should I be shooting with a lens hood or no lens hood indoors?
Started Dec 6, 2013 | Discussions
SteveCooper
SteveCooper Contributing Member • Posts: 504
Hi,
Should I be shooting with a lens hood or no lens hood indoors? How about if I'm using a hot shoe  flash or off camera flash?
I have read that using a lens hood may improve contrast.
Opinions?
 SteveCooper's gear list:SteveCooper's gear list
Fujifilm FinePix S100fs Sony Cyber-shot DSC-F828 Nikon D90 Nikon D300S Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +8 more
confyushis Senior Member • Posts: 1,070
lens hood all the time ...
i would use a lens hood at all times and at all locations.
i would use a lens hood with all on-/off-camera flash unless the light is blocked by the hood of a longer lens.
yes, a lens hood improves contrast.
 confyushis's gear list:confyushis's gear list
Canon EOS 550D Canon EOS Rebel SL1 Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 30mm F1.4 EX DC HSM Sigma 8-16mm F4.5-5.6 DC HSM +3 more
SteveCooper
SteveCooper OP Contributing Member • Posts: 504
Re: lens hood all the time ...
thank you, I thought that was the case, but I read a review by someone whose first name starts with a "K" that said (and I quote) "lens hoods are for wimps"- that the lens coatings were sufficient- I thought that was crazy.......
VIRTWO
VIRTWO Forum Member • Posts: 92
It would be nice if you can post some pictures (if possible) taken indoors, with and without hood. That will make the point more clear.
I personally use hood all the time now (someone on DPR advised to use it) but previously I did not used it all the time. Now, when I see pictures with and without hood taken indoors at different time, I really cannot make big difference between them. Well that may be possible because I have just started into photography.
 VIRTWO's gear list:VIRTWO's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon 200-500mm F5.6E ED VR +1 more
jtan163 Senior Member • Posts: 2,264
You could try both approaches and see how it works for you in the conditions you shoot in.
I don't know for sure, but I think a lot of these "thou shalt.."/"thou must..." type rules are averages across lots of scenarios.
If you're shooting in reasonably similar conditions most of the time, then just try out both approaches and see if either approach yields better results in your target viewing media.
Then you can choose - for those conditions - on actual first hand experience and knowledge.
Personally I take a lot of K's opinion as questionable and it appears inconsistent to me.
I find his site occasionally useful for finding specs and if I'm really bored, light entertainment.
 jtan163's gear list:jtan163's gear list
Nikon D750 Nikon D4 Olympus OM-D E-M5 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 24-120mm f/4G ED VR +7 more
Josh152 Senior Member • Posts: 1,888
A lens hood will stop stray light from entering the lense and washing out the picture. If you are indoors and don't have strong light source shining stray light into the lens it won't really make a differnce. However it will still protect the lens and shooting with the lens hood on all the time is a good habit to have.
For reference while outside, this video show the difference a lens hood can make.
http://www.youtube.com/watch?v=oSiZ99NcKu4
Craig Gillette Veteran Member • Posts: 9,456
Re: Depends
If using flash, especially the on camera flash, the lens and  lens hood, can intrude into the light path from the flash.  This will cause a pretty distinctive shadowing in the lower portion of an image.  Not as likely to prove a problem at longer focal lengths or higher shoe mounted flashes.  Still, worth checking, especially at wider focal lengths or big, fat, fast lenses.
tocar Veteran Member • Posts: 4,304
Re: should I be shooting with a lens hood or no lens hood indoors?
Lens hoods were mainly used outdoors for preventing stray side lights from going into the lens and causing flares.  With new improved lens coatings the lens hood became less useful except for really bright lights hitting the edge of the lens.  Now the lens hood is used mainly to protect the lens specially if you're not going to put a lens cap during a shoot.  Using the lens hood indoors is overkill for regular shooting with flash but might be different with off hot shoe shooting and multiple flash use.  On shoe/in camera flash use you will see the lens hoods ruining the pictures.
 tocar's gear list:tocar's gear list
Canon PowerShot S5 IS Canon PowerShot SX50 HS Nikon Coolpix P900 Canon EOS 5D Mark II Canon EOS M +1 more
nymphaeles New Member • Posts: 6
A lens hoods protects the front of a lens, that's a fact. My own experience is that there have been so many time I swung the camera and the lens hood hit something hard enough that it caused serious scratches on the hood. Just last week, my camera hit the corner of a desk with the lens hood in reversed position. That hit broke a UV filter, but luckily the lens survived. Had the hood in the right position, I wouldn't lose an expensive filter. I say have the lens hood on at all times, it may cause you some inconveniences, but it would save your expensive lens and UV filter.
