How much would I miss a small gap in focal length between lenses?
Started Dec 9, 2013 | Questions
KayW
KayW New Member • Posts: 2
I have a Nikon D3100 with an 18-55 lens and am looking at the following telephoto zooms:
Nikon 55-300 f/4.5-5.6G ED VR
Nikon 70-300 f/4.5-5.6 IF-ED VR
Tamron 70-300 f/4-5.6 Di VC USD
I'm leaning towards one of the 70-300 lenses for what appears to be better AF plus manual AF override, but am wondering how much I'd miss the 55-70 mm gap between my two lenses. My use is all personal pleasure: friends, travel & nature, school sports.
Nikon D3100
Zlik
Zlik Contributing Member • Posts: 990
Re: How much would I miss a small gap in focal length between lenses?
That small gap will never be a problem. The problem will be that when your future telephoto will be attached, you will want to shoot some wide stuff as well without changing lenses, and that's when you'll see the biggest difference in convenience between those lenses. Having the possibility to zoom out to 55 in stead of 70 will spare you a couple of lens switches.
Only you can decide if you want better AF/quality (70-300) or more convenience/weight (55-300).
If you plan to upgrade to FX, the 70-300 has an advantage obviously.
Bing Chow
Bing Chow Contributing Member • Posts: 901
You won't miss it. If you have 18-55 on and it is not close enough, just walk closer. If you have the 70-300 on and you're too close at 70mm, just back up. Choose your lens based on its optical performance and feature set.
KennyXL
KennyXL Contributing Member • Posts: 711
The only way you'll truly miss it is if you are the obsessive type who, once something gets in their mind, they can't let it go.  The simple fact is a few steps forward will pretty much cover the gap.  However, there are times when you simply cannot take those steps and you have to make do with a subject that is either slightly too small or too big.  In cases like that default to the too small and crop to taste and don't look back.  However, if you are the obsessive type mentioned earlier, maybe trading a little AF speed for peace of mind is a small price to pay for long-term sanity.
 KennyXL's gear list:KennyXL's gear list
Sony RX100 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Tamron SP 24-70mm F2.8 Di VC USD Nikon AF-S Nikkor 85mm f/1.8G +3 more
dasams
dasams Senior Member • Posts: 1,037
Nikon's 28-300 is also a nice lens.
 dasams's gear list:dasams's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED
KennyXL
It's softer at 300mm (which is a big reason why people buy these zoom lenses) than all the lenses mentioned above.  I have had 3 models of the Nikon 28-300mm VR lens and they all exhibited this attribute.  They weren't particularly wonderful at 28mm either, but they were passable.  By the way, I've also had multiple copies of all the lenses above as well except for the Tamron (which I had only one copy of, but it was the sharpest of all the lenses mentioned at 300mm).
Brev00
Brev00 Veteran Member • Posts: 7,426
I shoot more by purpose than focal length.  When I want action/wildlife, I use my Tammy 70-300 vc.  When I am walking around shooting flowers and landscapes I use my Sigma 17-70 os.  That covers the range, too, but I got the 17-70 after the telephoto and liked the closeup shooting at the long end.  A purpose.  I did not get it for the smooth range transition.  So, identify your purpose and the purchase will follow.
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Tokina AT-X Pro 12-24mm f/4 DX II Sigma 17-70mm F2.8-4 DC Macro OS HSM Sigma 70mm F2.8 EX DG Macro +3 more
vepar
vepar Regular Member • Posts: 147
You got pretty much everything covered, that small gap in 55-70 range should not be an issue. Maybe, it could be annoying doing portraiture, because it is possible you would swap lenses more often, but you got portraiture also covered with that in mind. Other than that, IMO you should't have any significant issues with the gap.
 vepar's gear list:vepar's gear list
Fujifilm FinePix E900 Zoom Nikon D7000 Nikon D800 Nikon AF-S Nikkor 50mm f/1.8G Carl Zeiss Distagon T* 2/35 +13 more
brightcolours
brightcolours Forum Pro • Posts: 12,477
You won't miss it, unless it keeps being in your mind. I do not know if the Tamron has manual AF override (a feature I never "get" anyway), but the Tamron is the best of the lenses you list (in my opinion).
JP Scherrer
JP Scherrer Veteran Member • Posts: 9,917
You have legs, don't you ?
