strong spherical projection
Started Nov 23, 2013 | User reviews
chanaw
chanaw Forum Member • Posts: 60
I love this lens for being so small. Walking around, the people will not even notice when photographed. The bad side is the strong spherical projection. Sometimes it does not matter, however, for landscape and buildings with a more flat appearance this lens delivers pictures not so good as should be.
 chanaw's gear list:chanaw's gear list
Pentax K-3 Pentax smc DA* 200mm F2.8 ED (IF) SDM Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc D-FA 50mm F2.8 Macro Canon PowerShot S100 +8 more
Pentax smc DA 40mm F2.8 Limited
Prime lens • Pentax KAF • 21550
Announced: Dec 15, 2004
chanaw's score
4.0
Average community score
4.3
Leandros S Senior Member • Posts: 1,790
your copy may not be typical
Assuming that you're referring to barrel distortion, I suspect that your copy is not in spec - photozone review has this to say:
"exhibits only a minor degree of barrel distortion (~0.6%) which is usually not an issue"
Source: http://www.photozone.de/pentax/630-pentax40f28?start=1
If you're really noticing the distortion, there's probably something wrong with your copy.
No amount of perceived entitlement can replace actual expertise.
chanaw
chanaw OP Forum Member • Posts: 60
Re: your copy may not be typical
I know what barrel distortion is.
Thanks.
Msroberts Contributing Member • Posts: 714
Are you saying the distortion you're seeing is not barrel distortion? If so could you please describe what you're seeing?
chanaw
It's simply spoken unsharp at the border where it should be sharp. It's very easy to see. The lens is sharp, but not in a flat plane, but strongly curved toward the camera. Sometimes it helps to get a real sharp picture from border to border, e.g., when photographing a scene where I stand in front of a building and at the border there are trees in the foreground. So I found out that the projection is a sphere rather than a flat plane.
I'm not the first person who makes this observation. For instance, go to the slrgear.com review and see the blur index. It starts with +1 from left to the center and goes up to +2 at the right border. They tell it so: "Our review sample of the 40mm ƒ/2.8 seemed to be slightly sharper on the left side than the right". In fact, it is perfectly sharp on the right side also, but you need to have some object in the foreground.
Giklab Contributing Member • Posts: 598
Field curvature /nt
no text
chanaw
Re: Field curvature /nt
Giklab wrote:
no text
Yes, and it is very pronounced, so I'm wondering that so many people didn't notice. The effect worsens if you stop down. This is really strange, however, you can see it again at slrgear.com when you stick the slider to f/5.6. The curve starts at +1.5 at the left border, lowers down to +1 in the center and rises to just a bit under +3 at the right border.
If this is a bad copy, so I'm not the only one who got one of those.
chanaw
Re: strong spherical projection - Examples
I still owe the proof. Here is the very annoying picture.
Of course, you can have it sharp in the middle. This is not the problem with this lens. See this.
If you look through the branches you can see the center of the opposite shore is very sharp. On the border the opposite shore is out of focus, but the branches in the foreground are still sharp.
I've never seen such a pronounced field curvature elsewhere.
MightyMike Forum Pro • Posts: 34,228
Why haven't you got it serviced yet? clearly you have a bad copy, stop complaining and get it serviced.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
chanaw
It's not a bug, it's a feature.
Since this lens is really sharp and I'm not sure what I will get back after "servicing" (what should they do?), I'm keeping this lens for special sceneries.
No one else will be in a position to control a certain situation when this particular property would be required.
Seriously, I guess, this is a standard error of the production line, because slrgear.com states the same.
In their blur index diagram of this lens the blur on the border starts moderately at f2.8 and increases surprisingly when stopped down. The maximum is at f5.6.
Really annoying is it only, when you expect to receive a lens with a behaviour "as usual".
Thank you and best regards!
Flex M Regular Member • Posts: 140
Re: spherical like this?
Courtesy NASA/JPL-Caltech
http://kayakfari.wordpress.com/2014/01/01/happy-new-year/
Flex Maslan
www.kayakfari.com
most issues like this get weaker as you stop down... perhaps its the aperture that is tilted.
Mike from Canada
chanaw
Yes, exactly that's it!
In a special situation like this, the lens is wonderful.
All you need is the right scope of application.
Thank you and kind regards!
chanaw
It gets better from f8...
Thank you for suggestion.
Although the effect is seen to the extreme left and right, it is not quite symmetrical. The pictures explain exactly what slrgear.com has measured. They did not measure the field-curvature, but the blur caused by curvature. Maybe there are two bad copies?
miles green
miles green Veteran Member • Posts: 5,091
Bad lens
I'm with mike:
Based on the fiirst picture in particular, i think your lens needs repairs.
Infinity stop is off and field curvature is waaaay more than what's acceptable.
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax K-1 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited +10 more
The tilt might change as the aperture rotates and of course most effects like this do vanish with higher DOFs
Mike from Canada
rogerstpierre Veteran Member • Posts: 3,896
Interesting observation. I must admit, field curvature is one thing I never noticed on my DA40 and in any cases, strong is certainly not how I would describe it on mine.
Roger
 rogerstpierre's gear list:rogerstpierre's gear list
Pentax smc DA 21mm F3.2 AL Limited Pentax Optio 33WR Samsung TL500 Pentax K10D Pentax K-01 +18 more
andrew britten Senior Member • Posts: 1,128
This lens has long been well regarded for its sharpness, corner to corner, regardless of aperture.
You've got a bad, maybe dropped, copy - simple as that.
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +1 more
chanaw
Roger
Thank you!
Maybe that even a bad copy could produce an image like this. Or, would you regard this as the result of a bad copy?
My attention was aroused when I saw the review of Klaus Schroiff at photozone. He did a valuable remark when he tested this lens on a K-5: "You may also spot a slight focus shift towards the background when stopping down ("residual spherical aberrations") - if you observe the "17" at the various aperture settings in the chart below you will notice that it doesn't get any sharper and the focus hotspot moves towards the background."
Moreover, if you look carefully you can see that in his demonstration the lines which are about in the middle of DOF at f2.8 actually walk out of the field regarded as sharp at f5.6. In other words, if the camera focusses a special spot at f2.8 exactly, this spot may be OOF when stopped down. I have not only one picture showing this behaviour. This effect may be independent of field curvature.
However, I must admit that in most cases DOF helps very much with this short focus length. And in many pictures the extreme borders do not count. So, I'm quite happy with this lens also. I do not play football with my lenses.
Some people already mentioned that this pancake because of it's extraordinary smallness has to face some compromise in IQ.
So, I believe that it is not evil to deliver some examples for the "bad" side also. We have not always fair weather.
Kind regards.
JeffAHayes
JeffAHayes Senior Member • Posts: 1,968
What IS that in your next-to-last picture, Chanaw -- the Leaning Tower of Piza??? Take that lens back for an EXCHANGE -- like YESTERDAY!!!!!
Jeff
A word is worth 1/1000th of a picture... Maybe that's why I use so many words!
 JeffAHayes's gear list:JeffAHayes's gear list
Pentax WG-3 Pentax K-5 Pentax K-30 Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +8 more
