what used 50/1.4 lens should I look for to A7r
Started Nov 21, 2013 | Discussions
Kari Rannisto Contributing Member • Posts: 923
Will get a A7r here in Shanghai and would like to as first lens choose a second hand manual 50/1.4 lens with proper adapter.
We have a great second hand market here and I can probably find most lenses here, so what should I look for in getting a manual 50/1.4 that would shine on the A7r?  200-300USD maximum
what do you guys recommend?
Cheers in advance
Sony Alpha 7R
Kari Rannisto OP Contributing Member • Posts: 923
Re: what used 50/1.4 lens should I look for to A7r
wanted to add that I already have a lot of Canon L lenses that I will get an adapter for so they can be used on the A7r as well, but the collection is missing a 50mm as well, therefore I start with that lens on the A7r
JohnK Veteran Member • Posts: 6,793
Hi Kari, IMO the Konica Hexanon 50mm f1.4 is a real winner, IQ wise
JohnK
Take a picture, it'll last longer.
 JohnK's gear list:JohnK's gear list
Sony Cyber-shot DSC-F828 Sony a6000 Sony Alpha NEX-5N Sony Alpha NEX-5 Canon EOS 5D
verybiglebowski
verybiglebowski Veteran Member • Posts: 3,773
Dream team:
1. Zeiss Otus 55/1.4
2. Leica Summicron f/2 Aspherical APO
3. Leica Noctilux 50/0.95
4. Leica Summilux 50/1.4 Asph.
5. Canon EF 50/1.2 L USM with MB SA III
6. New Voigtlander Nokton 50/1.5 or Zeiss Sonnar 50/1.5 ZM
7. Canon FD 55/1.2 S.S.C aspherical
8. Nikon Nikkor 58/1.4 Noktor
But, probably the best option will be FE 55/1.8
Don't trust your eyes or mind, they might betray you! Trust only comments posted on the forums, because there is the absolute truth!
http://www.flickr.com/photos/viktor_viktor/
http://verybiglobo.blogspot.com/
Sure a dream team .... But very $$$$$
will have a look at the used market
cheers
Dream team:
verybiglebowski
cheers
I was just kidding, but FE 55/1.8 could easily be one of the best options.
Nevertheless, you might want to check my brief comparison of legacy and third party 50mm f/1.4 lenses, or another comparison of super fast standard lenses (50-58mm). Few of those most popular should be there.
In general, I would pick the one that is in the best condition, unless you are after some specific look. Members here tend to recommand lenses that they have, (which is normal I guess), but in reality, they are all very good and rather similar in performance if you find good copy.
I would choose Canon FDn for sharpness across the frame, Minolta (MC) and Takumar for its build quality, Olympus (50/1.4 after serial number 1100000 is brilliant lens, not in my test unfortunatelly, but I tried it later) for it's compact size and Konica AR for good ballance of all that. (Zeiss or Leica are rather too expensive IMO.)
Differences might be more pronounced on FF though, so I am looking forward to re-test them soon on A7 and A7r.
Lightshow
Lightshow Veteran Member • Posts: 4,488
Cheers in advance
I'm really looking forward to using my Topcor RE 58/1.4, I only have experience with it on crop, and it's awesome on my NEX-7, it's at the upper end of your price range, there is a cheaper RE 58/1.8
RE 58/1.4 on NEX-7
From a Flickr search, on a 5DII:
http://www.flickr.com/photos/21716768@N08/4570523993/
Corners look good.
Other lenses....
OM 50/1.4 MC
C/Y 50/1.4 should be good.
If you are looking for good corners, look at ~50mm macros, they should be great, FD 50/3.5, OM 50/3.5 Nikkor 55/2.8, etc...
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Voigtlander 15mm F4.5 Super Wide Heliar +1 more
jkspepper Contributing Member • Posts: 544
If you're going to get a 50mm now, then I would suggest you get a 'speciality' lens.  The FE 55mm Sonnar coming out after Christmas looks to be a stonking good quality and sharp lens with native AF.  If you buy a 50mm now at that price range and that quality (both sharpness and bokeh) then I reckon the closest would be the Zeiss 50mm Planar - cheaper but lacks AF.
I had this thought too, I will get the native FE 55mm Sonnar when it is released, but in the mean while I got the Zeiss 50mm f1.5 C Sonnar.  Not as sharp but with a 'dreamy' bokeh quality.
PaulR Regular Member • Posts: 495
I've tested a bunch of 50mm lenses and the best one I've found so far was the Canon FD 50mm f1.4 SSCl and the second best was the Minolta MD Rokkor-X 50mm f1.4.  But I have also decided that sample variation and even variations in the adapter you use may be as important as the specific brand.
Cheers in advance
 PaulR's gear list:PaulR's gear list
Sony Alpha NEX-7 Sony Alpha 7R Nikon D600 Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN +4 more
seachicken2000
seachicken2000 Veteran Member • Posts: 3,181
+1 I reckon this, or its modern Voigtländer cousin, is definitely a good option. If they weren't so good they wouldn't be able to command the prices they do.
I have a feeling the humble Super Takumar 50mm f/1.4 will be a cracking lens on the Alpha7's. This can be had for very little money. Being an older lens, they are prone to flare, and so I'd recommend a multicoated version of the lens.
Looking at VBL's incredibly useful test it seems it's not the sharpest of the bunch wide open, but it has great rendering, and they do get nice and sharp stopped down. I am not sure how it will perform towards the edges on a FF sensor though.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Sony Alpha NEX-5 Sony Alpha NEX-7 Fujifilm FinePix S2 Pro Sony Alpha 7R +21 more
Jokica
Jokica Senior Member • Posts: 1,178
Very useful comparison can be found here . Courtesy of our forum member kuuan.
 Jokica's gear list:Jokica's gear list
Sony a6000 Sony a77 II Sony DT 16-50mm F2.8 SSM Sony E 50mm F1.8 OSS Samyang 85mm F1.4 Aspherical IF +2 more
YuriS Regular Member • Posts: 337
Hi! Take Minolta MD(MC) Rokkor 50mm f1.4. It is good on m4/3, it is wonderful on Nex-6 and it should be amazing on FF. And... It is relatively cheap. See samples:
http://natalispalette.jimdo.com/photo/minolta-md-rokkor-50mm-f1-4-lens/
http://natalispalette.jimdo.com/new-and-old-camera-lenses-by-yuri-stangrit/comparisons-and-reviews/several-50mm-prime-lenses-comparison/
 YuriS's gear list:YuriS's gear list
Sony Alpha NEX-6 Olympus PEN E-PL1 Samyang 7.5mm F3.5 UMC Fisheye MFT Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +1 more
Thank you all for great input, Will study the recommendations and links you provided.
Appreciated !!!
Michael Everett Senior Member • Posts: 1,916
+1 on FD and sample.  I did the same thing and ended with a Canon FDn 1.4, but only after discarding a couple of other Canons that were distinctly inferior.  The FDn bettered Olympus OM, Minolta and even a Zeiss Planar 1.7.
Michael
rjjr Forum Pro • Posts: 10,104
My Super Takumar 50/1.4 V2 is what I'd use. (nt)
No text.
