A7/A7r wireless flash.
Started Nov 4, 2013 | Discussions
PhotoKhan Veteran Member • Posts: 9,677
I now have the A7/A7r on my shortlist for a "light travel" plan: A camera, 2 or 3 lenses and a small flash to take along on trips where my Canon 1DMKIV and larger EF lenses might be both unpractical and unsafe.
The current EOS-M is the obvious other contender, together with its next incarnation, the M2, whenever it may pop-up.
My current EF lenses can work both in the EOS-M and Sony approaches, via dedicated adapters, both of which (Canon's and Metabones) support AF and IS.
However, Canon's current EOS-M offer has 2 severe drawbacks, as far as my needs go: No wired remote control capability and (I just learned) not currently being supported by PocketWizard's ControlTL system (I have several Control TL units and Speedlites).
I see the A7/A7r feature the wired-remote functionality.
I also see, under "Flash Modes" in the Sony cameras specifications a "wireless" mode listed.
Since those cameras do not feature an in-built flash, this can't be referring to "optical wireless", right?
If not, what are the Sony flashes (if any) that can work under "radio wireless"?
Thank you for any input.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.pbase.com/photokhan
(PBase Supporter)
Canon EOS-1D Sony Alpha 7
TiagoReil
TiagoReil Senior Member • Posts: 1,565
Re: A7/A7r wireless flash.
PK
(PBase Supporter)
For the A7(r) you have the same options as all the latest sony cameras (a99, nex-6, RX1, etc) and that is:
1-For TTL: get the sony hvl-20m as trigger and any other sony flash as receiver. It is obviously optical wireless. Not radio.
2-For non TTL: For studio strobes, and generic flashes, in manual obviously, (almost) any radio trigger for ISO flash will work. For instance any of the cheap yongnuo triggers (I have many of these). I go for many cheap. I have 3 tramsitters and 6 receivers. That costed me less than just one pocket wizzard. IF any of them fails, I have a lot of replacements.
There was information of an ODIN radio trigger for the new sony flash. I saw it some moths ago, but have not read anything in these days. Maybe the new A7(r) will make more manufacturers consider sony for their triggers. Here is a review of the old one, that points to the possibility of a new one:
http://www.frankdoorhof.com/site/2013/01/review-phottix-odin-for-sony/
Another from Frank using the A7r with the odin triggers:
http://www.frankdoorhof.com/site/2013/11/sony-a7r-review-part-ii-small-flash-and-more/
and here about the problems we now face with the transition from Minolta shoe to sony shoe:
http://www.lightingrumours.com/phottix-odin-for-sony-arrives-just-in-time-to-be-obsolete-2817
This would be very cool, cause you could have the tramsitter for the old or new shoe, and have receivers for the old and new shoe, so you could mix flashes (old minolta, and new sony) without a problem. I hope they release it soon. I really want this one. Still this solution is not cheap at all also.
I wont lie to you. If you dont like using a flash as trigger, right now, for TTL the sony is a bet. IT is workable (with adapter) but how good it will be in the future is not known.
 TiagoReil's gear list:TiagoReil's gear list
Sony Alpha NEX-5 Sony Alpha NEX-6 Sony 85mm F2.8 SAM Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 18-55mm F3.5-5.6 OSS +3 more
robert614 Senior Member • Posts: 1,322
PK
(PBase Supporter)
Unfortunately,"wireless" just stands for optically triggered wireless using a Sony flash mounted on top.
Sony doesn't offer any radio wireless flashes at this time.
I also contacted Pocketwizard ealier in the year and asked about them possibly producing a Sony version of their ControlTL triggers.They said they have received similar requests from others and are considering it,but I don't know if that will ever come to fruition.
Pocketwizard plus III's work fine on Sony cams though,Except you're relegated to manual control only.
There are a couple of TTL wireless triggers for Sony made by 3rd party manufacturers.They are made by Pixel King and Phottix.There might be others,but I 'm not aware of them.Only problem is that they are designed for the old Minolta hotshoe,and require you to add an adapter to make it fit onto the new hotshoe design.
I don't know how important all of this is to you if you're planning to use the A7/7r mostly as a travel camera,but I hope this info helps you in your decision.
Robert
PhotoKhan OP Veteran Member • Posts: 9,677
Tiago,
Thank you so much for the in-depth reply. Much, much appreciated
PK
(PBase Supporter)
TiagoReil
PK
(PBase Supporter)
Yes, that's exactly what I said in my post. Actually, not many camera manufacturers offer radio wireless triggers. Generally are third parties that offer them. There are exceptions.
I also pointed that out. any ISO trigger will work in manual mode.
Also, what said in my post, and with examples of people using it that way (The PHOTIX ODIN TRIGGERS). The pixel king is different actually. It is actually transforming the light patterns to radio, and then to light patterns again.
Robert
And I never said it was easy, or completely there yet.
(unknown member) Contributing Member • Posts: 946
Why would you need a wired remote control? A7/r feature NFC for wireless remote control through a smart phone. Moreover, I am sure there will be wireless remote controllers available for the cameras. Another option that I use is a $5 IR emitter plugged into the headphone jack on my Android phone together with an appropriate application has turned my phone into a remote control.
