GX7 Connect to netbook with wifi?
Started Nov 5, 2013 | Discussions
Waynger
New MemberPosts: 2Gear list
Nov 5, 2013
I easily connect my GX7 to my wireless network at home, but now I'm on the road and can't connect to my netbook that is not on a network. Anyone know if this is doable and source of some step by step instructions? Using windows 7
 Waynger's gear list:Waynger's gear list
Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
Panasonic Lumix DMC-GX7
David Kieltyka
Veteran MemberPosts: 4,638Gear list
Re: GX7 Connect to netbook with wifi?
In reply to Waynger, Nov 5, 2013
If your netbook can operate over WiFi it should be able to see your GX7 as a network it can attach to. I assume you have Panasonic's WiFi software (on my iPad it's called Image App). Make sure the GX7's WiFi broadcasting is turned on...if so the blue LED next to the WiFi button on the back will be lit. You'll need the password provided by the camera, of course.
-Dave-
 David Kieltyka's gear list:David Kieltyka's gear list
Leica M8.2 Pentax 645D Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 +7 more
Waynger
Waynger OP
In reply to David Kieltyka, Nov 6, 2013
Ok, I assumed since the laptop "sees" other networks, without additional software, it would see the gx7 when wifi is on, but it doesn't. I will checkout the panasonic sw and see if it supports win 7
Thanks!
David Kieltyka
In reply to Waynger, Nov 6, 2013
My iPad can see the GX7 by itself, but it needs the app to actually control the camera and/or pull photos from it.
-Dave-
