D610 vs. 5D Mark III
Started Nov 10, 2013 | Discussions
ron purdy OP Senior Member • Posts: 2,493
Re: D610 vs. 5D Mark III
11
Overall I love the Canon cameras for their functionality and durability. I have published thousands of images with Canon and for the most part, it's been very good.
This is a crop from a recent shot for a book I am working on. ISO 100. It was shot in RAW and converted in ACR. This is obviously a high dynamic range situation I exposed for the islands but had to lighten up shadows to see the boy. The only editing that's been done here was to move the shadow slider and to increase the exposure overall by .3 stops - and as you can see, things got ugly fast.
This is an example of what makes me nervous when shooting cameras with shadow noise issues, and what brought on the Nikon purchase. The Sony sensors are leagues more graceful on shots like this one, where there's no time to get a reflector or add lighting to even out the dynamic range.
In my book, this issue is MUCH more important than, "well gee, I bought the most expensive/sharpest lens I could find. DxO said the 24-70..." Sharpness of lenses/resolution of chip are minor footnotes compared to this, IMO:
ron purdy dot com
caspianm Senior Member • Posts: 2,132
Which Canon body?
 caspianm's gear list:caspianm's gear list
Nikon D800E Sony Alpha NEX-3N Sony Alpha 7 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +13 more
billythek Veteran Member • Posts: 5,258
Can you post your RAW file on Dropbox? Perhaps if the file were processed a little differently...
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
5
I can not post the RAW. It is to be published, and thus is off limits. That is why I cropped it.
Like I said, using ACR, all I did was increase exposure by 0.3 stops, and use the shadow slider (and no, I did not jack it all the way up to 100%.)
This is simply a high DR situation situation which the Canons handle very poorly.
Most of my Canon shots are fine and can be used without issue, but some end up like this. And this is obviously the same issue that the 5D II had, and the same issue which is well documented all over the web.
re caspianm's question: It's an image from the 5D3.
ron purdy dot com
Timbukto Senior Member • Posts: 4,618
ron purdy dot com
Yes its obvious what the issue is and its the same issue as the 7D or 5DMKII and to a lesser extent the 5DMKIII. The 6D is the first Canon camera that does not grate on me like that...granted it does not have a bottomless pit of DR like the Sony Exmors, but it has *enough* and it does *not* band. It gets uglier quicker than the Sony but it never *bands* which is the #1 characteristic that is subjectively grating on the eyes.
The 6D's DR I would say for most applications is good enough and absolutely workable, the Sony Exmor DR is *so* good however that you can't even take advantage of it with sliders without things getting out of whack and at that point you should work with layers.
So in summary -
Most Canon - pretty bad shadows and banding, limited use of exposure push and shadow pull without brushing all the time.
6D - first Canon that has just enough DR to eek by to the point that it is extremely usable in LR's tone curve adjustments for both exposure push and shadow pulls.
Sony Exmor - Go beyond what is needed for LR's tone adjustments to the point that you need to do layer mask to take 100% advantage of its terrific DR.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
ron purdy dot com
There's always an excuse as to why the RAW file can't be made available. Don't you have a dozen other shots similar to this one that aren't going to be published? Post one of those.
- Bill
Timbukto : I agree on all points.
Though I do not yet have a 6D. I tried a 6D several times though, and the outer-point AF seemed usable, unlike the 5D2.
ron purdy dot com
qianp2k Forum Pro • Posts: 10,350
I noticed you have few test photos in your DPR gallery. It seems that you used to be in the group of advocating no-banding problem
http://www.dpreview.com/galleries/3892554947/photos/1967157/no_banding_2
Do you mind to post CR2 file somewhere and I can show you with proper processing, it will look much better.
A simply way is just to mount a flashgun on your 5DIII and shoot in fill-flash that effectively solves the issue
I still see sky (highlight) is overblown. So you seem like to expose on highlight and pushing shadows many stops back. Sure Sony sensors are much better if you do this way, but this is not a good way to generate photos.
But that doesn't mean you cannot do with Canon cameras if you exposed properly such as increase +0.5 EV from your original photo, recover highlight in remote scene and push shadow moderately. Need some processing nevertheless.
Both are important. But let me show you how my 5DIII deals with such contrast scene.
OOC RAW
processed
The Victoria Falls at noon near-Equator harsh light. Left side is under very bright sunlight while right side is in pretty dark shadow. By exposing at middle, I am still able to recover highlight at left side and pull shadows at right side and I even recover even more brighter Falls' water with proper processing.
