,683
I received the lens last week and took some first snaps on the K5IIs.
The lens needed +6 focus fine adjustment but now seems to work fine.
My impression is that sharpness over the frame is quite good even at f4.0.
The Bokeh can get a little busy.
I really like the built and handling.
That's all I can say so far.
Here are some more images: http://www.pbase.com/tstreng/pentax_20-40
Regards,Tom
Pentax K-5
afterswish1
afterswish1 Contributing Member • Posts: 741
Re: my first images with the 20-40mm
Hi Thomas, thanks for posting. I think you're quite brave as I'm sure you know you're going to be bombarded with questions now
One question I'd like to ask myself would be: how do the corners look at the wide angles around f8? I've had a look at the images you uploaded but given the file sizes and lack of exif data it's hard to say.
Gravity will make you crazy until you get the hang of it.
ASR45
ASR45 Forum Pro • Posts: 34,979
Good start, hard to tell i dont like pbase as they dont show the true picture, as much as i hate flickr as well the definition looks a lot better, im sure the lens will prove to be a good one have fun.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
Thomas Streng OP Senior Member • Posts: 2,683
lower right corner at f5.6 at 20mm. One with the 18-135 one with the 20-40. can you see which is which? (I can)
leopold Forum Pro • Posts: 14,029
First shot with DA 20-40mm Ltd !
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm f/4.0L USM Fujifilm XF 14mm F2.8 R +3 more
noel2 Contributing Member • Posts: 566
First shot certainly with 20-40. The 18-135 performs rather miserably in the corners.
 noel2's gear list:noel2's gear list
Pentax K-5 IIs Sony Alpha 7 II Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 12-24mm F4.0 ED AL (IF) +22 more
afterswish1
I'd say the top is the 20-40, well it does look a bit sharper or more contrasty. The bottom one is not far off though.
Plakanina Contributing Member • Posts: 772
If it's the 2nd one I want to cancel my order! so please let us know.
 Plakanina's gear list:Plakanina's gear list
Ricoh GR Pentax K-5 II HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
Regards,Tom
I would really like to know how it is at 30mm. Can you do this?
Of course first one is 20-40. This was at f5.6
At f4.0/4.5 the difference is even more obvious.
here is one at 30mm. So far I find IQ consistent over the full range.
one more at 30mm wide open (3.5)
20mm f2.8
20mm f2.8
ozdean
ozdean Forum Pro • Posts: 23,002
Thanks Thomas would love to see them both at f8 and say 25mm if you had the time.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
Thanks for that. Looks quite sharp. Is that a little curvature I see?
