Fuji - Softness & Noise questions
Started Nov 6, 2013 | Discussions
(unknown member) Contributing Member • Posts: 614
Just testing my new X-E1 up against my OM-D E-M5 - there is no doubt that there is a huge difference in noise, more than a lot of the online test shots & samples show.
However I am finding everything to be a bit too smooth if I am honest, skin looks a bit like plastic / wet / soft. The Olympus does seem to over sharpen everything, but at least there are some fine details such as pores, or small hairs.
Take the eyebrows here for example
Not as bad but still showing a little plastic looking
Fujifilm X-E1 Olympus OM-D E-M5
(unknown member) OP Contributing Member • Posts: 614
Re: Fuji - Softness & Noise questions
Edit: It's an X-E2 not X-E1. :r
Red5TX
Red5TX Senior Member • Posts: 1,586
It is impossible to evaluate this without EXIF and processing information.
No processing. Straight out of camera Jpegs, default settings, no noise reduction on X-E1
Both 1/125 f2.0 2500 ISO
ryan2007 Forum Pro • Posts: 12,001
Set Dynamic Range to 100%, set autofocus to Area and select the center, manually set ISO based on the lighting situation same as you would pick a film ISO, use Provia or Astia film mode.
as a guide
ISO 100/200 bright sun
200/400 cloudy/low light inside with flash
800 and higher no flash
Do not set any on camera sharpness or mess with color etc for now leave all that at Zero.
In short Fuji X cameras work best not use Auto I have found this way and first discovered this with the Fuji X20 that you can not use Auto settings. ISO and Dynamic Range are linked to each other. Check the manual for more detail.
I have the XE-1.
Oh, use exposure comp as needed.
viking79
viking79 Forum Pro • Posts: 14,136
Since they are JPEG, try setting NR to - something on Fuji.  At least on my XA1 it defaults to being too high.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Jim Evidon
Jim Evidon Contributing Member • Posts: 734
Are you shooting RAW or JPEG?  If RAW, what are you using as a RAW converter. Lightroom doesn't hack it if your needs are critical. Try Capture One ExpressPro7 or PhotoNinja or one of the other 3rd party RAW converter plug-ins or stand alone products that other forum contributors recommend.
I use C1 Express Pro 7 and my images from my XPro-1 are very sharp and do not look plastic compared to my OM-D E-M5 images. Both are equally sharp.
Jim
 Jim Evidon's gear list:Jim Evidon's gear list
Fujifilm XF1 Fujifilm X-Pro1 Olympus OM-D E-M5 Leica M9-P Leica T +2 more
baobob
baobob Veteran Member • Posts: 7,222
It is just a matter of settings IMHO
below an example with XP1 OOC JPEG only adjusted for levels and framing
You can sharpen abit more according to your taste For me this is close to, optimal sharp enough and silky smooth
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Fujifilm X-T10 Nikon D7200 +12 more
biza43 Veteran Member • Posts: 4,015
What you are showing is that two different camera companies have different strategies and outputs with regards to their OOC JPEGs default settings. Nothing surprising, and all perfectly adjustable to suit different tastes.
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Sony Alpha 7 II Sony Alpha 7 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Sony FE 35mm F2.8 +2 more
baobob
100% agree
Just a matter of working out the settings that suits best the user!
Daniel Lauring
Daniel Lauring Veteran Member • Posts: 9,033
I have the E-M5 and a couple Fujis.  It is the difference between the default settings of the two cameras.
I agree that Fuji, at it's default, can yield very plasticy looking effects...worse actually with some materials than with skin and at higher ISO's.  For example, green foliage can look like it was done with an oil paint palette knife.  Things like chrome fixtures can have oddly sharp definitions between spectral highlights...almost and orb effect like the infamous X10.
Having said that, you can mitigate this considerably by turning the NR down to -2.
Likewise, I find the default sharpening of the E-M5 is way too much.  It gives the shots a cheaper, oversharpened P&S look to them.
You can never make either camera exactly the same, but IMHO, the Fuji is the better performer, with regard to IQ, when you get the settings right...especially for photographing people.
Asylum Photo
Asylum Photo Senior Member • Posts: 1,277
Set NR to -2, Sharpening to +1
 Asylum Photo's gear list:Asylum Photo's gear list
Fujifilm X-E2 Fujifilm XF 23mm F1.4 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +2 more
hellocrowley Senior Member • Posts: 1,270
Search for "red channel Fuji" and you will find many threads on this. Fuji does blur details in the red channel, and healthy skin just happens to be reddish. This is why many love to use it for people photography though, who doesn't like smooth skin?
OOC JPEG example
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 6,454
either shoot RAW or at least turn noise reduction down.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Fujifilm X-T1 Sony a6000 Sony Alpha 7R +13 more
