Help With Profiles Please
Started Nov 7, 2013 | Questions
Donny_B Forum Member • Posts: 86
Hi I have just bought a new Epson printer and what I would like to know which profile I should be using.
I have calibrated my monitor with Color Monkey but it doesn't do the printer I couldn't afford that one so should I be using the printers profile or the Color Monkey one. I use  Adobe CS6. I'm all very new to this please forgive my ignorance.
Thanks Don
 Donny_B's gear list:Donny_B's gear list
Canon EOS 5D Mark III Canon PowerShot S95 Panasonic Lumix DMC-FZ1000 Canon EF 50mm f/1.8 II Canon EF 70-200mm f/2.8L IS II USM +4 more
Phil Hill Senior Member • Posts: 2,676
Re: Help With Profiles Please
Use the CM profile for the display. When printing, you’ll typically use the profile supplied by the paper manufacturer.
Here’s a good place to begin:
http://www.dpreview.com/articles/2025119943/printer-primer-2-print-workflow
Hugowolf Forum Pro • Posts: 12,542
Which printer?
For what paper?
Your ColorMunki Display only produces profiles for your display. It should set them up so you need to do no more.
Perhaps you should consider reading a little about color management:
http://www.cambridgeincolour.com/tutorials/color-management1.htm
In general, to start out, I would suggest turning off color management in Photoshop, and letting the printer deal with color management, at least until you better understand what you are doing.
It isn't difficult. We all started with no knowledge. But it will take some reading. And perhaps hanging out on the forum.
Brian A
Gesture Veteran Member • Posts: 3,975
"In general, to start out, I would suggest turning off color management in Photoshop, and letting the printer deal with color management, at least until you better understand what you are doing."
I agree. When you let Printer Manage Color and choose the paper being used in the Printer driver, the printer will apply an internal, already determined profile.  Good luck and enjoy.
technoid Senior Member • Posts: 1,591
Generally, you should use sRGB as a default colorspace for all work in CS6 and print using "let the printer manage color" until you are comfortable with using profiles. In addition to the complexity they can be hard to verify that you are using them correctly without a spectrophotometer. Profiles are essential when pushing printers to their gamut limit but the effects are subtle on most images.
EtoA:
Profiling the display is valuable in itself and photoshop will use it automatically while you work in sRGB.