Thank you for your input, Robert
It is critical having a radio controlled (small) flash for travelling. It can be extrmely useful.
Ali Ben Youssef Madrasa, Marrakech:
(PBase Supporter)
Why, indeed...
http://www.kickstarter.com/projects/triggertrap/triggertrap-redsnap-modular-camera-trigger
PK
(PBase Supporter)
PK
(PBase Supporter)
Robert
I'm not sure if you're upset,but I wasn't trying to correct or contradict you.You and I seemed to be replying to the OP at the same time.Your post wasn't even up yet when I wrote my reply to the OP.Yet you seem to be angry I wrote a lot of the same information.Though your response was probably more helpful than mine was.
I was just trying to help the OP,just as you were.I don't come to this forum to argue with others.
Robert
TiagoReil
PK
(PBase Supporter)
Robert
Robert
Sorry Robert, not upset at all. I thought your comment was to correct something, but it seemed you were just agreeing with me. You know how internet is, we dont hear each other to understand the tone.
ti@go.
Wilky
Wilky Junior Member • Posts: 46
Re: A7/A7r wireless flash with Yongnuo YN-622N
I know this is an old topic but I'm new to the A7R. Sorry!
Would you expect a pair of Yongnuo YN-622Ns (which were used on a now defunct Nikon setup) to trigger an Olympus FL-600R?
On its own, in the A7R's hot shoe, the Olympus flash fires in Manual mode but, remotely, with the Yongnuos, it doesn't trigger for me. This combo works OK with my E-M1 though.
The YN-622N foot doesn't seem to fit all the way into the A7R's hot shoe.
If they are not compatible with Sony, could you recommend another unit please?
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,702
Sony optical-wiress-TTL-compatible flashes (note that hotshoes might be different) are made by Sony itself, Metz, Nissin, probably cheap one by iCorp/Tumax, Phottix... to name a few... above mentioned websites will give you an idea about setups where you can use simple remote radio triggering (in some case with remote power control)... and there is always possible to use a simple optical slave to trigger remote flash, albeit you don't want others to use flashes along w/ you
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
Abrak Senior Member • Posts: 2,590
In my opinion a very good option for wireless flash for the A7/A7r is
1) YN560iii Yongnuo flashes. These are very cheap (US$80 a go) well built and most importantly include a built in receiver. They are entirely manual though.
2) YN-560-TX Yongnuo transmitter. This is cheap (US$50) and well built. It lets you control power and zoom of each 560iii (up to 6) directly from the unit. In fact the only button you have to touch on the flashes is the on off button.
This is an incredibly user-friendly set up for off camera flash.
Of course people might be reluctant to buy new flashes but if you consider that 3 x 560iii flashes and one transmitter is a total of US$300, it is hardly a great expense.
swee New Member • Posts: 1
Hi TiagoReil, I read with great interest on your response regarding the Youngnuo flash and remote triggers for the SonyA7r
I am interested in getting them for interior photography and wondering if you would king enough to share with me the models of the flash and remote triggers and how you set the camera to receive the signals. Do you need a adapter for the hotshoe to accept the 3rd party flash?
Thank you for your help in advance.
zwinters New Member • Posts: 13
I am thinking of pulling the trigger on this set up! (YN560iii flash and YN-560-TX transmitter).
Can you (or anyone) verify that this setup works on the Sony a7? Or do I need adapters?
THANKS!!
 zwinters's gear list:zwinters's gear list
Sony Alpha 7 Sony FE 70-200 F4 Rokinon 24mm F1.4 Aspherical Rokinon 14mm f/2.8 IF ED MC Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +3 more
xtracrispy New Member • Posts: 9
this yongnuo 560iii and 560tx setup works well for my sony a7 and does not need additional hotshoe adapters. like abrak said, you must control the flashes manually (no ttl) and also there's no high speed sync (fastest syncable shutter speed is around 1/250th) . but even without those features, that price is hard to beat, especially for a system where the receivers are built into the hot flashes and you can remotely control all the flashes through the 560tx
Thanks! It's on its way... I'll comment with impressions once I start using it.
As far as I know the only TTL and HSS radio based off camera flash solution for Sony is the Phottix Mitros+. They have a built in receiver like the Yongnuos and you can use together with an Odin transmitter. I would really like to have one TTL and HSS off camera flash. They are not cheap though and I havent seen any reviews on how well they work and how reliable their TTL is. So if anyone has tried one particularly with an A7, a few words on their experience would be helpful.
RavenSight Forum Member • Posts: 67
I was wondering about this as well as I'm looking to purchase these flashes, and if Odin's transmitter works with ttl/hss then I'm sold!
Mark Kanawati Contributing Member • Posts: 606
I just purchased this Cactus V6 remote 2.4 GHz wireless trigger (with control) as well as the RF60 Flash Which seems to work quite nicely.
http://www.cactus-image.com/index.html
https://www.youtube.com/watch?v=ooOS2XMoJs4
Mark
 Mark Kanawati's gear list:Mark Kanawati's gear list
Carl Zeiss Apo Sonnar T* 2/135
