K3 : in Action
Started Nov 4, 2013 | Discussions
awaldram
awaldram Forum Pro • Posts: 12,317
K3 : in Action
As promised some from the weekend.
The hold AF allows for shots I could not easily achieved with the K5.
running out of DoF !!but camera stayed on head
hold  AF  has it done the trick ?
Let be sure .....Yep Hold AF works!
I just liked it sorry
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax Q7 Pentax K-x Pentax smc DA 40mm F2.8 Limited +15 more
Pentax K-3
ASR45
ASR45 Forum Pro • Posts: 34,979
Re: K3 : in Action
Looks like the K-3 is producing the goods, all good stuff.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS 6D Canon EOS 5D Mark III +7 more
MightyMike Forum Pro • Posts: 34,552
Re: K3 : in Action
Nicely done awaldram, but no Exif, what lens do you use? and that last one seems to have the WB a bit off, i'm sure you have tricky lighting in the pool but just noticing the white cap isn't quite white.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
awaldram
awaldram OP Forum Pro • Posts: 12,317
Re: K3 : in Action
Whoops sorry about exif re-sized at work with a different toll
The first two would be bigma last two da*300 all wide open 1/640 and iso 3200
As to WB the pool had end white sodiums and a glass wall but the slightly off white wb came in the eveing when the street light were shining through the windows @ pool centre .
Mike from Canada
robbo d
robbo d Senior Member • Posts: 1,837
so, what your saying....
....is the k3 has improved AF function, not so much in absolute speed, but its locking onto and keeping up with things the K5's previously would struggle, therefore we are getting a lot more sharp keepers and a more reliable system ?
Sounds like Audiobomber is experiencing the same with BIF
 robbo d's gear list:robbo d's gear list
Pentax K-5 IIs Pentax K-x Pentax K-01 Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 EX DG HSM +12 more
janneman02 Forum Pro • Posts: 15,732
That means trouble
More work  picking the keepers,  so much  easier if you can discard a huge number out of the camera
http://i.pbase.com/t1/73/362673/4/109584377.e8MTmsbX.jpg
http://i.pbase.com/o6/73/362673/1/90215210.jVwGKoPT.bugfv2kq5.gif
> The difference between genius and LBA is that genius has its
> limits.
> - Janneman ( adaptation of the Kings quote from Albert Einstein)
awaldram
Re: That means trouble
Never a truer word
> limits.
Johan Josefsson Senior Member • Posts: 1,151
> limits.
Wonder if it has improved SR?
Only one way to find out...
Re: K3 : in Action
I'm surprised you can use such lenses, must be a bright place, I can't even get by with an F4 lens at an indoor ice hockey rink, it really pushes the ISOs up.
Mike from Canada
awaldram
Re: K3 : in Action
Brighter than normal with 1 wall of glass and a sunny day
I was shooting 1/640 f4-5.6 iso 3200
whereas average is
1/400 f4 iso 1600
and bad
1/180 f2.8 iso 6400
Be interesting how it performs under mixed orange sodium my K5 used to hate that refusing to focus under what I considered workable light ev1-2.
Juts been playing with the k3 in low light it will focus 4sec f2.8 iso3200 !! I can't even see what it focusing on till I take the shot.
Mike from Canada
kitsios_spyros
kitsios_spyros Senior Member • Posts: 2,084
awaldram wrote:
Never a truer word
That's what I thought too!
Impressive results Andrew. K5ii is OK for my needs AF wise, but it seems that AF is really improoved in K3. Thanks for sharing these samples. They go together with Dale's and Dan's samples too.
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Samsung NX300 Pentax K-5 II Pentax K-3 Pentax K-3 II +13 more
lock Veteran Member • Posts: 6,183
Is this jpg straight out of the camera?
Or did you PP them ? If so, what noise reduction did you use.
Lock
awaldram
Re: Is this jpg straight out of the camera?
Lock
I usually use neat image pro  but these were knocked out on my work PC so if any it would be noise ninja plugin for after-shot-pro.
but as they were AF examples I didn't take much notice what settings were when processed sorry.
Also they were originally the Jpeg OOC just resized in aftershot so will have Camera Nr applied.
awaldram
Lock
Found theses originals still on the puter
so re-sized only should have exif intact ensured all PP was unselected.
Barry Pearson
Barry Pearson Veteran Member • Posts: 7,299
Re: K3 : in Action
I'm finding the same - if I can see it, then with the right lens I can probably focus on it. Liberating!
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-3 II Pentax K-1 Pentax smc DA 12-24mm F4.0 ED AL (IF) Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +19 more
awaldram
Re: K3 : in Action
Think I may need to re-asses my lens as well
Was playing what's fastest in moderate low light and to my surprise point to point 5ft -20ft my da*55 was quickest followed by the da* 16-50 !
My quick lens the da* 300 was 3rd and 50-135 4th with my 'controls' da 18-55 (nicked wives off KX) and Sigma 70-300 Apo seriously sluggish.
I suspect it's T-stop related, Besides the Sigma which seems to have a bug every time I went short to long the lens focused shorter - long !
hayslip Contributing Member • Posts: 990
> limits.
I wonder if a proper lawnmower SR test will come out in the near future....
Peace - Roger Hayslip
 hayslip's gear list:hayslip's gear list
Pentax K-3
Barry Pearson
Re: K3 : in Action
Interesting comment about the DA* 55mm f/1.4. That is what I have been testing (successfully) in low light conditions (rain at night) around my village.
I need to test my other lenses in low light conditions, otherwise I will have a biased view of the K-3.