...so, to fill the gap, just WALK back or forth ! ...much cheaper than buying a new lens, and very healthy !
J-P.
Photo Galeries at http://www.pbase.com/scherrer
Spherical Panoramas (360x180 degrees) at http://www.viewat.org/?sec=pn&id_aut=2489
Equipment list in profile
 JP Scherrer's gear list:JP Scherrer's gear list
Nikon 1 J1 Nikon 1 V1 Nikon D800 Nikon 1 Nikkor VR 6.7-13mm f/3.5-5.6 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 +8 more
KayW
KayW OP New Member • Posts: 2
I've thought about the 28-300, too, but not sure I want to spend that much at this time...
Thanks for all the input. I appreciate it!
Kuvasauna
Kuvasauna Contributing Member • Posts: 767
Not at all (n/t)
'Anyone who believes exponential growth can go on forever in a finite world is either a madman or an economist.'
marco1974
marco1974 Senior Member • Posts: 1,588
Gaps are actually beneficial!
 marco1974's gear list:marco1974's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R XF 90mm
afoton
afoton Senior Member • Posts: 1,043
No, you don't need all focal lengths. In my photo bag right now, there is a 20mm, 35mm, 85mm and 200mm. In the summer I have a 55mm and a 105mm, both closeup lenses, instead of the 35mm and 85mm with bigger aperture I use in the dark season.
calson
calson Veteran Member • Posts: 7,191
Go with the gap - i.e. the much better 70-300mm lens. If in doubt take a look at your photos and see how many fall into the 56-69mm zoom range.
Jon Ingram
Jon Ingram Regular Member • Posts: 157
You will absolutely never miss the gap. Trust me. If the main reason you are thinking of the 55-300 is for the gap, then don't worry about it. But as others' have said though, you may miss be able to go as wide as 55, but there are trade-offs between the two lenses. Just know that for Dx 70mm is very zoomed in, so the 70-300 lens will be most useful as a specialty lens for head portraits, wild-life, and compressed landscapes. It will probably not be an all purpose lens that you keep on your body all the time.
vepar
Previously I forgot to mention, one situation where 55-70mm range is very usefull and handy. Photographing soccer from the goal line. There is a lot of situation where wing player runs by the side and in the end of action is doing center-kick - you won't be able to capture that decisive moment. I noticed how american style of photographing soccer differs much from european style, americans do it often from side line in portraiture style, but we europeans do it always from the goal line trying more to capture decisive moment.
Other than this, which might be trivial for you, I really can't think of any other situation where 55-70mm could be crucial.
Tom Nokin
Tom Nokin Junior Member • Posts: 25
Go with the 55-300mm if you know, that you stay with DX go for the 70-300mm if upgrading to FX is an option. Great lvalue ens by the way.
Cope
Cope Veteran Member • Posts: 6,327
Depends, but for most of what you say you shoot, it's not likely an issue.  To be safe though, I would recommend the 55-300 for your second lens.
Never ask a man where he's from. If he is from Texas, he'll tell you. Otherwise, don't embarrass him.
 Cope's gear list:Cope's gear list
Nikon D7000 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Sigma 150mm F2.8 EX DG Macro HSM +3 more
timbyers11
timbyers11 Forum Member • Posts: 73
It is very unlikely you would be missing anything with a 7.4 degree difference in FOV, especially at distances between 3 feet and 30 feet.
If shooting at 55mm, you would crop few pixels to get the equivalent view of a 70mm lens.
The number of pixels to crop would be even less for something inbetween 55mm and 70mm.
If you were working professionally, and needed every last bit of quality obtainable from your equipment, to make up the entire difference between 55mm and 70mm at a 3 foot subject distance, you would have to move a maximum of 5 inches to cover the 55mm to 70mm gap.
At a subject distance of 10 feet, you would have to move a maximum of about 1.5 feet to cover the gap..
At a subject distance of 100 feet, you would have to move a maximum of 14 feet.
At that level of quality and detail you would probably be more concerned with relationship of subject to background, but you also wouldn't be economizing on "consumer-grade" lenses.
 timbyers11's gear list:timbyers11's gear list
Nikon D3200 Nikon D300S Nikon D810 Nikon AF-S Nikkor 35mm f/1.4G Nikon AF-S Nikkor 24mm f/1.4G ED +25 more
