Please post your A7/r settings here
Started Nov 21, 2013 | Discussions
radissimo
Regular MemberPosts: 135Gear list
Nov 21, 2013
Hi, I just got my A7 and wondering what are the most useful setting you guys can recommend to change out of the box. I listed my preference, let me know what you think
Radissimo settings- e.g.what I changed:
( listed from beginning to end, or from left to right)
1) image quality Fine-> extraFine
2) Focus Mode-> DMF (shows peaking always ON)
3) Focus area ->center spot
4) AF illuminator --> Off (?more quicker focusing,less annoying)
5) ISO--> Auto ISO (min:100 max:6400)
6) DRO/HDR--> Off (prefer to be done in PP)
7) Focus Magnif. time--> No limit
8) Peaking level --> High ( on my Nex-6 I had Low)
9)Phase Detect Area--> On (helps me to stay without that area for faster focusing + reminds me a viewfinder of old SLR
10) release w/o lens --> Enable
11) e-front curtain shutter--> ON (A7 only, needs more research if not damaging the picture quality as some posters noticed)
12) APS-C size capture--> Off (as I am using my 35mm f1.8 OSS lens with acceptable vignetting)
13) Dial Wheel --> Lock (as too easy to change ISO)
14) Display Rotation--> Auto
15) Mode dial guide--> On (not need to look on the dial only)
Outstanding questions:
A) what is your Creative style preference (Std/Vivid? Contrast /Sat/sharpness?)
B) AF micro adjustment (cogwheel, menu 5)??
C) Lens Comp--?? all AUTO
D) YOUR CUSTOM FUNCTION MENU SETTINGS?
E) YOUR CUSTOM KEY SETTINGS (C1,C2,C3) ?
F) YOUR CUSTOM MAIN DIAL SETTINGS?
 radissimo's gear list:radissimo's gear list
Sigma DP2 Merrill Ricoh GR Panasonic Lumix DMC-LX100 Canon PowerShot G7 X NEX-5T +3 more
Sony Alpha 7 Sony Alpha NEX-6
radissimo
Re: Please post your A7/r settings here
In reply to radissimo, Nov 22, 2013
My current Custom button settings:
C1: DRO/HDR
C2: Memory (Register) - to easy switch between modes id memory without turning the Mode dial
C3: Color Peaking (as manual focusing 90% and switching between day/night -some peaking colors beter the other in certain conditions)
AEL button: Magnification for MF
SCN mode: Handheld twilight
Rado
Jonathan Robson
Contributing MemberPosts: 843Gear list
I think the micro adjustments only apply if you're using the LEA adapters for A mount lenses, its not applicable otherwise.
'When the seagulls follow the trawler, it's because they think sardines will be thrown in
to the sea.' - Eric Cantona
http://bornred.net
 Jonathan Robson's gear list:Jonathan Robson's gear list
Sony Alpha 7R Sony a6000 Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 70-200mm f/2.8L IS II USM Sigma 150mm F2.8 EX DG Macro HSM +10 more
turnstyle
Senior MemberPosts: 1,935
Is AutoHDR available if you're shooting RAW?
I know AutoHDR will save a JPG, but do you have to switch to JPG first before you can select AutoHDR?
Blitz
Regular MemberPosts: 155
hi,
i have one question: where can i switch off the window for the magnification when pressing the ael buttom for manual focussing ? currently i need to press it twice which is annoying and not like my nex7, first press the focus area window appears, second press the magnification is there....
YankeeUK
New MemberPosts: 4Gear list
Great idea for a thread, gathering up all the collective wisdom from the forums on settings. I just got mine yesterday and I haven't had much of a chance to play with it yet.
Thanks.
 YankeeUK's gear list:YankeeUK's gear list
Sony Alpha 7
radissimo
In reply to Blitz, Nov 22, 2013
Blitz wrote:
hi,
This is annoying me as well, anybody knows?
NEXFULLFRAME
Regular MemberPosts: 281
In reply to radissimo, Nov 23, 2013
radissimo wrote:
Blitz wrote:
hi,
Me too!
NEXFULLFRAME
Great thread! I'd like to know if there's a way to review the shot (chimping) with magnified view to check critical focus using a button other than c2. I find it's quite difficult to reach c2 and it's a very common operation for me.
navierb
Forum MemberPosts: 53Gear list
In reply to NEXFULLFRAME, Nov 23, 2013
In the Nex-6 was perfect with the OK-Button! Why the change!?!?!