I don't have the expertise nor the scientific equipment to test and prove that a lens hood would do you shots better. In my opinion, stray light is stray light, it can well be both indoor or outdoor. And since you want to put your hood on for protection, why not keep it on for both indoor or outdoor shots?
Just my two cents.
 nymphaeles's gear list:nymphaeles's gear list
Canon EOS 50D Canon EOS 350D Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm f/2.8L USM +8 more
Parry Johnson Contributing Member • Posts: 581
I shoot with a lens hood whenever I can, indoors or out for all the above reasons.  However, while using a built-in flash, there will be a shadow caused by the hood in any wide-angle photo (usually with focal lengths less than 28mm FX or 20mm DX), so if I'll often just take off the hood rather than getting caught up in the moment and forget about the vignetting.  It's just something to think about.  Remember that in that case most of the light will come from the flash, and it therefore won't create flare, so using a hood defeats the purpose.
Of course, this doesn't apply to a hotshoe-mounted flash, as there would then be enough clearance to avoid the hood shadow.
 Parry Johnson's gear list:Parry Johnson's gear list
Nikon D800 Nikon 1 V1 Nikon D7100 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +8 more
Mark B. Forum Pro • Posts: 19,559
The only time I would shoot w/o a hood is if I'm stuck using the built-in flash indoors, when the hood will create a shadow.  Other than that, the lens hood is properly attached at all times when I'm shooting.
Mark
Bronze Age Man Regular Member • Posts: 340
Lens hoods reduce flare from edge lights that degrade contrast. There may or may not be such light sources but generally that is not where you are looking. Lens filters as protection are for wimps. The 'K' guy likes them and the dots of internal reflection they add to pictures, I never use them.  I do use hoods for physical protection from objects and light rain.
Appreciative student of the late Joan Wakelin. 39+ years later still enjoying it!
MichaelVadon Senior Member • Posts: 1,109
The main advantage of a lens hood is protection of the front element.  It puts space between the front element and everything else.  This is especially handy when working close quarters and crowds.
The main disadvantage is when you want to switch lenses.  You have to put the lens back in the bag and it usually doesnt fit in the bag with the hood on thus requiring an extra step.  If you have to change lenses quickly lets say during a sporting event or a wedding then the hood presents a problem.
As for contrast and picture quality, I believe the protection of the front element is the greater reason for using the hood.
nkistrup
nkistrup Senior Member • Posts: 1,701
+1
Agreed!  It only comes off for attaching/detaching filters & a thorough lens cleaning w. ROR.
 nkistrup's gear list:nkistrup's gear list
Canon PowerShot G12 Olympus XZ-1 Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED +4 more
Which is basically what I said....
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,089
SteveCooper wrote:
Hi,
Opinions?
  1. To use lens hood as mechanical protection for the lenses is a big BS, IMO. Its primary function would be avoid direct light on lens surface
  2. From my twelve lenses, I think eight have hoods. All of them are near to crap as they are too small to offer real protection against light direct hit on the lens surface except the hood for Nikkor 80-400 AFD VR. Perhaps the hood for Nikkor 85 f/1.4 can be worth something, but when I am using it usually the light more deliberated so no need for the hood also
  3. The biggest joke is the hood for Tokina 35 f/2.8 Macro - actually a two mm ring!!
  4. I prefer by far to avoid glare positioning myself carefully or protecting direct light hit with my hand or cap. It is not always convenient, mainly when shooting action indoors with a lot of artificial light sources but the hoods at the same circumstances usually are also unuseful
  5. Definitively direct light hit on the lens glass surface will bill a toll on contrast. It will be worst in poorer coated lenses. Unfortunately lens hood are near to nothing IMO, so take care positioning yourself with more care and eventually shadowing it with your hands, a cap, a piece of paper, anything is better than the usual hood.
Best regards,
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Colin Franks
Colin Franks Senior Member • Posts: 1,249
 Colin Franks's gear list:Colin Franks's gear list
Panasonic Lumix DMC-G3 Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF 50mm f/1.2L USM +20 more
Rexgig0 Senior Member • Posts: 3,197
I am equally clumsy indoors and outdoors; a hood is the first line of defense against impacts and scrapes.
I wear a badge and pistol, and, primarily with 7D cameras, with 10-22mm and 100mm Macro L lenses, shoot evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, PJ, and occasional action. During personal time, I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +30 more
