X100 battery charger failed
Started Nov 23, 2013 | Discussions
Zaax
Regular MemberPosts: 352Gear list
Nov 23, 2013
Last weekend I was doing a lot of shooting with my X100 and I stuck one of my four batteries in the BC-65N charger overnight. Got up the next day and noticed that the green light was blinking. Put the battery in the camera and it would not power up. Took a second discharged battery and put it in the charger and got the same result. Then I took the charger off the wall socket and noticed that the green light stayed on. That was very odd.
I figured that the charger had failed so I looked at B&H for a replacement and found that they were $49.00 there http://www.bhphotovi...er_for_the.html Took a look at ebay and found a non-OEM charger that was sold by a dealer with good feedback and thought that I would take a chance for $9.00 with free shipping. http://www.ebay.com/...984.m1439.l2649
Got the charger last night and charged three batteries with it. It seems to work well but does not seem to charge as fast as the original BC-65N charger.
Zack S
Shoshin ni modoru - go back and remember the feeling of being a beginner
Flickr http://www.flickr.com/photos/10025089@N05
 Zaax's gear list:Zaax's gear list
Fujifilm FinePix X100 Sony RX100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +10 more
Phil Levy
Contributing MemberPosts: 607Gear list
Re: X100 battery charger failed
In reply to Zaax, Nov 23, 2013
This happened to me a few weeks ago whilst on holiday in India - nothing I could do until I got home which was frustrating. Luckily the X100 was just backup to my X-E1 system, but it was disappointing not to be able to use it. I too got a non-Fuji charger very cheaply when I got back which works just fine.
www.phillevy.co.uk
 Phil Levy's gear list:Phil Levy's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +13 more
baobob
Veteran MemberPosts: 6,961Gear list
fuji chargers are not reliable
i have postrd several times
it is known
Fujifilm FinePix X100 Sony RX100 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
Phil Levy
In reply to baobob, Nov 23, 2013
it is known
baobob - does this apply to X-Pro1/X-E1 charger also? If so I think I will get a backup now.
www.phillevy.co.uk
WT Jones
Senior MemberPosts: 2,491
I have not had a Fuji charger fail, but I did not like the long cord in my bag and I wanted a 12 Volt option to charge in the car. I bought three (one X100 & two X-E1 type) Wasabi brand chargers & a few batteries from Amazon (US). So far so good on all accounts. They seem to charge at a good rate as well.
Warren
Zaax
Zaax OP
I forgot to mention that the charger came with a 12V cigarette cord too.
Zack S
jyhfeei
Forum MemberPosts: 88Gear list
Zack S
For some reason, Fuji's chargers are very unreliable. At the end of this article, it notes that they have a failure rate almost 10 times normal.
http://www.lensrentals.com/blog/2013/08/lensrentals-repair-data-2012-2013
 jyhfeei's gear list:jyhfeei's gear list
Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8
limlh
Senior MemberPosts: 1,132
In reply to Zaax, Nov 24, 2013
Remove the battery and unplug the power cable from the charger and power point. Put the battery back into the charger. Then plug the cable back into the charger first and then to the power point. It should work again.
http://www.pbase.com/lhlim
Marx81
Regular MemberPosts: 432Gear list
In reply to Phil Levy, Nov 24, 2013
Yes , in my view , Fuji could easily win a contest for the worst charger in the market .
The detachable battery support , the led that switch off when battery is charged but also if the electrical connection goes off....are unique features .
http://www.flickr.com/photos/marxx/
 Marx81's gear list:Marx81's gear list
Fujifilm FinePix X100 Canon EOS 400D Canon EOS 5D Mark III Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM +3 more
paulcraig
Regular MemberPosts: 345Gear list
In reply to jyhfeei, Nov 24, 2013
jFor some reason, Fuji's chargers are very unreliable. At the end of this article, it notes that they have a failure rate almost 10 times normal.
So very true. My X100 is less than a year old and already on my second charger. The first one failed while charging several batteries in a row. Thankfully Fuji did replace it, but that was little help in the middle of a vacation.
 paulcraig's gear list:paulcraig's gear list
Fujifilm FinePix X100 Sony RX100 Sony Alpha NEX-6 Sony E 18-200mm F3.5-6.3 OSS LE Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
baobob
I get most of the flat battery episodes
Inow use a generic charger that I systematically unplug after each charge
100% og success and no more problem