At least, once is zoomed with C2, you can zoom-in/out with the rear dial
 navierb's gear list:navierb's gear list
Sony Alpha NEX-6
navierb
In reply to navierb, Nov 24, 2013
I made a Table with which Functions can be assigned to which Buttons or Fn-List:
A7 Assignable Functions (Dropbox)
Sony Alpha NEX-6
D©P Images
Regular MemberPosts: 256
In reply to radissimo, Dec 8, 2013
Bump. Interesting thread!
d
Lancefurr
New MemberPosts: 1
In reply to radissimo, Feb 18, 2014
Noob question: What is the benefit of changing the focus area to center spot from it's wide default? I tried researching online but couldn't find a clear answer. Thanks
Fredy Ross
Veteran MemberPosts: 6,695
I have an a7r
In reply to Lancefurr, Feb 18, 2014
would the recommended settings be the same as an a7?
fredyr
stevo23
Veteran MemberPosts: 9,470Gear list
Raw + jpg. If you use jpg, you should drop sharpness and noise correction a bit.
I like this setting too.
It's useful, but the others have their use.
On. Does it always come on? I think it only comes on when it needs it.
Never auto, I put ISO settings on the dial.
DRO on this camera works well. Don't confuse DRO with HDR.
Yep
For wide angle, yes. For Telephoto, high.
? Not sure what you mean.
Yep.
Same.
Why worry about it changing ISO if you have auto ISO on?
Yep
A) I use std because I use RAW. You can apply that later in Lightroom.
B) No need to keep this on a handy button. Once you've compensated a lens, you don't need it.
C) Off - do it in post processing
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Nikon AF Nikkor 20mm f/2.8D Tamron SP AF 90mm F/2.8 Di Macro Sony FE 35mm F2.8 Sony FE 55mm F1.8 +1 more
halfmonkey
Regular MemberPosts: 167Gear list
In reply to radissimo, Feb 26, 2014
I should have my A7 with Zeiss 55mm FE baby in the next few days and once I have chance to play with it, I'll be sure to post my settings to share. Can't wait...
 halfmonkey's gear list:halfmonkey's gear list
Canon PowerShot S95 Sony Alpha 7 Sony FE 55mm F1.8 Sony FE 35mm F1.4
dave92029
Contributing MemberPosts: 705Gear list
Center spot
In reply to halfmonkey, Feb 26, 2014
I like to use center spot, BUT the A7 has IMHO an annoying requirement that I must select Center Spot again each time I want to shoot in order to be able to move the center spot around the frame, which is one of the reasons I prefer this focus mode.
In order to compose a shot where the subject isn't in the center the A7 requires that I must  re-select center spot,  this doesn't take a lot of time but you may miss the shot by needing to confirm that you want Center Spot AND want the ability to relocate the spot!
I have programmed one  of the function buttons, but my Olympus Always allows me to move the center spot if I select that focus mode. I wish Sony would Fix this Issue?
Dave
 dave92029's gear list:dave92029's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +3 more
Jerry Fusselman
Contributing MemberPosts: 528Gear list
Thanks for the helpful table
In reply to navierb, Jul 14, 2014
It took me a minute to figure out what this is.  It is very useful for configuring my Sony Alpha A7r/s cameras. Thanks so much!
Jerry Fusselman
 Jerry Fusselman's gear list:Jerry Fusselman's gear list
Sony Alpha 7R Sony a6000 Sony Alpha 7S Sony Alpha 7R II Canon EF 50mm f/1.4 USM +26 more
ronguo
New MemberPosts: 20
In reply to stevo23, Oct 29, 2014
Many thanks for posting your settings. Helped me to narrow my choices for my A7R and prompted me to learn how to do!
I use mostly legacy lenses, so I shoot on manual settings. My mode choices are M or S.
S preferred now at 1/80, which then enables the cam to choose AutoISO from 100 to 1600. [not the best solution, but a decent work-around for avoiding the shutter-shock]. If I reach exposure limits, I adjust in order via Aperture, ISO, Shutter [but rarely below 1/60 handheld].
The centre button on control wheel is now set to Peak level. The control wheel is now locked to ensure ISO is not changed. But the arrows remain functional. [I want the down-arrow to be on/off toggle for LiveView, but this is not possible yet (needs new firmware)]
the Fn button controls the Creative option, which I set to "Neutral" with "sharpen" set to "+1". [my lenses give very accurate saturation and contrast, and I dislike the unnatural colours from the other settings]
I use RAW very rarely, so my shots are all jpg fine and large.
Yep
Yep.
Same.
Yep
philip pj
Senior MemberPosts: 1,493
In reply to ronguo, Oct 29, 2014
What is interesting is I don't use about 80% of your settings, l-o-l. Which shows how well the customisation can work, once worked through by each person.
As a guy who is always going from ISO 6400 down to ISO 50-100 and back, I just love the spin dial for ISO, and gladly live with the occasional unintentional nudge it gets to the next value. I wish all my cameras had had this, and here it is, as default.
The AF lights on Sonys are sometimes effective, but not necessary even in very low light. I leave it on unless I need stealth.