The Victoria Falls, Zambia
A few more samples that all are very contrast scenes. And yeah the peerless 24-70L/2.8 II shines
Cape Town, South Africa
sunset Zambezi River, Zambia without using any filter, taken from a moving fishing boat hand-held
If you believe you can get photos by exposing on highlight and then pushing deep shadows many stops back (where Sony sensor indeed has a big advantage), good luck. This is not a good method and only result surreal looking photo, that is well debated.
ron purdy dot com
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R +20 more
5
- Bill
Bill, have a look at my web site if you doubt that I am shooting for publication.
I can not post RAW files from an outtake from that shoot.
However, this can be duplicated with anyone's 5D3, you don't need mine
Here is what you can do Bill: do you have a 5D3? Find a HIGH D.R file which was exposed for the highlights and bring the shadows up without using N.R. and post a 100% crop or post the RAW file (don't use DPP, as it annoyingly ALWAYS applies N.R. regardless of the settings.)
ron purdy dot com
- Bill
I am not sure you know post processing well enough.  If you posted that photo in CR2 somewhere I can show you a big difference, seriously.
ron purdy dot com
quinp2k, here is what I just suggested to Bill:
Do you have a 5D3? Find a high D.R. file which was exposed for the highlights and bring the shadows up without using N.R. and post a 100% crop or post the RAW file (don't use DPP, as it annoyingly ALWAYS applies N.R. regardless of the settings.)
ron purdy dot com
Do you have a 5D3?
LOL, did you ever check my samples above, and tons more in my links below?
All samples I posted above are in pretty contrast scenes.
However in your that particular sample, a) I will not shoot in your way; b) even with that sample taken by you, I will process and will show much better result provided you posted RAW somewhere.
No what a camera can do for you, but what you can do with a camera
BTW, I have reasons why I said I love Canon colors
ron purdy dot com
shawn in ak Regular Member • Posts: 206
The 6D does produce much cleaner files if you need to push shadows than the 5D2/3. Kind of annoying with the 5D3--which is otherwise probably the best DSLR on the market, not counting the single digit pro series.
 shawn in ak's gear list:shawn in ak's gear list
Pentax K-5 Canon EOS 6D Canon EF 85mm f/1.2L II USM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +1 more
qianp2k, yes for a while I was not seeing the banding issue with this camera. That is because Digital Photo Pro does a better job with the noise and banding (it has always on NR) but it also removed a LOT of fine details so I use it only rarely now.
As for your samples, I do not see any 100% crops from recovered shadow areas without NR applied. am I missing something? (maybe I just can't tell as I am now on looking on a cell phone browser at the moment.)
*If you will, please post a RAW file from that one of the van parked in front of the stone wall.
Best.
ron purdy dot com
Like many who first tried cameras with Sony sensor, you seem now want to expose on highlight and then pushing up shadows many stops back on contrast scenes and truly believe this is the right way to generate photos. Wrong, most serious photographers will tell you this is not the right way. It also a beaten-to-death debate in DPR forums.
I have no problems to show some 100% cropped photos that is still sharp that I showed before. NR applied or not determine by content and light condition. I don't need apply NR or only little if under good light. If you push up shadows 4-6 stops back even without banding it will show ISO 1600 to 6400 eq noises/grains anyway. You will still need to apply NR in that scenario or noises will be very prominent especially if you view in big size.
Much better view on a big and high definition monitor. I'd also love to see your D610 samples on my Dell U2713H wide gamut monitor.
It's a key to expose correctly and process properly.
ron purdy dot com
Please post the RAW file, sir. (the van and the stone wall.)
Thanks.
Thanks.
NP, that is a sample of a test shot and can give away. Will do tonight after I return home. You process first. Then if you're interested I can show you how I processed.  It doesn't mean it's the best processing but just for a demo purpose.
Lovely.
As I have said, most of my Canon files are fine, otherwise I would not have been using them all this time.
Probably 95% of the shots on my site are from Canons. So yeah, I am not really knocking Canon, just noticing how much better the Nikon files are.
A few of my 5D files shot for commerce:
ron purdy dot com
ron purdy dot com
I'm not the one having the problem with my post processing technique, you are. Show me a RAW file that you are having problems with and I think I can show you an alternate way to process that avoids the problem. Of course if you blow out the highlights completely you can't recover.
- Bill
7
Trust me Bill, I am not asking you to help me with post processing, bu thanks for the offer
I am simply acknowledging and confirming that (like everyone has said) the Nikon has the better chip and yields better files, hands down. *Especially in difficult lighting situations such as that sample I posted.*
I have now personally confirmed for myself what DxO and the rest of the testers have already documented.
ron purdy dot com
